Question ?? I got a little project in mind ......
Old Feb 14, 2002 | 03:21 PM
Conrad283's Avatar
I need a truck
I was wondering if anyone knew if the 95-96 tail lights would fit 97-99 and vice versa. Are they a different size or the same?
Old Feb 14, 2002 | 03:26 PM
97BlackMax's Avatar
Re: Question ?? I got a little project in mind ......
i'm not too sure but i think this mighta been talked about, so you could try searching...but i think in order for this to happen, some rear end modding would need to happen
Old Feb 14, 2002 | 03:46 PM
mzmtg's Avatar
Minister of Silly Walks
They are just different enough to require sheet metal to be cut...
Old Feb 14, 2002 | 04:25 PM
Conrad283's Avatar
I need a truck
where would this sheet of metal go if you know
Old Feb 14, 2002 | 08:29 PM
Nealoc187's Avatar
SLOW
He is saying you have to cut up your car to make them fit. Look at them, they are plainly NOT the same shape.
Old Feb 14, 2002 | 09:30 PM
Ramius83
The outers are the same, the inners will NOT fit, unless if you follow MZMTG's helpful advice and do some custom work....
Old Feb 15, 2002 | 05:47 AM
Dreizehn's Avatar
Get a 97-99 lid, then the inner ones will fit.
Old Feb 15, 2002 | 06:19 AM
dwapenyi's Avatar
I once saw a 97-99 Max with a 95-96 trunk lid, which also had the 95/96 tails. Or was it the other way around?? Confused the hell out of me when I saw it. Everything fit perfectly. I wanted to take a picture but had no camera.
So, like the others said, the lights only fit the years they were made with. Gotta do metal bending if you're going to make them fit.
DW
Mar 12, 2020 12:06 AM
chisam14
Nov 6, 2018 08:56 PM
Forge277
Jun 13, 2016 09:26 PM
Unclejunebug
Apr 2, 2016 05:42 AM
pears
Sep 18, 2015 05:25 AM
