Having some hesitation on a 2000 se
Old May 17, 2003 | 10:44 PM
Bl00SE's Avatar
Not sure what is going on. Wife has been driving the car for over a year (I get it on weekends). There is some hesitation on full throttle. Kind of seems to be cutting out. I have 70k on the car seems to be the plugs but I changed the plugs to Bosch platinum 4's about 6 mos ago. Always keep the air filter changed. Any one else experience this? Or can give any clues?
Old May 18, 2003 | 08:06 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Re: Having some hesitation on a 2000 se
if you have an early build 00 then you could have a failed coil issue. many early 2000 had problems with coils failing and there is a tsb but you are out of warranty but the good news is that they arent that difficult to change yourself. the only other issue i could think of is that 4th gen guys swear by NGK plugs and when they used bosch +2 or +4 they had problems shortly after. i would change the plugs to either NGK coppers ($1.59) or platniums (8.00) and if that doesnt resolve it then get the coils replaced.
Old May 18, 2003 | 12:42 PM
BLKMAX005SPD's Avatar
I HAVE THE SAME PROBLEM...
its only when i give it a lot of gas...my car has problems...
and not its stalls at every stop light...
anyone want to help me out? please
Old May 18, 2003 | 01:29 PM
sloppymax's Avatar
have you replaced the plugs recently or do you have a cel on?
Old May 18, 2003 | 06:15 PM
car only has 47,000 miles on it
whats a "cel"
thanks
Old May 18, 2003 | 06:19 PM
Maximam's Avatar
He means SES light, Service engine soon
Old May 18, 2003 | 07:31 PM
no light is on...
my car is ****ed up
it stalls all the time
Old May 18, 2003 | 08:51 PM
skalberti's Avatar
I live life on the edge
I'm having the same problem. I get detonation knock under hard throttle. Other times it acts like it's running out of power or bogging down, kinda like when you press the brakes and gas at the same time. Spent$265 at Nissan for Mass airflow meter. Was a little better. I guess I'll try the coils next.
Old May 18, 2003 | 09:04 PM
TimW's Avatar
The silent but deadly Moderator
definately coils.. they are more prone to failure than your MAF (pre-02).. after the MAF, its O2 sensors but those will throw a code/SES light
Old May 19, 2003 | 06:37 AM
thanks for the help
Old May 19, 2003 | 07:52 AM
Max_Gator's Avatar
Blkmax005spd -
You may not have a coil problem. If your symptoms are JUST the stalling, then there may be another problem/cure. Your symptoms sound a bit different than skalberti.
There have been two other solutions to the problem that you have.
One, clean the throttle body.
Two, (and this is what solved my problem) have the fuel cut tsb done. My car was stalling at red lights. And I could make it stall if I went full throttle for a couple of secs and then pushed the clutch in, shifted to neutral and braked. (as you would do if a light suddenly turned red).
I believe they adjusted my throttle a bit in connection with the TSB. Hasn't stalled since.
Also, if you've added an aftermarket intake, air getting in behind the MAF could cause a stalling problem as well.
Old May 19, 2003 | 01:39 PM
Well i did clean the TB...its was not dirty...
I have a frankencar intake on
But before i put it on my car stalled a couple times
How do i adjust my throttle....there are two wires
One moer thing...around 3500 rpm's my car really does not excellerate
it just kinda doesn't move...
its really ****ing my off
I had an accord before and i never had problems with it, as i do this my maxima
please help
Old May 19, 2003 | 02:02 PM
Max_Gator's Avatar
please help
You can't adjust the idle manually. It must be done with the computer. I believe that any shop with an OBD II reader can adjust the idle - but I may be wrong.
If you can't accelerate after 3500 rpms, then it is not what I suggested in my earlier post. It is either
1) Air getting in behind the MAF.
2) Bad Coils
3) Bad MAF.
