Soft brake pedal after rear caliper change
Old Oct 16, 2024 | 05:48 PM
RITE's Avatar
Hi, this was my first time changing a caliper. I followed this video:
After waiting for the air to drip out of the bleeder valve for 20 minutes, I followed up with getting 2nd person to do a few pumps until I saw no more air coming out of the bleeder valve. I made sure to refill the brake fluid reservoir so it never even got down to half full.
After test driving a half mile, on the way back the pedal got soft. Pumping the pedal doesn't help it.
What should I do? Does this mean there is still some air inside the caliper that I need to bleed out?
Old Oct 17, 2024 | 02:45 AM
Rit's Avatar
Rit
Yep, still ait in the line. Try bleeding all 4 brake lines, in the correct order. BTW, air will not "drip" out of the brake line.
Old Oct 17, 2024 | 02:55 AM
Turbobink's Avatar
Old Oct 17, 2024 | 04:24 PM
RITE's Avatar
Thank you guys.
Today I tried just bleeding that same rear right brake, but no luck, pedal still soft when I turn on engine. So I will do that one over again, as well as the other 3 wheels.
Is it OK to do 2 wheels one day (rear right + left front), and the other two wheels the next day? I won't start the car, just physically difficult to do all 4 in one day.
And how many times should I open and close the bleeder valve? Would 10 reps be good enough?
Old Oct 18, 2024 | 02:53 AM
Rit's Avatar
Rit
Sure.
Old Oct 18, 2024 | 04:34 AM
Turbobink's Avatar
I’d recommend that you get yourself one of these.
It makes things a bit quicker and you’re able to complete the bleeding process in one-fell-swoop.
Old Oct 19, 2024 | 03:11 PM
RITE's Avatar
@Rit @Turbobink Thank you again guys, I think the job was a success. First time bleeding the brakes for me, I followed that FSM guide. Did all 4 wheels, brakes work fine like they used to so far.
erictown
Jul 26, 2013 10:46 AM
Maximeltman
Mar 16, 2010 09:26 AM
1993-VG30E-GXE
Apr 22, 2009 07:23 PM
aznstormin
May 27, 2006 07:02 AM
97BLUEMAX
Sep 25, 2003 06:54 PM
