View Poll Results: What kind or rotors to change to???
Cross-drilled
13.37%
Drilled slotted
16.57%
Slotted
32.85%
Oem
37.21%
Voters: 344. You may not vote on this poll
Those who have changed your rotors...
Old 02-21-2007, 08:36 AM
  #121
Trurida18's Avatar
Originally Posted by ghost
alright fellas I just installed front/back cross-drill/slotted rotors with dura last ceramic pads cause those are the only ones I could find over the weekend and I was inpatient. I have two questions, 1. I've search every where I could think of "yahoo images, cardomain, here" and I've seen people put rotors facing both ways as far as the holes/groves go, can't figure which way is right way. 2. Since this was my first time doing brakes I notice that the new pads did not have the metal thingy where the stock hooked up on the clip from the caliper, is this normal? I hear the pads rubbing when Im driving at slow speeds on the freeway by the wall and I think is because they are not retracting back like I think they should plus I see some dust which I know is normal considering that the groves would remove more pad as oppose to blank rotors. Here's a pic of my rotors, I swapt the front rotor to look like the back ones "ones painted blue" I forgot to take pics of the front ones after I swapt em. I'm planning on getting hawks but they're on special order, gotta wait like 3-4 days.
ARE THOSE YOUR oem CALIPERS PAINTED?
Trurida18 is offline
Old 02-22-2007, 10:24 AM
  #122
98sebring's Avatar
Chinese rotors, $30.00 each, OEM pads. 175000KM driven, 3rd set of rotors and pads.
98sebring is offline
Old 03-03-2007, 12:07 PM
  #123
Ronniels's Avatar
Drilled & Slotted from R1 Concepts, WOW! Unbelievable difference...wish I had done this upgrade long ago.
Ronniels is offline
Old 03-07-2007, 10:13 AM
  #124
MidN1te's Avatar
Yeah i had mine for a min and its been wonderful! some people dont like the sound.....but i think it sounds kinda cool when i slow down.....sounds like a plane coming to a stop hahahha.
MidN1te is offline
Old 03-07-2007, 12:53 PM
  #125
skyjay617's Avatar
cross drilled they crack. Slotted or OEM are good!
skyjay617 is offline
Old 03-07-2007, 01:15 PM
  #126
MidN1te's Avatar
no all cross drilled rotors cracked....depends on what cheap company you go with...even the mercedes has cross drilled that come factory from the dealer and i've seen them last awhile.
I love my rotors....they stopped better than the power slot's i had.
MidN1te is offline
Old 03-12-2007, 09:42 AM
  #127
clayman88's Avatar
No option for this in the poll, but I just installed Brembo blanks & Hawk HPS pads. They seem to grab really hard...much better than OEM. I really don't see any reason to pay extra for slotted/drilled. I'm willing to bet 99% of the people who pay for them do it strictly for looks.
clayman88 is offline
Old 03-19-2007, 05:02 AM
  #128
MidN1te's Avatar
well i guess i'm in the that .1% category, cuz i only paid 180 bucks for ALL 4 slotted/cross drilled rotors WITH brake pads and never had a problem. no warping, hardly any break dust.
True, people pay for looks....but why not have the performance too? and for only 180 bucks for all 4 rotors AND brakes? They work awesome and they grab like their's no tomorrow!
MidN1te is offline
Old 05-07-2007, 07:02 PM
  #129
milesd77's Avatar
For rotors, Frozen rotors are best having been through a nitrogen freezing cycle. This is what nascar uses because the technology really works. These are easy to put on and marked for left and right side. HPS performance pads finish up this setup. The frozen rotors have instructions on how to break in and seat the pads as well as properly heat cycling them... $116 tirerack.
milesd77 is offline
Old 05-07-2007, 08:18 PM
  #130
Trurida18's Avatar
^^ im running standard powerslot slotted premium rotors.......im gonna try the cryo rotors for the fronts next time around
Old 05-07-2007, 10:00 PM
  #131
Nightmare = Reality
Maxim(a)SerjVQ's Avatar
wow.. . haven't seen this thread in awhile.
To refresh; i have Stillen/Brakepros xdrilled (brembo manufacture) rotors at all 4 corners w/ Hawk HPS pads.
NO Cracking whatsoever.
