View Poll Results: CASH-IN-HAND buyers for TechnoSquare ECU
Cali-spec 5spd
26.19%
Cali-spec Auto
26.19%
Fed-spec 5spd
15.48%
Fed-spec Auto
32.14%
Voters: 168. You may not vote on this poll
$$$$$$$$$2K-2K1 Owners with $600 CASH-IN-HAND ready for TechnoSquare ECU?$$$$$$$$$$$$
Old Nov 8, 2004 | 09:24 AM
  #281
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Larry got his ECU back and I'm waiting on Tadashis' response on when you should bring your car in for reflashing.
Hopefully, you're still up for it.
Originally Posted by Regime
Larrio means that the test ECU that TS has made, was made based on his AE 5sp. He currently is running the test ECU from TS.
The Auto one, If it is ever made, will be based on my AE auto ECU.
Old Nov 8, 2004 | 09:28 AM
  #282
IceY2K1's Avatar
mad2kmax - Honestly, I doubt it will happen *UNLESS* we can convince TS that the R&D is worthwhile by LOTS of 2001 5spd and autos purchasing their reflash.
Originally Posted by mad2kmax
OK Ice,
I hate to ask again, because I think I already know the answer, but do you think that there is the SLIGHTEST possibility of TS making a 2000 fed spec 5spd ecu? I know that I represent the smallest portion of those polled, therefore of least importance, but I would like to know if I should just go ahead and give up hope or not. Thanks again to everyone who has put forth so much effort on this project.
Old Nov 8, 2004 | 09:33 AM
  #283
SR20DEN's Avatar
VQ Wizard
So you ***** are getting all the Service Packs included.
windowsupdate.microsoft.com
Old Nov 8, 2004 | 10:36 AM
  #284
IceY2K1's Avatar
I wouldn't say "all", but I'm *PRAYING* for a better fix to the "fuel-cut" TSB.
Old Nov 8, 2004 | 10:48 AM
  #285
Regime's Avatar
The non-postwhoring Org member
Indeed. God I hope MS didn't program our ECU's. We don't need that kind of bloat in the coding. Though it would explain some things about the LAG in the TCM
BTW ICE, Just a reminder, because of the other ECU "incident", I now have the newest (my original one was one of the first gen because my car was built so early) AE Auto flash as well. So I am going to assume Tadashis will want to send mine out (again) to get the newest updates as well. I know we talked about this before, but alot of time/other things have happened in the meantime so you may have forgotten.
Old Nov 8, 2004 | 10:58 AM
  #286
IceY2K1's Avatar
Yes, I did forget.
Check your email, so we can figure this one out.
Old Nov 8, 2004 | 11:23 AM
  #287
NisMo-Max's Avatar
Larrio, did you dyno the car after reflashing your ecu to the AE Ecu??? If so, did you See differences, and also did it only expand the speed limiter????
Old Nov 8, 2004 | 11:47 AM
  #288
Larrio's Avatar
The Definitive AE Master
advanced timing, tuned fuel maps, raised rev limiter.
my stock AE ecu before the TS reflash has the highest version of ECU software nissan offers (4Y916- most tsbs and bugs worked out). Nissan only offers up to 4Y915 for non-dealer downloads and icey2k1's spare ecu originally had 4Y913
i have the y-pipe on now. Just waiting for the b-pipe and i'll go and dyno
Old Nov 8, 2004 | 11:58 AM
  #289
IceY2K1's Avatar
Larry,
Does your OBD scanner show 23710-4Y916 as the part number?
my stock AE ecu before the TS reflash has the highest version of ECU software nissan offers (4py16- most tsbs and bugs worked out). Nissan only offers up to 4py15 for non-dealer downloads and icey2k1's spare ecu originally had 4py13
Old Nov 8, 2004 | 12:26 PM
  #290
Larrio's Avatar
no. The scanner I have plugs into my labtop, it doesn't list part #'s. I saw those versions on the computer at TS when both our ECUs were plugged in and getting reflashed.
they found out mine was ver.16 so they went to some nissan-tech site, but it only offered up to ver.15. Thats why my ECU got sent back to japan to crack
Old Nov 8, 2004 | 12:33 PM
  #291
IceY2K1's Avatar
Yes, I remember Danny telling me your latest cat efficiency TSB reflash bumped you up to xx916, which is WHY your ECU was sent to Techtom also. If you look where TS gets their updates from it only has up to xx915: http://www.nissan-techinfo.com/nissan/ecm.asp?
Which OBD scanner do you have?
Alex
Old Nov 8, 2004 | 12:36 PM
  #292
NisMo-Max's Avatar
I just spoke to Technosquare, and they said they are still working on the Ts Ecu For the 2001 maxis and they said it Maybe released by Mid December!!!!!!
