THE NEW Let's sue nissan for our 15hp thread
Originally posted by Larry
Take a look at my dyno. Assuming 15% drive train loss I didn't get the torque I paid for.
http://www.mustangmods.com/publish/8...ockmaxdyno.jpg
Only after I removed my air filter. And still didn't get the hp I paid for.
Originally posted by johnvt1111
very good dyno, send the to steve by email (DMB) And as for the previous question about suing for giving us too much torque? Are you serious or is that a smart *** comment? Because it seems that the only thing they were correct on was calculating the torque, and in some cases it's low as well.......
Here's an example of how Dodge has rated their 5.9 engine. This is not an effort to promote Dodge trucks by any means but only as reference as to how their engine is rated verses our 2K2 Maxima's.
This is a dyno of my automatic 5.9 2001 Dodge Ram with 265 miles back on 02/07/01. This engine is factory rated at 245 hp and 335 pounds of torque.
Drive train losses calculate 16.9% for hp and 14.8% for torque based on their rated values. Keep in mind this truck has a big differential and a heavy duty transmission. Surely more drive train loss would be expect on this big truck verses our little Maxima's drive train.
http://www.mustangmods.com/publish/8850//ramdyno1.jpg
Dyno 001 is with the engine completely stock. Run 005 is with an underdrive crank pulley installed. Not to change the point of my post but pretty good gains on that engine with just a crank pulley through out the rpm range. Particularly that 17.3 pounds of torque.
I got the power I paid for with this Dodge. I did not with my Maxima!
disatisfied with my maixima
I have a 6 speed 2003 with 4500 miles, I love the power I have, but if there is a lie about the HP rating, I'll be demanding something, maybe for Nissan to buy my car back, it's a breach of contract, I bought a car that was supposed to have 255bhp. The interior rattles uncontrolably, I was looking at a 330ci w/5 speed, but bought into the maxima because of all the power...just ticks me off, I'll take mine to a dino...let me know what I can do to help the lawsuit. French people suck...Maybe I'll buy a Lexus or a BMW next time.
Well...
Granted I've only had my car for 9,000. miles with or without the extra 15 horses I still Luv my Max! I'm extremly happy with my vehicle. However, I do think that if we're promissed 255 hp, that we should atleast get that much and no more less. Please let me know if there's anything that I can do to contribute...
Max Rocks!
Max Rocks!
Re: Re: Question
The most drive trail loss we should see is approximately 18%. Anyone with a car making less than 209.1 fwhp should expect Nissan to make what ever modification required to give the engine the avertised hp. If your engine dynoes 209.1 then no we wouldn't expect Nissan to fix what isn't broke. We just want the hp that we paid for. Mine dynoed 194.1 hp with 93 octane fuel. I feel I've been cheated by 15 hp. If your car dynoes 209.1 hp then you got what you paid.
If for example your rotor warps you wouldn't expect Nissan to replace rotors on all cars. Only the ones that are defective. Same with our hp numbers. Only if you car is not making the advertised hp should we expect Nissan to fix it.
I feel that if they advertise 255HP, that is what should be comming off the wheels, not around 203. Do you Agree? Why are you asking Nissan for only 15 HP, when they boast of 255 HP. What can I do to help the cause? Personally, I'm ****ed that they made such a claim and not live up to it.
Larry
g35 280 vs 350z 287
has to be another marketing ploy...who would by the Z if it didn't have more power than the UNDENIABLY better looking G35? But proving 7 hp would be tough for 350Z owners...not as tough for us to prove 15hp...
You talk mostly of 2k2 maxima's...what about my 2k3? Isn't it the same altima engine as in your 2k2?
I posted some of this response in another thread about the power loss/rating differnce and thought others might like an opportunity to read it. I'd like to add that motorcycle manufacturers have a similar bad habit of rating the bikes really high using crank numbers. When the bikes get on the dyno, it is usually another story. For example, the Yamaha R6 is a 599cc sportbike with a manufacturer-claimed output of over 200hp/liter (~120hp) but it dynos in the 95-97hp range at the rear wheel. That translates into a drivetrain loss of ~20%; an unthinkable number given the relatively light and mechanically simple drivetrain of a high performance sportbike capable of speeds in excess of 150mph. It's stable-mate, the 998cc R1 is rated by the manufacturer as making 152hp at the crank but makes 137hp at the wheel which translates into a less than 10% drivetrain loss. If the R6 had losses similar to the R1 it would dyno at 107-108 at the rear wheel based on the manufacturers rating. Looking at those numbers, it seems that Yamaha is lying about one of the bikes. Anyway, the car/bike manufacturers lie/inflate/spin-doctor the numbers that will sell motor vehicles as they will. Below is the re-post:
What were the local environmental conditions at the time of the test or the correction factor used to determine the results of the test for the magazine article comparison posted above? And how do they compare to the environment/correction factor of the .ORG members who've posted their results? If the magazine was testing in the cool morning period with a high-speed fans (to reduce the effects of the engine heat in the testing bay) and high octane race fuel in the Max and/or testing the Altima in the mid-day with a lesser grade of fuel (regular premium or worse), that might account for the difference. There are so many variables that can affect power output in high-strung/close tolerance motors like the VQ.
Also, looking at the dyno, it appears that the hp difference is in the upper reaches of the power band which is indicative of airflow differences whether in or out. In addition, the torque is higher throughout the range despite the similar displacement and engine configuration. Not to be naive but, it could be easily explained by the variable capacity muffler and obvious engine variances (although they are supposed to be really close/tight). For example the Honda 954, Suzuki GSXR 1000, and Yamaha R1 all use valves in the exhaust pipes to boost low and mid-range torque by increasing backpressure while also increasing top-end power by reducing the restriction at higher RPMs. When a lot of folks modify the bikes by putting less restrictive exhaust systems on the bikes, the bikes actually make less power until the fuel mixture is enriched. Even then, the mid-range torque value is typically not as flat or wide as the stock numbers.
