Cheap DIY polyurethane motor mounts
Old Feb 10, 2014 | 06:16 PM
  #41
Originally Posted by asand1
The stuff dries harder than the original rubber, and ES polyurethane supports engines fine, so I don't doubt this will work great.
Depends on your perspective. These are the mounts that bolt to the cross member and engine block. They are the engine mounts that control the torque. I call them the front and rear, as this is where they are located inside the engine bay.
Yes, but as a mechanic, I would think you'd call them out correctly as left and right (relative to engine).
I hope I'm wrong, but I don't see this stuff working/lasting that long either.
Although some claim success with the stuff you bought, did you see this post in the Honda thread you linked?
"So I used the PL door and window sealant...it's NOT the correct one. Came out white and dried to a soft texture, very similar to the OEM rubber inside the mounts."
Old Feb 10, 2014 | 07:49 PM
  #42
asand1's Avatar
But they are chassis parts, not engine parts.
We will see how well they work. If they are no good i will use the same process using pl premium adhesive.
Old Feb 10, 2014 | 07:51 PM
  #43
asand1's Avatar
Does anyone know what the diameter of hockey pucks is?
Old Feb 10, 2014 | 07:53 PM
  #44
02 sensors are the same way.
How much cure time are you going to give them?
Nice jigs btw.
Old Feb 10, 2014 | 08:24 PM
  #45
Slamrod's Avatar
Asand1 you should let me "rent" your unused mounts when this is done so i can do the same. We could set up a chain of motor mount swapping!
Old Feb 10, 2014 | 10:37 PM
  #46
asand1's Avatar
Nice jigs btw.
3 weeks to a month.
Old Feb 11, 2014 | 07:42 AM
  #47
That's what I used
Old Feb 15, 2014 | 06:38 PM
  #48
asand1's Avatar
I've had the mounts out in the garage on the jigs for 5 days under a large tote with a heater running inside. Today I took the mounts off the jigs to come inside the house and cure for the rest of the duration.
Old Feb 15, 2014 | 07:16 PM
  #49
CMax03's Avatar
I usually clean up the used mount really well, and just fill in the voids...But I most say that jig and your method is pretty cool! I hope you plugged the bottom side....
Old Feb 15, 2014 | 10:31 PM
  #50
max ride 41's Avatar
correct me if i'm wrong, isn't there supposed to be a little play in those mounts as it reacts to bumps and engine torque? i mean, i understand the more solid the better, but i'm thinking you would want a little play in them, right? also, just cause it isn't rubber doesn't mean it's not safe, or does it? any write ups on how safe his mounts will be?
Old Feb 15, 2014 | 10:56 PM
  #51
Fakie J Farkerton's Avatar
He is his own test dummy for these, but solid mounts are fine; just more vibration.
Old Feb 15, 2014 | 11:00 PM
  #52
Slamrod's Avatar
I believe doing it as described in this thread results in stiffer mounts, which cater more to performance. There is still play, just not as much. IIRC the trade off is having less engine movement however more of that torque is transferred to the chassis which makes the driver feel it more. Smoother for the car but not the rider? Still doing my homework here myself.
Really digging this thread, always cool to see someone keeping a journal of sorts on their latest max project.
Old Feb 16, 2014 | 01:13 AM
  #53
asand1's Avatar
Solid motormounts will cause buzzing of my dash and trim at idle, but the trade off in durability of the mounts will be well eorth it. Also there will be no more pushing and pulling on hoses and harnesses. Shifting will be crisper and there will be a firmer feel while driving. As it is now my motor moves enough to affect the car at speed. Like a strong wind hitting you. You can feel the qhole car shake and shimmy when the engine moves.
Old Feb 21, 2014 | 07:13 AM
  #54
asand1's Avatar
Eleven days in and my home depot motor mounts are firming up nicely. 20 more days and they should be ready.
Old Feb 22, 2014 | 01:02 AM
  #55
CMax03's Avatar
You actually think it takes that long too cure fully? I would say 3 days is all that's needed.