Old Nov 8, 2004 | 12:47 PM
  #293
IceY2K1's Avatar
I was ASKED for you guys NOT to do that.
Why you guys think it's necessary to talk with TS, I don't know.
ALL the pertinent info is here and we are working on it as planned, just slowly.
***PLEASE*** keep your $$$$ ready, so that WHEN Tadashi tells *ME* that it is ready for sale, I will have you guy lined up to send in your ECUs without chaos/mixups/confusion.***PLEASE**
Old Nov 8, 2004 | 12:48 PM
  #294
Larrio's Avatar
Alex
www.autoenginuity.com scantool. And yes, thats the site where they tried to find my ECU version. Version xx915 (which I believe was on your ECU) still threw the P0420 code. It started at every month, then every few weeks, and then finally every day
nismo-max: they probably want to work out all bugs and minor tweaks before releasing it into public
Old Nov 8, 2004 | 12:58 PM
  #295
nailz420's Avatar
If you can manually enter commands through a terminal emulation console, enter 0904, like this:
LM323 v2.0
>0904
And it should give you a bunch data, like this:
BUS INIT: ...OK
49 04 01 31 32 59 39
49 04 02 31 38 00 00
49 04 03 00 00 00 00
49 04 04 00 00 00 00
49 04 05 56 58 32 33
49 04 06 35 47 00 00
49 04 07 00 00 00 00
49 04 08 00 00 00 00
this data contains your calibration id decoded from hex to ascii, like this:
12Y918VX235G
2Y918 is the important part.
Old Nov 8, 2004 | 01:33 PM
  #296
MyownNismo's Avatar
Future Camaro SS owner
But is there any hope for us 2000 owners. Cause I plan to keep auto but I will have 2k1 AE auto but don't according to DaveB I don't need to swap any electronics for it to work.
Old Nov 8, 2004 | 01:55 PM
  #297
Kevlo911's Avatar
Kevlo for President
You will prob get an EGR code, since 00fed and 00cali/01 have different EGR systems.
Old Nov 8, 2004 | 01:58 PM
  #298
Larrio's Avatar
speculation is that 2000 ECUs are too close to 98-99 ECUs. Also, 2000s supposedly run EGR whereas the 2001s don't. They are minute differences that add up.
Old Nov 8, 2004 | 02:10 PM
  #299
MyownNismo's Avatar
Doesn't matter to me if I don't get the ECU. I will just find other ways to be fast. Over winter once the car is stored the intake manifold comes off and taken to a machine shop to see if they can make a better one.
Old Nov 9, 2004 | 03:50 PM
  #300
Kevlo911's Avatar
Kevlo for President
I highly dout they are close to hte 98-99. But either way, if the wireing harness is the same, the ecu should work. Just like 95-96 ecu in a 97-98(soon99).
Old Nov 12, 2004 | 09:38 AM
  #301
IceY2K1's Avatar
Here is WHY 1999s and 2000s are out-of-luck....
Courtesy of Tadashi@TechnoSquare:
He says the 2001s lucked out because they use the same CPU found in the 350Z. The 2000 uses TWO unique CPUs, which are different from both the 1999 and 2001. He doesn't feel it's worth the R&D to develop a unique flash programmer just for the 2000s.
Hopefully, 2001s buy the crap out of these things as soon as they're released to maybe help convince him that 2000s are worthwhile.
Old Nov 12, 2004 | 09:47 AM
  #302
Progress's Avatar
It's business time.
It's as if Nissan made the Maxima so their could be no aftemarket development. No nismo products, changing the ECU every 6 months, etc.!
I'm sorry, it just makes me upset that it would take so long and so much man power to crack it only to find out a significant amount of them still aren't cracked.
Old Nov 12, 2004 | 09:52 AM
  #303
IceY2K1's Avatar
BTW, that 2000 is an early production Cali spec auto ECU w/o TCS.
If anyone opens up their 2000 ECU, please let me know if it looks different.
Maybe a later 2000 ECU is similar to the 2001s and can use the same programmer, maybe the 2001 Cali ECU will work in a 2000 Cali car, maybe not.
I'm pretty sure 2000 Fed specs are screwed.
Old Nov 12, 2004 | 10:09 AM
  #304
Regime's Avatar
WoW, everytime I read a new post by ICE I am amazed at the amount of research, thought, thoroughness and work he has put into this project. I just want to say that EVERYONE on this thread should thank ICE. And just because unfortunatly it hasn't worked out for everyone, or has been completed yet, does not take away from the fact that there are very few people on this board that are willing to give even a 1/10th the commitment that ICE has.
Anyway good job Alex and keep it up.
Old Nov 12, 2004 | 11:14 AM
  #305
IceY2K1's Avatar
Thanks..but YOU and Larrio are the man, not me.
