Anyone get the start-up whine resolved?
Old Mar 13, 2003 | 10:36 PM
PeterUbers's Avatar
It's still cold here in Chicago and I'm getting the start-up whine at temps as high as 35 degrees F. Anyone's dealer find the problem and fix it??
Old Mar 14, 2003 | 06:25 AM
MaximaMan77's Avatar
Re: Anyone get the start-up whine resolved?
I'm not sure what kind of whine your getting but if it's comming from the passenger side of the engine you may want to try tightening your belts a little and see if that does it.
Old Mar 14, 2003 | 07:10 AM
foodmanry's Avatar
Da Roller Coaster!
Yes, I did. I ended up taking the starter out and relubing it. I have no heard the whine since. It takes about an hour and a half. I posted up a how-to in the how-to section.
Good luck! It's well worth the hour and a half in my opinion.
Old Mar 14, 2003 | 07:11 AM
TimW's Avatar
The silent but deadly Moderator
I was hoping the warmer weather would fix it.. it hasnt time to get greasy
Old Mar 14, 2003 | 07:16 AM
foodmanry's Avatar
Da Roller Coaster!
Yeah you'll notice that when you take it apart the cap on the end is filled with dried grease and A LOT of metal filings. Looked like a defect to me with the assembly of the starter.
Old Mar 14, 2003 | 11:05 PM
PeterUbers's Avatar
Thank you for the replies.. I'll check out yer post.. and if it's too complex for a simpleton like me, i'll take it to mother Nissan.
Old Mar 15, 2003 | 06:36 AM
SkoorbMax's Avatar
Are you referring to the high-pitched grinding sound once the engine is engaged (ie, as the RPM peak), or a sound while you're actually turning the crank with the starter? Mine does the high pitch grind the split second after the engine has started and the RPM peak and does it in the cold only. I guess it's the timing chain tensioner, but I don't see how re-greasing the starter would solve that...?
Old Mar 15, 2003 | 08:10 AM
TimW's Avatar
a rattle would be the chain.. this grinding/whine is caused by the solenoid sticking and not pulling back the gear with the car starts. So for a split second, the engine is driving the starter at about 3x the speed it was intended to spin...
James92SE
142
Jan 2, 2024 09:23 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
followthadollar
Sep 17, 2015 06:31 PM
A32goldylocks
Sep 2, 2015 06:39 AM