Old Feb 22, 2014 | 04:03 AM
  #56
dwapenyi's Avatar
Solid motormounts will cause buzzing of my dash and trim at idle..
...in a 5MT Maxima sitting at a stoplight in neutral? If so, boy that's stiff.
Old Feb 22, 2014 | 04:55 AM
  #57
asand1's Avatar
at three days i could have pulled the inner sleeve out by hand. These are solid poly, no rubber. It will take a long time. Right now its kinda like a water bed, push here, and it rises there. It is much stiffer than five days ago yhough.
Old Apr 2, 2014 | 12:16 PM
  #58
mikeyen's Avatar
I'll add my voice, great job on the jig.
I'm in the process of reinstalling the upper pan on my 96 GLE, and the firewall and radiator mounts were both trashed. So I put in a pair of DEA's, and hope they're durable.
In fact, my question is about durability... How are these for durability? Both mounts are inches away from the exhaust manifolds; how is this material going to hold up at that point in the engine bay? How close to the manifolds are the engine mounts on Hondas?
Last, how do you maintain the left-right orientation on the center metal tube? This part isn't clear to me in your pictures.
Old Apr 2, 2014 | 12:24 PM
  #59
mikeyen's Avatar
Actually, I think I may have answered the temperature question on my own:
http://www.loctiteproducts.com/tds/PL_SEAL_DWS_tds.pdf
Supposed to withstand temps > 200. Where I live, 200 degrees in the summer is just about guaranteed, front or rear.
I think you should oven-test these: Put them on a cheap pan your SO doesn't care about, and put them in the oven for an hour at increasing temps (I'd start at 300). If it's fine at temps up to 400, I bet these are just fine.
Old Apr 2, 2014 | 12:25 PM
  #60
I was just thinking about bumping this thread yesterday. Did this stuff harden up like you hoped? Or was it a fail and you're going to try something else?
Old Apr 16, 2014 | 03:46 PM
  #61
bewrong's Avatar
How are the mounts holding up?
Old Apr 16, 2014 | 07:03 PM
  #62
He said his caulk is still soft.
Old Apr 16, 2014 | 10:05 PM
  #63
asand1's Avatar
They need some extra curing time.
Old May 15, 2014 | 11:03 AM
  #64
Sorry it didn't work out.
Old May 21, 2014 | 04:50 PM
  #65
asand1's Avatar
I installed the new mounts today. There is a quite measurable improvement over the old mounts. Still spongy, but the engine doesn't knock around when shifting, or goosing the throttle in gear.
UPDATE: Don't use PL adhesives, they are much too soft and don't hold up well.
Front mount driver side view.
Front mount passenger side view.
Rear mount driver side view.
Old May 21, 2014 | 05:17 PM
  #66
Please be sure to give us an update 1 to 2 months from now.
Old May 24, 2014 | 01:30 PM
  #67
Goomz's Avatar
i filled mine with polyurethane caulk in a honda i used to own and it dried in 2.5 days rock solid...in those 2.5 days i finished my swap and sold the car 2 years later no issues with the mounts at all...survived numerous trips to the track, road racing, daily driving and held up like new. i couldnt feel or hear any extra vibration upon driving/racing etc, except in the winter upon cold motor startup...it was just noticable to know that aftermarket "style" mounts were in my car.
i wish i could remember what specific brand of polyurethane it was but this was back in 07. good luck asand1, i read about this method from dsm forums years ago that inspired me to do this.
Old May 29, 2014 | 09:35 PM
  #68
asand1's Avatar
I've done some research and found some info for different fillers, with comparative pricing.
The PL S40 I used is only Shore A 28-32, and $7.99 a tube.
3M Auto Glass Urethane Windshield Adhesive-Medium Viscosity,
PN 08693, Is Shore A 50-55 and about $15.00 a tube.
3M Windo-Weld Super Fast Urethane, PN 08609, is Shore A 55-60 and $26.00 a tube.
I think 3M 08693 is the winner, and will go in my old mounts soon.
