Blown MAF with Frankencar+Monster Flow filter
My MAF sensor finally gave way today unexpectedly. I’ve had the Frakencar intake (which is a great product) with a Monster Flow air filter installed on my car for about 10 months or 9K miles. I’ve never experienced a problem with the intake or sensor until today. The worst part about this whole ordeal is that it is going to cost me $500 for a new MAF sensor. The dealer won’t replace it under the existing car warranty however that is another long story, which I don’t feel like recanting.
Apparently the oil or “non-petroleum agent” from the air filter caused the MAF sensor failure. If anyone is using these filters I strongly recommend you check your MAF sensor for any oily build up in the MAF housing. Personally after this experience I will never use another pre-oiled foam filter ever again. If I do decide to reinstall my Frakencar intake I will definitely be using an Apexi filter. However I having doubts as to whether it’s worth risking another blown MAF sensor or not. I sure do love the Frankencar intake though.
Re: Blown MAF with Frankencar+Monster Flow filter
Re: Re: Blown MAF with Frankencar+Monster Flow filter
Originally posted by Colonel
Dont spend 500 smackers...there is a part number for just the sensor itself and its under a $100
Click here!
Oh by the way the .org saves $$$ with the wealth of knowledge again!!!
Re: Re: Re: Blown MAF with Frankencar+Monster Flow filter
Originally posted by Maximam
That or use alcohol or throttle body cleaner and clean the MAF. Dry it and plug and play. It has worked for several people now.
Click here!
Click here!
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Originally posted by MaximaZero
people with the apexi dry filter have also experienced blown maf sensors.
Welcome to the club....did you want to join? Maf killer crew?
![Embarrassment](https://maxima.org/forums/images/smilies/redface.gif)
Yes my apexi dry filter was used when my 3nd maf blew.....
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Thanks!
Thanks for all the advice. I'll try cleaning out the MAF first and see what happens. I'll keep my fingers crossed.
I did try to purchase just the MAF "sensor" for $100 however I contacted several dealers and was told that this wasn't an option on the 2002 model year. Apparently you can purchase the sensor only for the 2000-2001 model year. For the 2002 and up you have to purchase the entire MAF assembly. Maybe I was misinformed?
Yes...pull it off and clean it first. Be sure to wipe the metal sides down REAL good and blow plenty of air through the "S" part of the flow path. You'll be fine then... ![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
ADMAN
ADMAN
Originally posted by adman
Yes...pull it off and clean it first. Be sure to wipe the metal sides down REAL good and blow plenty of air through the "S" part of the flow path. You'll be fine then...![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
ADMAN
ADMAN
I removed the MAF sensor from the housing and cleaned it as best as I could. I even used emax's instructions in another thread to clean the sensor. I then replaced the sensor reconnected my battery and started the car. My SES light is still on and the car still won't rev past 2500 rpm's. Any other recommendations? My MAF may just be shot all together. Thanks again for your help.
Oh by the way, I suggest you use the pleated rubber pipe connection that comes factory to connect the midpipe to the throttle body. It will isolate the vibrations from the motor getting to the MAF.
Re: Re: Re: Re: Blown MAF with Frankencar+Monster Flow filter
If you have it totally dry I would say maybe it is bad. Did you make sure to get it real clean?
Re: Thanks!
Re: Re: Thanks!
Originally posted by JoesMAX
isnt it funny how only the years with the MAF problems are the years where you have to buy the whole MAF and cant buy just the sensor
nissan service is horrible
Re: Re: Re: Thanks!
YES! It sucks and I'm angry as hell about out. I wish there was something else I could do about it. I was planning on spending that money on a new set of rims and tires. I guess I'll have to wait now.....
Re: Re: Re: Re: Thanks!
even though they can technically blame us for the MAF blowing, it still shouldnt blow from an intake.. you can put an intake on a damn hyundai without blowing it, why should it blow on our cars? not to mention there were no issues prior to 2002.. but you cant argue with nissan, they still wont warranty it. you should have put the stock intake back on before you brought it in, thats what i did when mine went and i had no problems
Re: Re: Re: Re: Re: Re: Thanks!
