Cruise control
Old Jun 2, 2016 | 07:52 PM
ShunDoe's Avatar
Cruise control
Cruise control stopped working out of nowhere. I want to say it was around the time I had my brakes replaced. What crazy is a friend of mine had a Infiniti Q45 and the same thing happened, his cruise control quit working. Any solution?
Old Jun 3, 2016 | 06:10 AM
lux97Max's Avatar
Worth a try
Old Jun 3, 2016 | 08:13 AM
ShunDoe's Avatar
Originally Posted by lux97Max
Old Jun 3, 2016 | 08:54 AM
rayz336's Avatar
Were there any black plastic pieces in the driver floorboards? If so, there's a plastic nub under the steering wheel that needs to be replaced and it's not much at the dealership. Maybe 5-10 dollars and it just pops into place.
Old Jun 3, 2016 | 10:19 AM
bumpypickle's Avatar
is your speedometer working? If it doesn't work, the cruise control wont work
Old Jun 3, 2016 | 08:09 PM
ShunDoe's Avatar
My speedometer works, but my tachometer goes crazy
Old Jun 3, 2016 | 09:38 PM
DennisMik's Avatar
This is probably the most likely cause.
The only thing is - the plastic "nub" is on the brake pedal, not the steering column. It operates a switch that cancels the cruise control when you step on the brake pedal.
Old Jun 3, 2016 | 09:59 PM
Fakie J Farkerton's Avatar
This is probably the most likely cause. The only thing is - the plastic "nub" is on the brake pedal, not the steering column. It operates a switch that cancels the cruise control when you step on the brake pedal.
Is this another potential penny fix situation?
Same type of fix for when the brake lights act up/stay on?
Penny fix is affordable.
Old Jun 4, 2016 | 11:17 AM
DennisMik's Avatar
Yes.
Mattman998
May 28, 2016 08:49 AM
JoeyChrome
22
May 27, 2016 12:46 AM
Tyler199580
May 21, 2016 02:12 PM
ONE BAD Maxima
May 15, 2016 01:40 PM
barristan
May 7, 2016 07:53 PM
