Fog lights just stopped working...
Hi guys,
I have a 99 SE and for whatever reason, my fog lights just stopped working at the same time. Not sure if it's coincidental, but I replaced the stock bulbs today with some Xenon 55 watt H3 bulbs.
I have replaced the relay, the 15 amp fuse, and put the stock bulbs back in, but no luck. I haven't checked the wiring harness, but I don't feel like that would be the issue. Any idea why this is happening?
Here are the specs for the bulbs I put in the car today:
Part Number: XB-H3BP
Weight: 0.15 lbs
Clear
H3 Bulb
Amperage Draw: 4.58
Attachment Method: Plug In
Bulb Call-Out Size: H3
Bulb Technology: Halogen
Bulb Type: Halogen
Thanks in advance for your help!
Weight: 0.15 lbs
Clear
H3 Bulb
Amperage Draw: 4.58
Bulb Type: Halogen
There are 2 fuses involved. One fuse is the power for the fog light bulbs and the other is used to energize the relay. They are both under the hood. The one labeled fog is for the bulbs, but I don't know the label for the other one. It is a 15 amp, on the battery side, the first one from the front. This 2nd fuse is also used for more than just the fog light relay, so if everything else is working, it's probably OK.
When I flip the fog light switch, I can hear the relay click, so I think the switch is fine. Even with the old bulbs back in, they won't come on!
Headlights are working just fine. My fog lights worked for about an hour before they both just stopped working completely. I made sure I had the correct bulb, and I do! Not sure why the harness would just go out.
Fog lights not working
The Frye
09-02-2021 11:03 AM
Maxima30
09-07-2015 06:13 PM