When my MAF died, I couldn't get the car above 3000 rpms and if I let it go below 1000 it would stall. I had to shift in between those two parameters and only give it a little gas. I mean the car was barely driveable and it took me a while to even figure out how to get it to move. It is much harder to drive a stick with a bad MAF than an auto.
Old May 19, 2003 | 02:29 PM
sloppymax's Avatar
please help
like maxgator said you cant adjust the idle with the throttle cable, it must be done with a consult 2 but you can adjust the tension on the throttle cable.
Old May 19, 2003 | 02:55 PM
TimW's Avatar
yeah.. I agree, stalling wasnt really the issue with coils, it was under load that they would start malfunctioning.
Hmmm, stalling? I would change gas stations as a precaution.
Old May 20, 2003 | 05:19 AM
PIONEER's Avatar
So We have 6 Coils in the Car. Do we replace all 6 or is there a way to tell which one is bad?? I just changed my Plugs with Nissan plugs about 1500 miles ago, and It hardly made a difference..
Old May 20, 2003 | 06:01 AM
sloppymax's Avatar
even though they dont throw a cel, i thought you could still use a diagnostic machine to tell which number coil is bad. how many miles did you have on it before you changed and i assume you went with the platniums since you said nissan plugs?
Old May 20, 2003 | 06:16 AM
PIONEER's Avatar
Car has 55K miles on it. Just changed plugs, drove to New York and Back.. no difference to me.... Now get this.. It only does it sometimes. Not all the time. I took my car to the dealer, he put the OBD II on the car, hell all kinds of readings were wrong he said, he said the cats were missing, the Stock airfilter was missing .. I said what you mean I have 2 precats missing .. I have a Y-Pipe but I was like you sure the car didn't come like this But he said the coils were good, and he said based on the readings, It might be the MAF but he had no way to prove that b/c the cats were missing and the facory air filter system was missing. I have a Place Racing CAI.
Old May 20, 2003 | 07:09 AM
Max_Gator's Avatar
Pioneer -
Which problem are you having? Stalling or more than that. If just stalling have you had the fuel cut tsb done?
Old May 20, 2003 | 07:38 AM
PIONEER's Avatar
Originally posted by Max_Gator
Pioneer -
Just when I press the gas, its sounds like it doesn't wanna go and Bogs down, and you hear the chain.. but if you ease off the Gas its allright. but only does it sometimes, not always.
Old May 20, 2003 | 08:53 AM
sloppymax's Avatar
did you gut the precat on the back of the manifold?
Old May 20, 2003 | 08:54 AM
PIONEER's Avatar
My car is Fed Spec, so my Y-Pipe is 1 piece, 2 Pre-Cats.
Old May 20, 2003 | 08:55 AM
Max_Gator's Avatar
I think he's only got two - and both are taken out by the ypipe. 2k fed spec.
Old May 20, 2003 | 01:11 PM
pana69's Avatar
I'm having the stalling problem too, I raised the throtle a bit. I want to see if there's a different way to fix it though. when you guys say to fix THE CUT TSB...what is that? and is it easy/inexpencive to do?
thanks
Old May 20, 2003 | 01:16 PM
Max_Gator's Avatar
thanks
The FUEL CUT TSB is what I'm talking about. It only applies to 2k/2k1s. There is more info than you could ever want on this site about that problem. Essentially, the way the computer was programmed caused drivability problems.
However, several of us have learned that asking the dealer to reflash the ECU with the updated programming solved the stalling problem I described above.
Old May 20, 2003 | 01:50 PM
same same...
i have the same problem but my car stalls too
why can't my car just run right
Old May 20, 2003 | 06:26 PM
Teser's Avatar
I think they do throw a cel. Well, in my case they did, and yes, ODBII code tells you exactly which coil needs replacement.
One suggestion though - try to reset ECU (unplug battery for a few hours), I found that it helps in a lot of situations. Worth a try.
Good luck.
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
Need help
23
Oct 2, 2015 08:56 AM
homewrecker
Sep 24, 2015 07:01 PM
ballerchris510
Sep 11, 2015 05:29 PM
