Nitrous Triggers.....Locations ?
Old Dec 4, 2003 | 11:07 PM
KLOOGY's Avatar
L33t BMW Drivah
I was wondering where those of you that are squeezing are mounting your triggers for your Nitrous.... I will be squezing the laughing gas soon !
Old Dec 4, 2003 | 11:43 PM
Larrio's Avatar
The Definitive AE Master
put it behind the steering wheel so they poke out and taunt at you.....
easy access too cause you can press down with ur thumbs while gripping the wheel
Old Dec 4, 2003 | 11:49 PM
KLOOGY's Avatar
L33t BMW Drivah
Dude, Im trying to avoid squeezing........I have a lot of re-matches in mind.....one is that C32 that beat me in Fontana ! I will spank him like a red-head step child !
Old Dec 4, 2003 | 11:54 PM
Anuj's Avatar
street racing is badd
how about you do it gone in 60 seconds style...put it in the center console somewhere with a button cover over it (or was it in like a fighter jet postition?)
Old Dec 4, 2003 | 11:57 PM
KLOOGY's Avatar
L33t BMW Drivah
Or like Stallone did in Cobra...flip a cover up and you just hit it !......I cant wait to see ***** see a 4 door sedan with big rims walk them , with the fosgates blasting !.....
Old Dec 5, 2003 | 12:02 AM
Larrio's Avatar
fontana is a track... so no street racing for kloogy ...... for now
Old Dec 5, 2003 | 12:03 AM
Anuj's Avatar
do u have heated seats? if not, there are two spots there that you can use...but it's in an awkward position
if you don't have heated seats, you don't have the meridian package (i hope not since u live in SO CAL) - and there are other spots as well (right next to the side mirrors toggle switch) - this also maybe a little low and awkward
what do you prefer as of now?
Old Dec 5, 2003 | 12:04 AM
KLOOGY's Avatar
L33t BMW Drivah
Larrio....what do you think the redneck announcer will say this time .....when I run with the JUICE ?...
Yes Glen.. I have heated seats..
I need spots for the Trigger, Bottle opener, purge , Heater
I live in So Cal but I wanted ALL OPTIONS including Navi when I bought it ...
Old Dec 5, 2003 | 12:07 AM
Anuj's Avatar
Originally Posted by announcer
here comes that family sedan - in it's last showing it got creamed by a C32
Old Dec 5, 2003 | 12:10 AM
Anuj's Avatar
for the bottle opener, purge, and the heater - maybe you can use the ash tray thing? (the thing right above the shifter) - that way it can be more stealth since you can hide it
Old Dec 5, 2003 | 01:43 AM
Larrio's Avatar
i have the meridian package also and i notice that that is an area on the left side of the steering wheel near the panel, underneath the vent slightly to the right.
i'm fully loaded, but both of my slots are empty
pulled this off from icey2k1's site
Old Dec 5, 2003 | 05:25 AM
SR20DEN's Avatar
VQ Wizard
When I do installs I mount the arming switch in the same place that Larrio did in his pic. The WOT switch goes on the gas pedal. You mount it using the same studs that mounts the pedal. There are a couple of couterweights on the very top of the pedal that can be used to strike the switch.
If you use a Zex kit you can tap one of the white wires on the TPS which is also located on the top of the gas pedal on the DBW systems.
Old Dec 5, 2003 | 06:54 AM
Blu's Avatar
Blu
the tits
whatever you do DON'T use the missle launching switch that comes with the kits
Old Dec 5, 2003 | 06:59 AM
NCTRNL's Avatar
All the nitrous kits for the LS1's have Window switches so that it will all work automatically if the car is at WOT between a certain RPM range because you can really damage the car if you do it at the wrong time. That is the way to go. Fast and Furious ruined everything. If you have nitrous going into the motor and you hit the rev limiter and the car cuts the fuel, you are SCREWED. Let the computer do it all for you. There is an arming switch of course but the actual nitrous activation is all done by computer. If you are looking for a place for the arming switch, wire it in with the rear defroster switch so that the switch only stays on for a few minutes at a time in case you forget to disarm it.
Old Dec 5, 2003 | 07:04 AM
skandalouz's Avatar
wow... never thought of that.... good idea.....
Old Dec 5, 2003 | 08:59 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
giovanni u biznatch, dont worry, ill find you a spot
the ones with the kit are f*cking huge, haha
i wanted to do this when the kit was on my car, but if someone knows the wiring schematics of the volume control on the 2k2, we can use that button to squeeze.
Old Dec 5, 2003 | 09:21 PM
SR20DEN's Avatar
VQ Wizard
I have explained this scenario at least a dozen times in this place and most times no one listens or pays attention anyway.
Old Dec 5, 2003 | 09:22 PM
maximadave's Avatar
detailerdaveb@gmail.com
use the coin holder on the right next to the shifter
Old Dec 5, 2003 | 09:33 PM
KLOOGY's Avatar
L33t BMW Drivah
Come on, I want to fire some Stinger missles at an Evo !
SmoothMax
Apr 16, 2001 06:53 PM
Cumalot
Mar 15, 2001 06:25 PM
Ramius83
Jan 5, 2001 03:31 PM
My 4DSC
Jan 4, 2001 07:21 PM
Cumalot
Nov 26, 2000 04:30 PM
