ABS, TCS Off, Slip Lights - No Codes Pulled
Old 06-16-2005, 11:57 AM
xUltra's Avatar
I went to autozone thinking it would be the ignition coils like everyone else, but it didn't pull any codes! The guy at autozone said that it doesn't read ABS problems, so I'm thinking it could be the ABS sensor.. or possibly the battery. (But I doubt it)
Any ideas suggestions? What can I do to troubleshoot the problem? I changed my front pads and rotors a couple weeks before the lights turned up, however they seemed to come up the day after very rigorous driving and I had to SLAM on my brakes while the ABS turned on.
xUltra is offline
Old 06-16-2005, 04:21 PM
importuner
It is an ABS sensor. I just changed an ABS sensor on a 2k1 Max today with those same lights on and pulled an ABS code with Consult II. Try to find someone that has a scanner with the capabilities of going into ABS to determine which sensor it is. It can be several things having to do with the ABS system. BTW, if you didn't know already, this doesn't affect your braking at all. You just don't have ABS. Good luck!!!
Old 06-19-2005, 11:20 PM
xUltra's Avatar
any particular shops that might have this sensor? Also how much is it roughly? I've heard numbers of around $300..?
xUltra is offline
Old 06-19-2005, 11:22 PM
Wat
E55AMG2's Avatar
It could be as simple as a fuse, or as bad as replacing the sensors...other times its just low system voltage
E55AMG2 is offline
Old 06-20-2005, 06:39 AM
jkayca's Avatar
It might not be the ABS sensor itself. Check out this thread I started a few months a go. I had two problems: a blown 02 sensor and a bad ABS relay - not the sensor itself. I was quoted by the stealership $75 CDN parts and labour for the relay. I opted not to get it fixed though as the problem is sporadic and does not occur very often and they didn't have the part in stock.
jkayca is offline
Old 06-28-2005, 10:24 PM
xUltra's Avatar
damn, I think I might just go to the dealer and pay $95 diagnostic :\
I have also been hearing very annoying, quite loud squeaking that seems to have been coming from my back left tire.... only when cruising- when I apply the brakes it seems to go away, same thing when I apply e-brake. Any ideas?
xUltra is offline
Old 06-29-2005, 05:23 AM
jkayca's Avatar
No idea. BTW, you're hijacking your own thread Might want to start a seperate one for this issue.
jkayca is offline
Old 07-11-2005, 05:25 PM
cobalt416's Avatar
xultra,
do you still get that 'clang' noise when the car start and the ABS do a self test ?
i have the same problems, all 3 lights are on (sporadic, not all the time), and i noticed that the 'clang' noise i used to hear from the self test is gone.
cobalt416 is offline
Old 07-14-2005, 02:43 PM
cobalt416's Avatar
today the situation got worse, there is some strange vibration from the passenger side front wheel. i have made an appointment with the stealership and let them take a look at the car, will keep you guy posted as to how are they going to rape me.
Old 07-15-2005, 11:03 PM
cobalt416's Avatar
the stealership had it fixed... the said the rear abs sensor was gone, had it replaced, costed:
ABS sensor 47900-2Y060 CA$509 (about US$ 397)
Labor - 2 unit CA$127 (about US$ 99)
Total CA$636 (about US$496)
The strange vibration is from the rotor they said, had the pads replaced and rotors serviced, costed me additional several hundred dollars on top of the amount mentioned aboved.
The service manager said I did not have ABS anymore, and it is ok to drive around in summer, but could be crucial in icey Toronto in winter, guess I had no choice, so I broke the piggy bank and had them fixed. The TCS, ABS, SLIP lights are all gone, the one time clang-noise (from ABS self-test) came back everytime I start the car.
Old 08-07-2005, 06:45 PM
xUltra's Avatar
hrmmm good to know
xUltra is offline
Old 08-07-2005, 07:08 PM
Inspiron's Avatar
The ABS sensors go for around $100.
http://www.trademotion.com/partlocat...11&catalogid=2
Inspiron is offline
Old 08-08-2005, 12:01 PM
BewstAdd1ct's Avatar
i show list as 131.37, thats a dealer price.
and thats a wheel speed sensor
BewstAdd1ct is offline
Old 08-08-2005, 04:14 PM
doublea's Avatar
I had the same thing happend to me few months ago, it was and ABS sensor. I was able to get one from the salvage yard for 50$ and worked fine for me. The dealer was asking 569$ fora brand new. After I removed the defective ABS sensor, I cleaned up the magnet and put it back and was working fine as well so now I have a spare one.
doublea is offline
Old 08-18-2005, 01:50 PM
xUltra's Avatar
yeah DaveB quoted me $117 USD for the sensor
xUltra is offline
Old 08-19-2005, 08:55 AM
instil's Avatar
how come nobody had their sensor replaced under warranty. It should cover that,no?
instil is offline
Old 08-19-2005, 12:31 PM
instil's Avatar
Anyone?!!! Im going to the dealership monday i guess for this same ABS,TCS,Slip light problem. If its this wheel sensor im reading about, i dont see any reason that it wouldnt covered under warranty (one of the 6 things that ARE actually covered)
instil is offline
Old 08-20-2005, 08:02 AM
wheel speed sensor is covered for 3/36.
Old 08-28-2005, 05:44 PM
xUltra's Avatar
ok, went to a friend's shop and hooked it up to the diagnostic computers, turned out that rear right "speed sensor" is out, is that the same as abs sensor?
xUltra is offline
Old 08-29-2005, 02:50 PM
yes, for some reason, nissan likes to call their wheel speed sensors 'ABS sensors'
Old 08-29-2005, 04:15 PM
xUltra's Avatar
hrmm, cool! I'm going to try to clean it off before ordering a replacement.
xUltra is offline
Old 09-23-2005, 11:29 AM
xUltra's Avatar
For future reference, the problem turned out to be a bad ABS Sensor, after takin it out and looking at it more closely, I probably could have used the original sensor by cleaning it a little more. But I called DaveB and had him send me a new one for ~$112. (2001)
xUltra is offline
CorollaULEV
30
08-09-2021 08:11 PM
AnsonJ
06-02-2017 01:35 PM
SmokinMax02
18
09-11-2015 12:25 AM
magneto112
09-10-2015 12:52 AM
doobadoo
08-15-2015 06:43 PM
Quick Reply: ABS, TCS Off, Slip Lights - No Codes Pulled
