Car Stuck In 5th Gear And Won't Move Now But Speedometer Shows Speed Increasing
Old Mar 17, 2015 | 12:09 PM
TurboMaximaFan's Avatar
I'm having problems with my 99 Maxima 5-Spd Stick Shift ...Thursday of last week I came around a curve and attempted to downshift from 5th and my gear was then stuck and I rode down the road till I got to my road and tried to slow down enough to make the sharp turn onto my road and my car then just stopped and on my speedometer it showed that I was moving everytime I tapped the pedal even though I was sitting still , I also hear the sound of gears grinding .. anybody have any ideas what it could be ? I'm thinking either the tranny needs to be replaced or it needs gear oil .. ?
Old Mar 17, 2015 | 02:11 PM
CMax03's Avatar
Have someone press on the clutch and see if the slave cylinder is moving...
Old Mar 17, 2015 | 02:55 PM
Yes it moves
Old Mar 17, 2015 | 03:04 PM
CMax03's Avatar
You sure the pressure plate fingers aren't broke....?
Old Mar 17, 2015 | 03:18 PM
asand1's Avatar
I don't know about being stuck in 5th, but your diff is shot, or a half shaft has popped out. The final drive is spinning, this is driving the speedo. For whatever reason the final drive is not transmitting power to the wheels though.
Sent from my XT1060 using Maxima
Old Mar 18, 2015 | 12:25 AM
CMax03's Avatar
You may have a throw out bearing that failed, Pull it and see!
Old Mar 18, 2015 | 11:47 AM
That wouldn't stop both wheels from spinning and I hear gears grinding .. plus it's hard to put in gear .. but yea my front left bearing is bad .
Old Mar 18, 2015 | 05:01 PM
asand1's Avatar
If you're referring to my post, then you don't understand how a diff works. Most cars are "one wheel drive". A diff is a set of gears that allows the wheels to spin at different speeds. If one wheel loses traction, it will spin double ring gear speed, and the car will not move.
If a halfshaft pops out of the trans (they do occasionally) you will go nowhere, and you will hear the splines running past each outher with the ends barely touching. This is the grinding you hear.
https://maxima.org/forums/4th-genera...ng-struts.html
https://maxima.org/forums/4th-genera...e-reverse.html
At 0:06 you can see the left side CV is popped out of the diff case, exposing the shiny sealing surface.
Old Mar 18, 2015 | 08:06 PM
That's The Noise !!! Lol
Old Mar 19, 2015 | 02:46 AM
asand1's Avatar
Have you done any recent suspension work? Any recent thrashing on the car?
Old Mar 19, 2015 | 08:25 AM
Nope , I Just Bought It From Someone , So What Am I Gonna Need To Do ..
Old Mar 19, 2015 | 03:03 PM
asand1's Avatar
Get it on jack stands and look around. First thing to look at would be driver side inner CV joint. See if it has come loose and moved out away from the transmission. Passenger side has a carrier bearing and wouldn't pop out without breaking the bracket.
Second would be the joints themselves, they could have come apart inside. Look for a joint where part is spinning and part is not. Everything should be spinning from the wheel to the inner joint.
Its also possible that the differential is grenaded, but not very likely.
Are you still stuck in fifth, or can you select other gears? Can you select other gears with the engine off?
Old Mar 19, 2015 | 03:10 PM
DennisMik's Avatar
Wow, good job diagnosing that, asand1!
Old Mar 19, 2015 | 10:08 PM
At first I couldn't but I put break fluid in and I got all gears now .. but I just can't get the car to move and I hear that grinding noise .
Old Mar 19, 2015 | 10:17 PM
asand1's Avatar
Good deal, but it sounds like you have a hydraulic clutch leak somewhere. check the lines, slave cylinder, and inside the car at the firewall for wetness. BUT FIRST>
Get that car in the air and inspect just as I laid out two posts up. We'll get you going as long as you're willing to do the foot work.
Old Mar 19, 2015 | 10:19 PM
I will first thing tomorrow
Old Mar 20, 2015 | 12:14 PM
Another thing I noticed , the oil light isn't on when I first turn the key to On , everything other light comes on like normal except that one now .
Old Mar 21, 2015 | 07:56 PM
asand1's Avatar
Well?
Old Mar 21, 2015 | 08:10 PM
Found out that both axles are bad and one is broken and a plug in the bottom was hanging lose and the axle knocked it loose when it broke
Old Mar 22, 2015 | 05:52 PM
asand1's Avatar
Get some pics and maybe a video. If the tranny is OK, axles can be had from Rockauto for CHEAP.
Old Mar 26, 2015 | 04:18 PM
asand1's Avatar
Any updates?
Old Mar 27, 2015 | 03:18 PM
Maximeltman's Avatar
Originally Posted by asand1
Any updates?
Old Mar 28, 2015 | 12:36 PM
NEED HELP ASAP 99 Maxima
something came a loose by my axles . I was wondering if anyone could tell me what it is ...I'm trying to provide a pic Car Stuck In 5th Gear And Won't Move Now But Speedometer Shows Speed Increasing-image.jpg
Old Mar 28, 2015 | 12:53 PM
Fakie J Farkerton's Avatar
Looks like the carrier bracket on the passenger axle.
Did it break?
Old Mar 28, 2015 | 01:23 PM
I think a bolt came out or something
Old Mar 28, 2015 | 01:47 PM
tosheto's Avatar
If I remember correctly, there are 3 12mm bolts that bolt your axle to the engine. Go to a junk yard or a dealer and get new bolts. I would not drive the car before you tie up your axle.
Old Mar 28, 2015 | 03:56 PM
vqmaxman's Avatar
It looks like the axle popped out do to the carrier bracket or that bracket screw and bracket broke.
Old Mar 28, 2015 | 04:02 PM
vqmaxman's Avatar
The pic looks small is there a bigger pic.
Old Mar 28, 2015 | 04:18 PM
CS_AR's Avatar
This reminds me of the following thread.
https://maxima.org/forums/4th-genera...power-oil.html
Old Mar 28, 2015 | 05:57 PM
asand1's Avatar
Bolt the bracket back onto the engine. Just as I posted in your other thread, If the bracket breaks (or all the bolts come out) the axle will come out of the traans and make grinding noises and no drivey drivey.
BTW why did you start a separate thread for the same problem?
Old Mar 28, 2015 | 05:58 PM
asand1's Avatar
Old Mar 28, 2015 | 05:59 PM
JoshG's Avatar
if u could circle in red the location, that would help too
Old Mar 28, 2015 | 06:00 PM
asand1's Avatar
Originally Posted by turbomaximafan
something came a loose by my axles . I was wondering if anyone could tell me what it is ...i'm trying to provide a pic
Old Mar 28, 2015 | 06:14 PM
maximaham's Avatar
Here you go. wow... how did that happen, makes me wanna check my bolts
Old Mar 28, 2015 | 07:17 PM
asand1's Avatar
He just bought the car, this happened and he ran out of clutch fluid. Car was likely wrenched on by a hack or tweaker and is like this all over the place.
Old Mar 29, 2015 | 01:44 AM
vqmaxman's Avatar
Ok, this is a better pic, now the bracket is just hanging loose,where are the bolts,did they break off or the bolts were never on the bracket. Look where the bracket mounts on to the car, see if the bolt holes are stripped or broken in the holes.
Lakersallday24
Jun 16, 2019 01:35 AM
Finkle
Sep 27, 2015 09:53 PM
AT978
Aug 15, 2015 06:39 PM
BobMax
Aug 15, 2015 12:35 PM
Balkins
Aug 12, 2015 06:39 AM
