1995 Nissan Maxima - need help with turn signal wiring
Old Apr 14, 2016 | 06:00 PM
cols's Avatar
Good Evening:
Long story long - sorry. My grandson's car had a busted key in the ignition. So a lock smith was called to remove. In doing so he removed some wiring clips, and now the turn signals don't work. There's one small black clip with two wires on it, but I can't find out where to plug it in. Can someone please provide me with a picture that shows the wiring harness inside the steering column and where each clip plugs into?
Thanks so much for your adult supervision.
COLS
Old Apr 14, 2016 | 07:07 PM
JvG's Avatar
JvG
There will be many photos available if you would use the search area of this forum. Many will be found by seaching for " ignition switch". The photos should show where the plugs belong.
Old Apr 15, 2016 | 11:37 AM
Maybe the turn signal relay under the dash was disconnected. Look up under the dash by where your knees would go.
enterconnect
May 31, 2016 02:02 PM
JDM_A33
Apr 3, 2016 02:33 PM
tarun900
Mar 31, 2016 05:45 AM
rotarymagic
Mar 29, 2016 09:12 PM
SuperStriker302
Mar 18, 2016 03:28 AM
