Blown HID question
Old Oct 28, 2004 | 11:11 PM
ÀÜSSÎË's Avatar
Blown HID question
G'day all, I know the HID subject has become old but I was wondering if someone might be able to help. I had a head light blow (HID) and took car top Nissan to get light replaced....but in getting car back, the bulbs don't match, the old bulb is slightly blue and and new one is amber in colour. Is this normal will the new bulb turn blue? Nissan is clueless..as I would like them to match they said it may be a balist causing it they said they are willing to fix problem..
Old Oct 29, 2004 | 01:24 AM
HNDA ETR's Avatar
Still Here... IM me for more..
try swapping the bulbs... that should tell you if it's the bulb or the ballast...
if the color follows the bulb, it's the bulb... if it stays put, it's the ballast..
Old Oct 29, 2004 | 08:08 PM
young1976's Avatar
Do HID bulbs yellow a bit over time? Did they put the same color temp back in?
Old Oct 29, 2004 | 08:15 PM
scmaxima2k's Avatar
HID bulbs colorshift over time. Sounds normal to me.
Old Oct 29, 2004 | 08:20 PM
R.I.P. Grandma's Avatar
Sc is right the bulb needs time to colorshift. 20hours should be enough time, i doubt its the ballast mainly because the bulb would have a hard time lighting up if the ballast was messed up. If it really bothers you tell nissan to put in a new bulb on the other side as well and then both will match.
Old Oct 30, 2004 | 11:27 PM
ÀÜSSÎË's Avatar
thanks for all your help, I will give it some time if it does not change I will ask Nissan if they can do something....at $253 a buld I doubt they will chang the outher side for me..we will se
Old Oct 30, 2004 | 11:34 PM
† ErV †
as far as i know they become blue/pinkish and when really worn red/orange.
so most people will never see the red part. that's why buying 6000k bulbs is somewhat questionable as in a few years 4100 will shift to about 6000k anyway.
Old Oct 31, 2004 | 05:21 AM
Qmax03
same here one of my bulb needed to be replaced the new one id a bit yellowish while the older one is a bit bluish.
Old Oct 31, 2004 | 06:53 AM
Ammi's Avatar
350 Detroit Muscle
They charged you $253 for 1 bulb?
Old Oct 31, 2004 | 09:34 AM
ICELANDIC MAX's Avatar
too much $$
Old Nov 1, 2004 | 10:58 PM
ÀÜSSÎË's Avatar
yer $253.88 for a xenon bulb, that realy hurt..but they covered the cost as the manager about fell off his chair when he found out how mutch it cost
Old Nov 2, 2004 | 04:42 AM
Ammi's Avatar
350 Detroit Muscle
W/ that price, you could have gotten nice aftermarket bulbs.
Old Nov 2, 2004 | 09:15 AM
OAUSSIEO's Avatar
No kidding, but whay can I say I did not hav to pay for it,
Old Nov 3, 2004 | 12:03 PM
icepick's Avatar
dont put it in your mouth and it wont blow !!!
Old Nov 4, 2004 | 06:59 AM
desperado_45's Avatar
You got robbed man
Its recommended that both bulbs are replaced at the same time, for color and longevity issues. Since the bulbs usually go about the same time.
Old Nov 10, 2004 | 11:43 AM
ÀÜSSÎË's Avatar
Update!!!!
I took the car into Nissan and they had it for a doy or so and could not figure out why the colour was so differant..Nissan switched the bulbs (put the old bulb in the drivers side) and got the sameb colour, so decided to replace both bulbs..the differance now is unbelivable..they are so bright..Nissan said they are a defferant bulb as the older ones had some coating that they are not alowed to use any more...I don't mind they work great
Pasific Nissan
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
MaxLife17
Sep 8, 2015 02:36 PM
