View Poll Results: CASH-IN-HAND buyers for TechnoSquare ECU
Cali-spec 5spd
26.19%
Cali-spec Auto
26.19%
Fed-spec 5spd
15.48%
Fed-spec Auto
32.14%
Voters: 168. You may not vote on this poll
$$$$$$$$$2K-2K1 Owners with $600 CASH-IN-HAND ready for TechnoSquare ECU?$$$$$$$$$$$$
Old Mar 16, 2004 | 05:52 AM
  #161
purekoryo's Avatar
will this ECU provide 15whp throughout the whole powerband? or peak hp? how much time will take off the 1/4mile time? I just wanted to know an estimate, and to see if its worth it to spend $600 over getting headers.
Old Mar 16, 2004 | 06:09 AM
  #162
HitManSE's Avatar
It will "add" to the curve so to speak. Yeah it should make decent power, as for the 1/4mile no1 has it yet so we dont know. It should knock off about .2-.3 though. A gain in power combined with more RPM's is a nice combo.
Old Mar 16, 2004 | 06:11 AM
  #163
Larrio's Avatar
The Definitive AE Master
too hard to say exact numbers. Thats like asking how much HP will a header put down before it even comes out.
1/4 mile time is affected by so many things such as track conditions, temperature, etc. Lower ETs = good traction, Higher trap speeds = more power. However, the ECU is designed to take advantage our shift points because the extended rev limiter enables us to rev higher to land the next gear higher into the optimal gear range.
also, I imagine that TS will tune fuel maps and advantage timing providing a smoother "under the curve" power
Old Mar 16, 2004 | 07:38 AM
  #164
purekoryo's Avatar
Is there anything else I need to get when I get the ecu upgrade?
Also, since it will rev up to 7100 rpm vs. stock 6700 rpm, won't that quickly mess up the engine?
Old Mar 16, 2004 | 09:04 AM
  #165
Larrio's Avatar
fuel cut and rev limiter are extended. Also, its been discussed that the vq30de piston speed at that rpm are not yet "dangerous"
Old Mar 16, 2004 | 11:17 AM
  #166
frankieduxAE's Avatar
yay i can't wait for the TS ECU upgrade. I got the cold hard cash in my hands.
hopefully everything works out with the testing larrio. love the midpipe by the way, thanks.
Old Mar 16, 2004 | 11:28 AM
  #167
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
5spd or auto?
I need to update my list of buyers, SO EVERYBODY CHIME IN!!!!
Old Mar 16, 2004 | 11:54 AM
  #168
purekoryo's Avatar
I'm in...
I have a 2000 maxima 5 spd CALI.
Would I need anything else along with the ecu?
Also, I may add additional bolt-ons in the future like, udp, test pipe, and b-pipe. Would the ecu still adapt to it?
I currently have GAB/OSCAI and y-pipe.
Old Mar 16, 2004 | 12:33 PM
  #169
IceY2K1's Avatar
I'll add you to the list~!
Any bolt on mods EXCEPT headers/cams/FI of some sort will work fine with the "standard" TS program.
I'm in...
Old Mar 16, 2004 | 02:07 PM
  #170
purekoryo's Avatar
Do you have any updates on the ECU? i.e. dyno charts, possible GD price, how long it would take before we can start purchasing it?
Thanks again!
Old Mar 17, 2004 | 04:53 AM
  #171
purekoryo's Avatar
bump................
Old Mar 17, 2004 | 12:53 PM
  #172
mad2kmax's Avatar
im in...
2000 5sp fed spec
place racing cai, cattman y-pipe, rt hi flow cat, and full cattman catback...
thanks again ice and everyone else for the effort being put into this.
Old Mar 18, 2004 | 11:55 PM
  #173
HNDA ETR's Avatar
Still Here... IM me for more..
Hey Ice,
I'm still in... gonna need a program for my S/C and Headers though...
Old Mar 19, 2004 | 07:10 AM
  #174
IceY2K1's Avatar
Thanks for confirming. I'd like EVERYBODY too, since it's been so long, who knows if they still have a Max.
Anyways, you'll either A)need to drive to TS or B)get someone that's local with similar mods to drive to TS or C)dyno with A/F monitoring and send TS the dyno. It may take a couple trips back and forth, but they'll dial you in.
Originally Posted by HNDA ETR
Hey Ice,
Old Mar 19, 2004 | 01:59 PM
  #175
doublea's Avatar
I'm still in, by the time the TS ECU arrive there might be a little bit of dust on the cash bundle, but who care...
Cheers
AA
Old Apr 16, 2004 | 01:30 PM
  #176
IceY2K1's Avatar
*UPDATE*
My ECU had to go back to Techtom of Japan for a problem our Max and the Murano ECUs had where the flash would get corrupted and stop responding.
Anyways, Techtom fixed the ECU, harness, software, and was able to flash my ECU.
Now we're waiting on it to get back to Techno Square USA and testing can begin.
Old Apr 16, 2004 | 07:20 PM
  #177
Larrio's Avatar
*UPDATE*
YESSSSSSSS!!!!!!!!!!
Old Apr 16, 2004 | 07:36 PM
  #178
JeffesonM's Avatar
living out of a maxima...
damn this is going to get close... I'm about to get down and dirty trying to get a 96 ECU to work in my 99 so I can get a JWT, but if the TS ECU is all it's cracked up to be it might be an easier route
Old Apr 17, 2004 | 06:06 AM
  #179
sighere's Avatar
Ipm still in, what's the timeframe?