NO warpage that I can discern. Any vibration that i have in the suspension is from some Tire Cupping and a bent rim I'm living with.
and according to my local shop last week, It seemed like I had plenty of life left on the front pads!
I installed this setup quite some time ago; I think around 65-70k on the ODO, and I'm currently at 124k. Almost 60k on the whole setup and apparently i have significant pad life left. with the amount of heavy braking I do, I am still impressed that it's lasting this long.
Braking performance has declined, but I firmly believe it's because I'm still on my original Shocks, which is probably limiting the effectiveness of acceleration and handling as well.
Maxim(a)SerjVQ is offline
Old 05-09-2007, 11:13 PM
  #132
Bad *** Newb
Child_uv_KoRn's Avatar
Originally Posted by makavelisk
I have had brembo cross drilled and slotted in the past and they are pointless. They do not make the pad wear less or help you stop quicker. They are for looks unless you upgrade from stock and go bigger then you will notice a difference. For instance the new 05 corvette comes with drilled rotors if you get the upgraded packed and GM says that they do not improve performance they are just looks. The only thing that I noticed on drilled rotors is that they tend to crack by the holes if you are in constant traffic.
I say that you had crappy everything to begin with.
I had brembo drilled and slotted with ceramic pads and stopping was incredibly easy and faster (my old 2000 baby). Even jacking the brakes at 120 I could stop with ease. Try that with stock and see what happens. I've warped my rotors doing that only twice.
Child_uv_KoRn is offline
Old 05-10-2007, 08:10 AM
  #133
JimmyH's Avatar
Why is everyone so worried about brakes? It is the the GO pedal you need to worry about...
JimmyH is offline
Old 05-10-2007, 02:14 PM
  #134
dblock75's Avatar
How do you kno if you need new pads/brakes? When I brake, the brakes squeak for a good 2-3 seconds and then stop....do i need new pads?
dblock75 is offline
Old 05-10-2007, 02:45 PM
  #135
Trurida18's Avatar
well if u can't stop doing a buck twenty.....hope u have a nice funeral and RIP...not to mention it takes twice as much force to stop an object with enough built up momentum, as opposed to accelerating the same object's speed......
Old 05-10-2007, 04:26 PM
  #136
Nightmare = Reality
Power is nothing without control.
Old 05-10-2007, 07:01 PM
  #137
andyslone's Avatar
yea stopping is always good...
andyslone is offline
Old 05-11-2007, 07:12 AM
  #138
JimmyH's Avatar
I drive fast, but I drive responsibly. 165k and stock brakes have always been just fine for me. I admit I hit 120 once or twice, but not very smart in a Maxima.
Sometimes squeak/squeel is just inherent to disc brakes, nothing you can do about it. If you are down to the limiters, you will know. It is horrible screeching when you brake. If you go too long, horrible screeching whenever you are moving.
A tip: if you do your own brakes, apply disc brake quiet to the BACK of the pads (side facing away from the rotor) before you install. This will stop 99.5% of squeeling. If you dont, tell the shop to apply it. Some shops do anyway.
JimmyH is offline
Old 05-11-2007, 09:22 AM
  #139
Cletus
SoonerFan's Avatar
new OEM rotors with Hawk HPS pads
SoonerFan is offline
Old 05-20-2007, 10:07 PM
  #140
Project323
these rotors are good:
Old 05-20-2007, 10:08 PM
  #141
Project323
Old 05-20-2007, 10:19 PM
  #142
Project323
i also like performance of powerslot rotors:
Old 05-22-2007, 04:16 PM
  #143
I C U
illlojik's Avatar
Originally Posted by Project323
Whoa. Those are nice. What rotors are those? and did you need a extra bracket of some sort to make the caliper fit?
illlojik is offline
Old 05-22-2007, 04:33 PM
  #144
I C U
illlojik's Avatar
By the way, I know it's been mentioned that 6th gen calipers fit on 5.5 gens with no modifications or additions. I didn't find the answer to whether they can fit directly on a 2k with after-market wheels. (I know they don't fit behind the stock 2k wheels)
edit: Nevermind.. I got it.
illlojik is offline
06-06-2017 02:01 PM
doctorpullit
03-29-2016 11:08 AM
MaxLvr21
10-17-2015 12:11 PM
jds22
09-29-2015 02:03 PM
Noela
09-26-2015 08:22 AM
Quick Reply: Those who have changed your rotors...
