97 Nissan Maxima4th gen car stalls and stumbles at times. Crankshaft position sensor?
Old Aug 31, 2019 | 10:05 AM
ahogue8041's Avatar
How many crankshaft position sensors are there on it? I bought a crank shaft position sensor but I’m not sure if I got the right one. The one I found under the car doesn’t look like the one I bought. Will it work for it if it doesn’t look the same?
Old Aug 31, 2019 | 10:07 AM
Fakie J Farkerton's Avatar
There's two
One between the transmission and engine facing the front of the car and the other is under the crank pulley
Old Aug 31, 2019 | 10:13 AM
ahogue8041's Avatar
Originally Posted by Fakie J Farkerton
There's two
Is there anyway to know witch one to replace?
Old Sep 1, 2019 | 03:38 AM
max ride 41's Avatar
the lower one tends to get covered in oil over time and need to be cleaned off, where as my upper one i tried replacing with an aftermarket sensor and the car wouldn't even start, so i put the original ( 24 y/o ) sensor back on and she started. car wouldn't run with the aftermarket sensor.
Old Sep 1, 2019 | 10:24 AM
JvG's Avatar
JvG
1. Buy a code reader or cheap scanner.
2. Use it to read the codes.
3. Look up the codes on the Internet to see which part to buy, and where it lives.
4. Perhaps there is a you tube video or something.
This is how most of us do this. Investigate on your own. Do some research, take some risks.
Us old timers had no code reader, no codes to read, no computer. We fixed our cars based on symtoms and basic measurements. Also a sound understanding of why cars work.
Old Sep 1, 2019 | 05:50 PM
Shrout1's Avatar
My crank sensor slowly failed, causing stumbling, loss of power etc. until the car finally refused to start (no spark). It never threw a code.
Old Sep 21, 2019 | 08:13 PM
maxprivate's Avatar
Black Lion
Check your crank sensor by the pulley, theres a common issue where the wire going to the ecu can become brittle and cause intermittent starting issues or no spark. I had the same problem with no spark on my 97. What i did was, ran a new wire from the sensor to the ecu. theres a service bulletin on what to do to test your wire, basically checking continuity. Search for the bulletin and test it before replacing the crank sensor.
mechanicaljoint
Mar 29, 2005 04:28 AM
JeEvE
Nov 16, 2003 02:10 PM
vinny1978
May 5, 2003 06:17 PM
Soon2BMaxed
Feb 2, 2003 10:02 PM
DanIAm
Nov 7, 2002 06:20 PM
