2000 Auto Transmission problem? <not the usual TSB issue>
Old Oct 27, 2003 | 03:28 PM
nhokt's Avatar
Hello,
So I am leaving work today, I drive out to the main entrance and come to a complete stop to check for cars at the stop sign. I give the car a normal amount of gas and the engine revs for 2 seconds and all the sudden the transmission catches and jerks hard (it felt like a nuetral drop from my youngin' years...). What the hell was that I'm thinking, I stopped again and it did not happen but now I am afraid to merge into city traffic!
A while back I brought my car to the dealer to have them check for the 1-2 Trans slip TSB and they said my car wasn't effected. Could todays issue be a fluke or a telltale sign? Car has only 34k miles.
thanks
Old Oct 27, 2003 | 03:48 PM
MaxSerg's Avatar
It happened to me coulpe times. I slowed down before making a turn, then pushed gas pedal again, car jerked.
Not sure its the same thing though.
Old Oct 27, 2003 | 03:56 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
Originally Posted by nhokt
Hello,
thanks
the best way to test slippage is find a moderate to large hill. start off at the bottom at partial throttle. the revs should climb without the car moving then it should slam forward. some peoples are worse than others but at least have them replace the tranny solenoids so you dont have to worry about reliability from here on out.
Old Oct 27, 2003 | 04:18 PM
Maximam's Avatar
It may have been hunting for gears if between 1st and second gear. If you came to a complete stop, check for low tranny fluid.
Old Oct 27, 2003 | 05:43 PM
E55AMG2's Avatar
Wat
Mine only does that when its cold, and the tranny doesnt have full line pressure
Old Oct 27, 2003 | 07:31 PM
nhokt's Avatar
So do you all think this is normal??? I t seems rather dangerous to me.
Old Oct 27, 2003 | 07:34 PM
sloppymax's Avatar
i allow my car to idle for 30sec to a minute before i drive. before the soleniods it would slip even when warmed up. i had the solenoiods down and it would occasionally do it when it was cold. after the TCM was replaced, i have not experienced any slippage. i also use a tranny cooler and mobil 1 atf to help keep the fluid temp low.
Lakersallday24
Nov 7, 2024 07:31 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
intimidator
Sep 5, 2015 07:23 PM
boomerbrian
Sep 2, 2015 03:46 PM
Gsantos79
Aug 8, 2015 07:41 AM