If you can't rev high, then it sounds like your car is still in limp mode. Leave your battery disconnected longer or step on the brake pedal or something to completely discharge the ECU.![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
ADMAN
ADMAN
Re: Re: Re: Re: Re: Re: Re: Thanks!
It was probably a bad MAF then. If it can't sense the air flow/temperature then it won't rev right. They probably just reprogrammed the ECU becuase the code was old.
As for the intake: That's your call. I'd just make sure it's oil free before I'd use it again. Or, that it has a good filter that does let a lot of crap pass. Otherwise, it will probably destroy the new MAF too.
![got me](https://maxima.org/forums/images/smilies/ne_nau.gif)
Re: Re: Re: Re: Re: Re: Re: Re: Thanks!
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thanks!
Stillen/Dry.![Wink](https://maxima.org/forums/images/smilies/wink.gif)
3-1/2 years now...
Stillen/Dry.
3-1/2 years now...
Stillen uses a K&N filter and it's oiled.
I just had my MAFS go on me, then the replacement went after just 3 days. This sucks.. BTW the replacement went even though I switched to a apexi filter.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thanks!
![bawling](https://maxima.org/forums/images/smilies/bawling.gif)
![EEK!](https://maxima.org/forums/images/smilies/eek.gif)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Thanks!
Yeah, but mine is not...
I was going to get the frankencar intake...
...but after reading about all the MAF nightmares people have had I think I just changed my mind. What the hell is it about the Max that make them not play nice with intakes? I have never heard about this on a car before.
Oh, I agree with putting the car back to stock when you go to the dealer. I would have argued like crazy about them telling you that the MAF was tampered with. "What the hell do you mean? What's a MAF?"![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
How did it get all busted up to begin with? Is that typical on a Frankencar install?
Re: I was going to get the frankencar intake...
As far as the dealer is concerned, I did argue with them at length about the MAF repair. I even told the technician what I thought the problem was when I first took it into the dealer. I actually knew it was the MAF after reading so many testimonials on the forum. I should have just kept my mouth shut all together. He just caught me off guard about the MAF being tampered with and I couldn't come back with a good enough arguement to convince him otherwise. Looking back on everything, I would handeled things very differently. It's an expensive lesson to learn.
![BangHead](https://maxima.org/forums/images/smilies/banghead.gif)
Re: Re: Re: Re: Re: Blown MAF with Frankencar+Monster Flow filter
I cleaned the sensor with K&N Filter cleaner, rinsed it out, then dried it with a heating iron (just like emax did with his). The sensor was really dirty before I cleaned it. Believe me, I cleaned it real good. It was now obvious why it failed on me. It's probably just bad and beyond cleaning/repair.
Re: Re: I was going to get the frankencar intake...
I don’t understand why so many people have problems with this MAF thing:
The MAF on our cars is a heated electro that constantly monitors temperature. It does this by sensing the amount of air it takes to cool the unit. If you put on an aftermarket unit that does not provide enough protection against the elements, like a lot of the CAI units, it will damage your MAF. Likewise, if you put on an overly oiled aftermarket filter, like a lot of the K&N type units, it too will damage your MAF as well.
The stock airbox is designed to only allow AIR to pass through the sensor.
![Roll Eyes (Sarcastic)](https://maxima.org/forums/images/smilies/rolleyes.gif)
i've found them used at junkyards for around $100 for the whole thing AND the junkyard warrantied the part. i got a new one, it blew after 3 days and they sent me another one. www.car-part.com
Re: Re: Re: I was going to get the frankencar intake...
BTW: You can get a new MAF from DaveB for $80.00 +/-
TallTom
50
07-08-2022 09:54 AM
my03maxima
04-29-2020 12:48 AM
06-06-2017 02:01 PM
