Advance Timing: Step by Step Instructions with Consult 2 Tool
Old May 3, 2009 | 08:13 AM
  #121
Kgkeen101's Avatar
So if I send my ECU to technosquare for the flash should I ask them to just bump the timing while they are in there? Will they do it?
Old May 3, 2009 | 10:25 AM
  #122
Progress's Avatar
It's business time.
Does anyone know if anything can reset the advance back to stock timing? For example the idle relearn or a misfire/blown coil, etc? I'm assuming no but was curious.
Old May 3, 2009 | 02:19 PM
  #123
Tippy Toes's Avatar
I assuming the consult 2 can. I have no idea- I dont see why you wouldnt be able to go back on consult 2 and plug in a lower degree and do the relearn.
Old May 3, 2009 | 03:07 PM
  #124
mannetti21's Avatar
I think he meant accidentally set it back...I'm pretty sure the only way you could retard the timing again is through the Consult. This is obviously not the case for the 4th gen ecu
Old May 3, 2009 | 04:58 PM
  #125
Progress's Avatar
It's business time.
Correct. I had mine advanced back in '06 and have since replaced a coil and done some other things.
Old May 15, 2009 | 10:20 AM
  #126
AEMAXIMA01's Avatar
My IACV just went out and it fried the ECM as well. The dealer just ordered the new ECM and it will be in next week. Would it be ill-advised to ask them to do the timing advance with a brand new ECM, or should I wait a while to make sure everything is back to normal before I do it? I mean, it shouldn't really cost anything, it's already going to be hooked up to the consult getting the keys reprogrammed, etc.
Old May 15, 2009 | 08:34 PM
  #127
hot_wax_tree's Avatar
if you actually read the thread you will find your info.
would a mazda dealer be able to. my buddy works there and the guys at nissan are ******.
Jake
Old May 15, 2009 | 10:36 PM
  #128
mannetti21's Avatar
Jake
I've also got a friend who works for Mazda, he said they don't have the right tool to do it on Nissans
Old May 15, 2009 | 10:37 PM
  #129
STILLENGLE's Avatar
You need a Consult II, there's another tool as well not sure what its called though.
Old May 15, 2009 | 10:43 PM
  #130
mannetti21's Avatar
UpRev's Cipher (http://www.uprev.com/products.php) - you need to purchase the cipher software package ($300)
Old May 15, 2009 | 10:46 PM
  #131
STILLENGLE's Avatar
^yea that^
Old May 16, 2009 | 05:17 PM
  #132
AEMAXIMA01's Avatar
Anyone?
Old May 18, 2009 | 09:25 AM
  #133
AEMAXIMA01's Avatar
Anyone?
Someone has to have an idea. The ECM arrived at the dealer today and should be put in soon. Anyone???
Old May 19, 2009 | 08:14 PM
  #134
AEMAXIMA01's Avatar
Too late. Already got the car back. Thanks anyway.
Old May 19, 2009 | 08:44 PM
  #135
Grand_hustle17's Avatar
wow, where was this thread... why i never saw it??? and i know sheehy nissan shop chairman
Old May 19, 2009 | 08:49 PM
  #136
mannetti21's Avatar
I got it done, +3*, I've definitely noticed and increase in low end torque, around about 1500-2500rpm...might go up 2 more degrees but I'm gonna wait until it gets hot out to make sure there isnt any ill effects with the 3
Old May 23, 2009 | 03:50 AM
  #137
arcueda's Avatar
sooo 2 questions that still havnt seen anwered......downsides? and why didnt nissan just sell from the factories at 17*?
t.y.
Old Jul 3, 2009 | 09:21 AM
  #138
jocoo's Avatar
Anyone know of any shops in NJ who are willing to do this? I went to my local dealer said $112 bucks for 30 min work......I think not. Hesitant to ask Nissan mechanic instead of desk.
Old Jul 3, 2009 | 10:52 AM
  #139
mannetti21's Avatar
t.y.
Only real downside is that you have to use 93octane
Why not straight from the factory? I would say that they probably wanted to play it safe in regards to knocking/pinging since the cars end up getting sold at different elevations and climates.
Old Jul 3, 2009 | 10:54 AM
  #140
mannetti21's Avatar
Hesitant why? Go ahead and ask him. Offer him a $20. Anything more is unreasonable as it takes less than 3minutes
Old Jul 3, 2009 | 03:25 PM
  #141
i did the advance, but secondtonone and the tech at the dealership said on A33B's it will most likely reset itself back to stock timing, how can i tell that it didnt if i dont have access to a consult anymore???
Old Jul 3, 2009 | 04:24 PM
  #142
02MAXZIMA's Avatar
you will be fine. i did it to mine a year ago at the dealership i work at and still is fine
Old Jul 4, 2009 | 08:49 AM
  #143
jocoo's Avatar
Does it take less than three minutes? One guy said it takes a half hour for the program to upload into the ecu? Don't think so....or am I wrong.
