Clanking in rear...
Old Oct 6, 2004 | 10:24 PM
SE01's Avatar
Clanking in rear...
Everytime I go over a speedbump I hear this clanking towards the rear of the car when the back tires go over the bump. It sounds like some type of metal clanking against metal. I think something is loose back there but I have no idea what to look for. Anyone have any ideas?
Old Oct 6, 2004 | 10:36 PM
2000 Maximus's Avatar
SE01,
i have a similar sound in my car as well. I think it may be my spare not being tightened in the right spot or something but its def comin from the rear of the car. Does yours sound like its comin mainly from the rear passenger side more than the drivers side rear? Let me know what you find out
morovasa@shu.edu
Old Oct 7, 2004 | 09:03 AM
MaximaPolak's Avatar
It could be your tools for the jack clanking.
Old Oct 7, 2004 | 09:17 AM
SE01's Avatar
Originally Posted by 2000 Maximus
SE01,
morovasa@shu.edu
I don't really know exactly which side it's coming from, just that its coming from the rear.
SE01's Avatar
Could be, but the only reason I posted is because it started doing it today and I had never heard it before.
Old Oct 7, 2004 | 09:23 AM
max5spd's Avatar
Says.."No mo Maximas for me!"
I had the same problem when I bought my car. Turns out it was the jack handle in the compartment where the actual jack was. I was never so happier than when I found that.
Old Oct 7, 2004 | 09:44 AM
Never heard your car without the radio on?
You'll hear many things!
Old Oct 7, 2004 | 01:43 PM
THe jack handle, really?? i am sure mine is under my spare tire, i will try to check it out. THankx max5spd
Old Oct 7, 2004 | 05:20 PM
midnightmax01's Avatar
if you have an aftermarket y pipe, it is designed so that it can turn on the flange that the bolts go through, mine was making some wicked racket so i got someone to turn the whole rear section while i was tightening the bolts and to make a long story short it went away.
Old Oct 7, 2004 | 05:24 PM
Triple8Sol's Avatar
I miss the .org!
Do you have an RSB?
Old Oct 7, 2004 | 06:37 PM
Y2K1GLEMAX's Avatar
i have the same problem. its comming from teh rear passenger side. It almost sounds as if its right under the seat. my friend said it was probably a strut. i wasnt sure and i left it at that
Old Oct 7, 2004 | 07:23 PM
Ephraim's Avatar
it could be your muffler has broken apart from your exhaust, right above the wheel, it happened to me, at only 43k miles, rusted right through.
Old Oct 7, 2004 | 07:28 PM
irish44j's Avatar
retired moderator
as you can see, it could be any number of things. It would be helpful if you told us about any suspension/exhaust mods you have...If you are stock then that narrows it down a bit. If you're OEM, I'm betting either loose spare tire/jack or bad strut....
Old Oct 7, 2004 | 07:57 PM
ZIPPIN's Avatar
Mauja He Mauja
dead body?????????????????
Old Oct 7, 2004 | 09:23 PM
SE01's Avatar
Stock suspension, stock exhaust.
Old Oct 8, 2004 | 06:46 AM
max5spd's Avatar
maybe the jack is just loose in that holder. tighten it and see if it goes away.
jashick
Apr 18, 2003 11:16 PM
humberto_i30
Mar 21, 2003 07:06 PM
max95q
Mar 2, 2003 06:27 PM
PCGuRu2K
Aug 20, 2002 04:17 PM
fmacdowell
Jan 12, 2002 07:09 AM