Pictured below are my OE MT motor mounts. Like the AT mounts, they are both fluid filled. The electronic mount is actually not an electrorheological fluid, like many believe. It simply has a servo motor that adjusts fluid damper valving like an adjustable shock to decrease vibration at idle. Old mounts were in better shape than the wrecking yard mounts. Perfect for filling gaps with construction adhesive
Here is the rear mount after cutting some rubber out of the top of the mount and draining fluid out. With these mounts I will cut out some rubber, drain, clean, and fill.
Fluid
I have cut away rubber on these two with a 1/2" hole saw. You can see the rear mount on the right has a good sized cavity on the bottom that was fluid filled. Also the mount on the left must be drilled in the area marked with red, this will reveal a cavity that must also be filled. After drilling and cutting rubber away they can be cleaned with brake cleaner and a toothbrush.
Old Sep 16, 2014 | 08:24 PM
  #69
asand1's Avatar
Today I picked up the 3M 08693 window urethane for $11.23 at NAPA auto parts and filled my original MT mounts. I cut a couple lengths of 1/2" aluminum tube to help fill the voids in one mount, this allowed me to complete the whole job with just one tube of urethane.
Old Sep 18, 2014 | 09:45 AM
  #70
asand1's Avatar
Both flavours of 3M window sealer are moisture curing;
http://multimedia.3m.com/mws/mediawe...6EVs6E666666--
After letting the mounts cure over night I placed them in a bucket of hot water. and twice I have put them in the steamed up the bathroom with a heater. They are getting pretty hard now and they will be fully cured long before my next day off on Wednesday.
Old Sep 24, 2014 | 01:16 PM
  #71
asand1's Avatar
Today I installed the new DIY mounts. The white mounts were not pretty. The rear mount tore loose and formed a gap above the eye.
Mounted the new DIY urethane mounts and bolted the cross member in, torqued to 65ft/lbs.
Car shakes a bunch at startup, but idle is still smooth.
Old Sep 24, 2014 | 01:51 PM
  #72
asand1's Avatar
Old Sep 26, 2014 | 06:37 AM
  #73
ateick's Avatar
Anybody ever fill a mount while it was on a car? I've been having vibration issues after a trans swap. I've swapped out the engine mounts and pass side mount. It's gotten better but not good enough for my liking. The last mount would be the MT mount BUT because of the swap I've welded it to the frame (Tip all - bolt it don't weld it). I didn't think of it at the time but now I can't remove it to swap it out. My solution would be to fill it while on the car. It can't make it any worse I suppose. Just wondering if anyone has tried it.
Old Sep 26, 2014 | 07:14 AM
  #74
asand1's Avatar
I suppose if you have room to clean it and get a caulking gun to it. And you wouldn't want to drive it for a week.
Old Sep 26, 2014 | 04:32 PM
  #75
asand1's Avatar
After diving to work and back, I am very pleased with how positive the shifting is now. No more shifter bouncing around in my hand with the motor and the car doesn’t lurch at low speed. Could be placebo, but the car also fells much more stable cornering on the highway, possibly from less weight shifting over the front tires.
Old Sep 26, 2014 | 11:51 PM
  #76
guarantee you that's the reason, keep us posted in 2-3 weeks on how they're holding up!!!
Old Sep 27, 2014 | 10:34 PM
  #77
CMax03's Avatar
Either there was an air pocket inside the mt cause you didn't press the urethane in thoroughly or the material doesn't have the elasticity/durability found in the the 3M polyurethane....
Old Oct 7, 2014 | 05:26 PM
  #78
asand1's Avatar
Three weeks later and they are still solid, while not causing the car to buzz excessively. Shifter is rock solid on accel and decel.
Old Jun 4, 2015 | 10:57 PM
  #79
asand1's Avatar
Still good and happy.
AaronL
Sep 23, 2015 03:34 PM
pears
Sep 18, 2015 05:25 AM
vball_max
Sep 17, 2015 10:01 AM
QueensMAX
Sep 15, 2015 04:14 AM
spidgeon
Sep 9, 2015 03:36 PM
