97 Maxima Battery & Brake Lights ON. Bad Battery Terminals?
Old Apr 25, 2015 | 02:41 PM
Pizzyflavin's Avatar
Hey all, I recently replaced the battery in my car and the positive terminal halfway broke leaving a loose connection. Afterward, the battery and brake lights were both on. I'm fairly certain they were not on before this.
I am aware that these lights being on simultaneously generally indicates a bad alternator, but I'm hoping that battery terminal could be the cause.
Thoughts?
Thanks!
Old Apr 25, 2015 | 02:49 PM
uttadms31's Avatar
Either way fix the terminal/battery first...have a warranty on it? Then fully charge the battery, start it up and see if you're getting around 13.8-14.4 volts or so, if so then the alternators fine.
Old Apr 25, 2015 | 02:51 PM
CMax03's Avatar
Dashboard brake light or actual brake lights?
uttadms31's Avatar
Also wouldn't the odds be quite low that the alternator would fail right after the battery terminal broke
Old Apr 25, 2015 | 04:20 PM
njmaxseltd's Avatar
The broken battery terminal also supplies the reference voltage for the alternator. Without it, the alternator won't charge, hance the lights.
Old May 4, 2015 | 10:43 AM
Thanks for your responses guys, sorry for the late reply.
@CMax03: Dashboard parking brake light.
@uttadms31: I agree, the probability is low.
I fixed the terminals, but I'm still getting those lights. Drove it around for about 15 minutes with no car death (probably about an hours worth of driving total).
I'll check it with a multimeter in a bit, but I don't have a means to fully charge the battery.
Old May 4, 2015 | 12:58 PM
tosheto's Avatar
Take it to autozone or another parts store. They will charge it for free.
Old May 4, 2015 | 02:38 PM
uttadms31's Avatar
Did you ever test the alternator by checking for around 13.8-14.4 volts at the battery terminals with the car running? If not, then when you go to Autozone to charge your battery, have them do this alternator test after.
Old May 4, 2015 | 05:13 PM
Daniel VQ30life's Avatar
sounds like your alternator picked a good time to take a dump on you. in my experience with these 4th gens, you'll be on top of the world for months at as time but when something goes wrong, everything goes wrong
Old May 4, 2015 | 07:45 PM
sanford7575's Avatar
A little advice; it;'s the alternator. Also, don't go used or reman, or you'll be doing the job all over again in a few months. I buy all of my alternators new on ebay. You can find some for under $100, that last a lifetime.
Old May 4, 2015 | 11:35 PM
vqmaxman's Avatar
The other thing can also cause this light to come on the master cylinder if the brake fluid is low and if the cable is loose that goes onto the master cylinder. I would check the voltage and the battery cables tighten them up from the starter to the battery terminal the battery terminals have to have a good clean connection from the build up corrosions.
Old May 6, 2015 | 10:46 PM
LaadiDaadi's Avatar
+1 on the alternator. I just had the same exact thing happen to me. I thought it was the terminals and the battery itself and after replacing both of them it turns out that it was the alt.
mithao101
Dec 28, 2019 11:35 PM
JLA117
Feb 20, 2015 12:58 AM
udienow
Oct 26, 2009 04:40 PM
akbarrasheed
Jan 18, 2008 08:21 PM
DJMaxGLE
Jan 16, 2008 03:28 PM