Old Apr 17, 2004 | 10:26 AM
  #180
IceY2K1's Avatar
You'll know, when I know.
Old Apr 17, 2004 | 08:49 PM
  #181
phantomax01's Avatar
quick question, as far as the testing is concerned, is technosquare only developing the ecu for a fed spec 5pd?or will their be available for most 3.0's such as cali spec autos, anniversaries, and cali spec 5 spds??
Old Apr 20, 2004 | 08:25 PM
  #182
BlackBIRDVQ's Avatar
drag racing is for wussies
I'm still gonna be down for one as long as gains are worth the wait time and $$$. I have a 2.5" custom mandrell catback, Cattman Ypipe ( HS headers are in the mail) all the cats are no longer there ( cali spec with 3 cats) UDP, Fidanza flywheel, Place Racing CAI, timing advanced on Consult. Car is a Cali spec GXE with no power seats or nothing 5spd 01. I'm pretty good with S-AFCII vs JWT ECU on SR20DETs like my G20 so even the extended redline would help me tune my VQ-K motor. But for 600 bux I wanna see some gains.
Old Apr 20, 2004 | 10:28 PM
  #183
Regime's Avatar
The non-postwhoring Org member
The current line up for test cars is a Cali-spec 5sp then a Cali-spec auto Anniversary (mine). Eventually TS will be doing tunes on all specs for the 00-01 cars.
Old Apr 21, 2004 | 12:24 AM
  #184
Larrio's Avatar
cali spec 5spd AE (mine)
Old Apr 26, 2004 | 10:20 PM
  #185
HNDA ETR's Avatar
stop rubbing it in larry...
Old Apr 27, 2004 | 09:11 AM
  #186
Larrio's Avatar
i'm excited about this. besides, I need at least ONE mod for my car (unlike mr. SC... ahem)
Old Apr 27, 2004 | 11:16 AM
  #187
IceY2K1's Avatar
Did you put your intake on yet?
Old Apr 27, 2004 | 11:29 AM
  #188
IceY2K1's Avatar
JUST SO EVERYBODY KNOWS...
After seeing how the 2K2+ TechnoSquare ECUs responded to an intake and ESPECIALLY the lack there of, I've convinced Danny@TS to allow the test-car, ie Larry, to dyno tune with his POP charger.
So, when you see the dyno results(SOMEDAY~!), you'll know why the baseline and TS ECU both included an intake. It's not TS fault or TS trying to overinflate the gains, so don't jump to conclusions. It's my opinion that pretty much the MAJORITY of people will have AT LEAST an intake and therefore the ECU "standard" program should account for it, so plan on a cone-filter/adapter or similar intake.
Here is an example of what *COULD* happen with the gains a TS ECU made with and withOUT the intake:
http://forums.maxima.org/showthread....0&page=1&pp=30 .
I'd rather have the "standard" program account for the intake from the START, so we don't have to worry about losing performance or getting reprogrammed.
Old Apr 27, 2004 | 01:09 PM
  #189
Larrio's Avatar
i was about to put it on today, but I am missing a screw on the stillen maf adaptor. I will try using one of the stock MAF bolts to see if it works. It will be on by this weekend for sure.
Old Apr 27, 2004 | 02:47 PM
  #190
Tim01MaxSE's Avatar
I got a Cali spec 5spd...i want one of these too....
Old Apr 27, 2004 | 02:56 PM
  #191
IceY2K1's Avatar
I added you to the list.
Make sure you vote, if you haven't already.
Old Apr 27, 2004 | 07:40 PM
  #192
HNDA ETR's Avatar
Who, me?
Old May 6, 2004 | 12:45 PM
  #193
IceY2K1's Avatar
*UPDATE* !!!!!!!!AWESOME NEWS!!!!!!!!! *UPDATE*
Dannys' latest email:
Hey Alex,
Good news, we got our harness back and SUCCESSFULLY Flash your ECU with a modify program. We didn't really know what to change, so we just bump the rev limiter for now, just to see if the program even works. Anyways, it seems to be working normal like the 02 Maximas and 350z, G35s etc.. ..
We're planning on using your ECU to run the test car. We're hoping we won't run into any immobilizer problem, but we won't be able to tell until the car comes in.
Danny.
Old May 6, 2004 | 01:00 PM
  #194
JeffesonM's Avatar
weeeeeee haaaaaa! good news for you guys!
Old May 6, 2004 | 01:11 PM
  #195
doublea's Avatar
I think my hair turn gray since that thread started but that sound like good news. One of the good side is it will give us planty of time to put money on the side until we get our unit next summer. lol
I'm just teasing you, like they say" Rome was not build in one day "
Keep up we want every hp and tq that can be steal.
Cheers
AA
Old May 10, 2004 | 08:23 AM
  #196
IceY2K1's Avatar
Anyone in the Torrance..."Hacienda Heights" area?
Larry needs a ride home TODAY once he drops his car off.
Old May 10, 2004 | 01:31 PM
  #197
Larrio's Avatar
haha... ppl were too busy. I got a ride home already, plz check ur PM for details alex
Old Jun 18, 2004 | 09:47 PM
  #198
are the ECUs a real thing or no ? I'm itching to buy it... would like a boosted program if possible with a TTZ MAF and 555cc injectors.
Old Jun 19, 2004 | 07:48 AM
  #199
Larrio's Avatar
its been real for the past four weeks
Old Jun 25, 2004 | 06:43 AM
  #200
91 EX-R's Avatar
Are or when will they be available??
