water leak behind glovebox after heavy rain
Old Nov 8, 2015 | 07:16 PM
omegaboost's Avatar
Hey,
I've been trying to search for an answer for quite some time but didn't find anything clear.
My 4th gen is leaking from behind the glovebox, from the blower motor and elsewhere when I hose it down with a garden hose on the cowl. I just can't seem to find the darn leak!!! Its not from the sunroof, its definitely from the cowl.
Anyone have the same issue and managed to fix it? I'd really appreciate it!!
Old Nov 9, 2015 | 11:07 AM
JvG's Avatar
JvG
You live in an area where rust is a common problem. You could have rust-threw on the cowl behind the windshield seal.
Old Nov 10, 2015 | 10:20 AM
DennisMik's Avatar
Here is a link to a thread in the 5th gen section from a guy that had a leak sounding very similar to yours. Since the 4th and 5th gens are fairly similar, you should check it out.
https://maxima.org/forums/5th-genera...ger-floor.html
Old Nov 10, 2015 | 07:25 PM
omegaboost's Avatar
^ I saw that a while ago and sealed them pretty good but it still leaks. =/
Old Nov 10, 2015 | 09:27 PM
ef9's Avatar
ef9
My 96 I30 leaked on both sides behind each fender. I had to cut this piece open to gain access to the rust.
Same problem on my 95 Hardbody.
Old Nov 11, 2015 | 07:39 PM
omegaboost's Avatar
nice. Did you do anything else to it or just cut that section out so it could drain properly?
Old Nov 11, 2015 | 08:33 PM
ef9's Avatar
ef9
I had to cut that support structure to see where the leak was.
I cut the rotten section out and riveted a piece of sheet metal with gasket maker around the seams and rivets. Then painted it with rustoleum paint afterwards.
pieterm
Jun 13, 2020 05:36 AM
Genes1s
Aug 27, 2018 05:47 PM
98MaxGLE234K
29
Feb 8, 2016 07:34 AM
Mrbizness1
Nov 14, 2015 05:15 PM
Chefmatt
Nov 8, 2015 01:38 PM
