Antitheft
Old 07-16-2018, 05:38 AM
Foothillsconst's Avatar
Antitheft
Girlfriend had front end collision and triggered Anti theft. Followed fsm and power to 3 on relay then none to starter signal wire. 98 gxe
Foothillsconst is offline
Old 07-16-2018, 10:21 PM
DennisMik's Avatar
Your description is not very clear. 3 on what relay?
But if the alarm (anti-theft) is triggered, you need to fix that, not the starter.
More info would be very helpful.
DennisMik is offline
Old 07-17-2018, 12:51 AM
Violator's Avatar
NATS disables the fuel injectors but the car should still crank shouldn't have any effect on the starter
Violator is offline
Old 07-18-2018, 11:12 AM
DennisMik's Avatar
op's car is a 98. It doesn't have NATS.
Old 07-18-2018, 11:22 AM
Violator's Avatar
Well Dennis I know it's been 7 years but you did write this
If I read the wiring diagram correctly, remove the theft warning relay and put a jumper in across pins 3 and 4. The THEFT WARNING relay is by the power steering reservoir on the right side of the car. The cover over the relays is labeled as to which relay is which. The cover is labeled ANTI-THEFT.
This will allow the starter to crank the engine IF the alarm system is the cause. I'm pretty sure that the security led in with the clock will be on If the alarm system is the cause.
My car has a manufacturing date of 98 and it had NATs, easiest way to tell is looking to see if your key has the chip.
Violator is offline
wisti
09-04-2012 06:38 AM
cspangg
01-30-2009 09:58 AM
Coochie Coach
07-11-2007 11:47 AM
djballen
01-03-2005 05:12 AM
Quick Reply: Antitheft