Old Jul 4, 2009 | 09:44 AM
  #144
knight_yyz's Avatar
Toolie
downside... increased emissions.
Takes 5 minutes with autoenginuity so shouldn't take 1/2 hour with the consult 2, but they will charge minimum 1/2 hour to one full hour.
Old Feb 22, 2010 | 08:08 AM
  #145
efanatic's Avatar
I am going to stop by the dealership and see if I can find someone to do it.
I just got a 2K auto(it runs good but its slower than I thought it would be) so anything I can do to make it a bit quicker would be nice.
It stunk getting beat by a sentra ser I have only put 93octan in it so I am good there
Old Feb 22, 2010 | 08:39 AM
  #146
Mr. Brett's Avatar
1.) Check the date of the thread...
2.) If you got walked by a Sentra SE-R, you probably have some serious issues you should see about getting resolved before you consider a timing advance. I've never heard of the VQ30 being slower than a Sentra.
Old Feb 22, 2010 | 11:31 AM
  #147
efanatic's Avatar
My 0 to 60 time is around 8 seconds according to a window mount G-meter. The SER is running a 7.1 sec. Mine is an auto which I know slows it down a little, I would have thought it would have been in the 7 second range.
If its suposed to be faster than it is(I have new plugs in it) then I guess I need to go to the dealership anyways and have them look at it.
Its a new car to me , on have had it about 2 weeks. It does get good gas milage(24.6 is what I got on the first tank)
Old Feb 22, 2010 | 11:38 AM
  #148
Mr. Brett's Avatar
I think the 0-60 on the VQ30 should run between 6.7 and 7.4 seconds. So you should've been able to run with or overtake that Spec-V.
Have your car serviced. It sounds like it's in need of a tune-up.
Edit: I never thought to take into account the mods on the SE-R. Any?
Old Feb 22, 2010 | 01:10 PM
  #149
efanatic's Avatar
The SE-R was stock except a CAI .
What kind of things need to be tuned up. I just replaced the plugs. I am thinking about getting a header and CAI if its not too much trouble to install.
I had a 2002 SE-R that I modded myself so I have no issues doing the same here. Just need to know what will help the most (and is easy on the wallet)
Old May 17, 2011 | 02:49 PM
  #150
meangreenchevy's Avatar
I AM A NISSAN TECH
i will do this for anyone that wants to come to the staten island,ny dealership. i want $40 to do it. call or txt me 347 265 4635
Old May 17, 2011 | 06:14 PM
  #151
Nexus67's Avatar
^Good to know, number saved
Old May 18, 2011 | 06:26 AM
  #152
NmexMAX's Avatar
dot dot dot ...
Whenever I'm in NY, I'll go ahead and call him too.
I charge my locals 20$ or a few beers .
UpRev.
Old May 18, 2011 | 06:32 AM
  #153
ranmas2004's Avatar
I know I'm late but I know you should get PROPER tuning from a professional on a dyno and not on your laptop in your car at home. If you adjust A/F ratio and timing at the same time (using some kind of FIC controller) you will have a PROPERLY tuned vehicle and it should be safe, especially if you got headers, big bore MAF, CAI, exhaust, SSIM, etc! You can go to the dealer or backyard mechanic and slip some dude that don't give 2 craps about your car $20 to do whatever and they will, then when your engine have problems they going to deny doing anything because you don't have proof because you were trying to be cheap and get a quick fix. I know we want to get more power out the vehicle but we want it to be done SAFE and not ruin a great engine.
Old May 18, 2011 | 06:38 AM
  #154
NmexMAX's Avatar
dot dot dot ...
Originally Posted by ranmas2004
This thread isn't about all that, it's about dealers or someone with proper software adding 2º base timing.
Believe us, we know what we are doing (most of us).
Old May 18, 2011 | 08:20 PM
  #155
T_Behr904's Avatar
Anyone have this done by a dealer in north/central Florida, or south Georgia?
Old May 19, 2011 | 06:09 AM
  #156
NmexMAX's Avatar
dot dot dot ...
Try your regional forum .
Old May 19, 2011 | 06:54 AM
  #157
01SilverMaxima's Avatar
Just got it done yesterday. For free, I might add. Def a lot better throttle response!
Old May 19, 2011 | 08:41 AM
  #158
Old May 19, 2011 | 05:42 PM
  #159
T_Behr904's Avatar
Been working on that, haven't had much luck yet
Old May 28, 2011 | 11:44 AM
  #160
amixamse's Avatar
Slid past the service bay fri after work, and stopped where I seen a tech in one of the bays. Pretty much was like what's up cuz wanna make 20 bucks I need to plug up to ur consult.. He proceded to plug in the software and handed the machine over to me and went back to working on a versa. I couldn't tell if the update completed after adjustment cause there isn't a loading bar etc.. But when I tested it I knew it worked, nice lil torque adder! Pm me If u want it done in Memphis area