Yeah I'm out a little money, but you were without your Max for ~2-months while driving your track SER as your temp daily driver, warranty issues, and Larry was without his Max for a week begging rides, completed several trips to TechnoSquare to do several dyno tunes, and even paid for his own dyno runs to help trouble-shoot his VIAS problem. And you're not even done yet.
Anyways, without you two suckers...er...guinea-pigs...er...volunteers, none of this would have been possible. I live in AZ and TechnoSquare is in Cali, so without local members such as you two willing to STEP UP, this lucky break for at least 2001s wouldn't have happened no matter WHAT I did on my end.
Again, thanks Larry and Daniel for putting up with my nagging and volumes of email banter. I hope you guys know how much respect/appreciation I have for you guys. Hopefully, this pans out soon and I hope it's worth all the BS you've gone through in the end.
Old Nov 12, 2004 | 11:38 AM
  #306
Progress's Avatar
It's business time.
I'm sorry, I didn't mean to come across as ungrateful or anything, I understand a lot of hard work and time must go into this. Good luck with this guys, I hope it all works up to/beyond expectations.
Old Nov 12, 2004 | 11:47 AM
  #307
Regime's Avatar
Nah, that wasn't it at all. This was not in response to anyone's posts negative or otherwise, just an aside from me. Because I think Alex deserves a bit of thanks for all his work (even if he wants to be modest about it).
On another note...looky-looky 300 posts, Took me long enough. haha
Old Nov 12, 2004 | 01:22 PM
  #308
BlackBIRDVQ's Avatar
drag racing is for wussies
Cool deal thanx to you guys, when will we be able to get the ECU reprogrammed ? My car is going into storage soon so I could send out the ECU for a full program. I have headers, no cats at all, catback, flywheel, UDP, PR CAI for power mods along with S-AFCII and wideband to tune my car up. Think all the mods are going to make some power with the ECU ? Seeing how they can't get a ECU right on a 3.5L with headers, will this pose an issue with the 3.0Ls ?
Old Nov 12, 2004 | 01:32 PM
  #309
IceY2K1's Avatar
VQ35 ECUs have that CVTC stuff that I don't think TS/JWT or anyone else besides NISMO has figured out yet.
The VQ30s don't have that problem, but until we get some baseline dynos, I'm not going to promise any gains other then a raised rev-limiter and better AFR.
Old Nov 13, 2004 | 01:54 AM
  #310
NisMo-Max's Avatar
Thanks Ice, Larrio, and Regime! I have learned so much from you guys, and thanks again for your time and commitment helping to produce the Ts Ecu. And am Happy to have you guys as a Moderator...... Hands to u Guys!!!!!!!
Old Jan 22, 2005 | 05:45 PM
  #311
MadMaxima99's Avatar
Still no headway on the elusive programmin for the 99 5speed fed maxi's?
Old Jan 22, 2005 | 08:04 PM
  #312
SR20DEN's Avatar
VQ Wizard
I think it's safe to say that will never happen.
Old Jan 22, 2005 | 09:24 PM
  #313
Larrio's Avatar
umm... post #301 (first one on this page) shows why that will not happen
Old Jan 23, 2005 | 09:19 AM
  #314
MyownNismo's Avatar
This is probably stated in this somewhere but can I put the 01 ecu in my 00. I know I would have to find way around the EGR. Could it be possible.
Old Jan 23, 2005 | 10:15 AM
  #315
SR20DEN's Avatar
VQ Wizard
Yes it is possible and I will be working on this as soon as a local gets his hands on a '01 ECU.
Why is everyone so concerned about the stupid EGR? The '01 ECU does not give a rats behind about the EGR on the '00 manifold. It is irrelevant.
Old Jan 23, 2005 | 10:30 AM
  #316
MyownNismo's Avatar
I can get four for my 00 auto.
Old Jan 23, 2005 | 11:45 AM
  #317
2kGLE's Avatar
That was my plan until my engine died. If I dont use my spare cali 5spd ECU with my new engine it's up for grabs. I'm still not sure what ECU im gonna use but I will know in a week or two.
Old Jan 23, 2005 | 05:50 PM
  #318
Just need someone to try harder on the 97-99 maxi ECUs, oooooo programmer went out of business, TRY!
Old Jan 24, 2005 | 11:31 AM
  #319
doublea's Avatar
Is there any release date for the 2k1 AE TS ECU ?
Old Jan 24, 2005 | 11:34 AM
  #320
IceY2K1's Avatar
Any day now for the 5spd, just waiting for Tadashi to get back to me.
If I were you guys, I'd wait until I do my stock vs. TS ECU dyno, so you know what you are ACTUALLY buying.