Again, if I'm missing some power that Nissan promised, I want it back. I'm just offering a motorsports comparison.
I've been reading this topic since the beginning. I personally feel lied to and cheated out of hard earned money. Don't get me wrong. I love the Max and have had no problems with it(except for all the paint chips). Just the fact that I didn't get what Nissan advertised. Has anyone posted on the willingness to have their motor pulled for a engine dyno? I know there are a few guys on here that could live without there Max for a few days. Why don't we get a volunteer to do this and the maxima.org members pay to have it done. I'm sure there are plenty of .org members along with myself that would paypal $5-$10 for the cause. Just a thought, what does everyone else think?
Craig
Craig
Craig
Craig
Originally posted by 95bluse
Are you guys sure this 15hp thing wasn't started up by the dyno shops to generate some cash? Seems like an awful lot of dyno'ing for an iffy lawsuit.
This lawsuit is not iffy it is legit.
people have posted to this love there max's but, I agree if they are
cheating us they should pony up. My car is an automatic unfortunately I think my wife would kill me if I said I wanted to get a dyno done on it. If there is anything else I could do to help let me know.
Good Luck.
Originally posted by clarkm3
I have a 2k2 with 20k on it and I love it. I like many of the
Good Luck.
Good Luck.
A dyno is not going to hurt your transmission or engine. These cars were designed to take them to the revlimiter without damaging the engine or transmission. If it breaks on the dyno it is a good inidcation you had an underlying problem and the dyno discovrered it. If that is the case then use your warranty before it goes out.
I'm not sure about the comparison between the models, but *as far as I know* (which could be wrong, but it is what I have heard from various sources) there is no standard on how the car manufacturers test the HP. So is that crank HP with the AC compressor installed? alternator? engine with NO accessories? If they tested the engine with nothing on it, then it will seem like a bigger difference because you will have to add the parasitic losses in with the drivetrain loss. In which case their numbers may be correct.
But if you guys are right and the loss should be around 15%, then this probably goes back a long time with Nissan. The 3rd gen VG auto maximas dynoed between 106-115 stock which is over 30% loss. The 4th and 5th gens were also around 18%, from the dynos I've seen at our maxima meets. The sentra spec v is also around 18%. I hope you guys are right though, cause I've got a 3rd gen and a spec v and would love a precedent to get something back.
These say it all about Nissan "Modest" Power claims.
Edmund's Review
"...About the only car that can match up to the Maxima is — uh-oh — the Altima. A five-speed Altima 3.5 SE we tested had identical acceleration numbers — a 6.3-second 0-to-60 and a 14.9-second quarter-mile. Both cars weigh about 3,225 pounds, so where the Maxima's horsepower and transmission advantages went to we have no idea..."
"Infiniti has fended off criticism over its claim that its flagship Q45 sedan can accelerate from 0 to 60 mph in 5.9 seconds. Automotive media and industry consultants who have tested the 340-horsepower Q45 have consistently failed to break the 6-second barrier....
Nissan officials have staunchly defended their acceleration figures for the Q45."
"Nissan has also backpedaled on its widely publicized claim that its new 3.5-liter V6, destined for the 2002 Nissan Maxima and Infiniti I35, would deliver 260 horsepower"
"Fudging horsepower ratings might be tempting for automakers. But the practice can also damage reputations and cost automakers a bundle. "
-Motorway
"The more modest power claims for the new engines aren't related to the Q45 controversy..."
"The engine power ratings were preliminary figures, engineering targets that the company couldn't quite match in production"
-Kurt Von Zumwalt, director of Nissan product public relations
Edmund's Review
-Motorway
Originally posted by Eleebob7
Anyone realize that all they needed was ONE maxima that would push 255 HP and they could say that that's the output of it...
I mean... i wouldn't dyno just for this but i do wish u guys luck w/ ur case
sue for defective shifter
we should also sue nissan for a defective shifter.
This site is soooo FUNNY.
http://www.hermes-press.com/nazification_step3.htm
This site is soooo FUNNY. TOTALLY UNRELATED
Pal if that was the case.....every company would throw a supercharger into the car and then sell the car N/A, you have to do many tests on cars before you sell them and on more than one....please don't post if you are uninformed
On a sidenote:
Anyone know cheap Dyno place near SD? I got stock that can add another to it
Very true... Sorry for being Misinformed...
On a sidenote:
On a sidenote:
hmmm...
i do see a possibility in us getting something out of a class action lawsuit...
i got notice of class action settlement from Cingular wireless.
this is related somewhat but anyhow, the plaintiffs, us consumers, is awaiting, pending out-of-court settlement, several optional reimbursement alternatives in a case regarding nokia cell phones (5190 and 6190 models). The claim was against Pacific Bell Wireless (now known as Cingular) in regards to the phones being capable of holding, guess what?....
.... 255 names and telephone numbers... that's right, ye old magic number that we were stripped of in our 2k2+ maximas... yet because of those stupid SIM cards (a computer chip) installed in the cell phones to get Cingular (then PacBell) Wireless service, those phones were limited to storing only 80 names and numbers. That's like a 319% drop in analagous performance.
some people just post stupid s%^t, if it was started by a dyno shop, it would have to be ALL the dyno shops, because people are getting the same losses EVERYWHERE, plus most cars that go to a dyno and get the loss from the flywheel to the wheels nowhere near the loss of h/p we are getting if the 2k2 does have 255 horses
and got 197 FWHP, and 206 Torque to the wheels.
I have a 2k2 Automatic with 255 err 240hp!?!?!
I dont want to believe these numbers so, i'll dyno again.
