keyless entry, auto dome light, lock switch all not working, HELP
Old 09-04-2005, 05:04 PM
Max_Vader_2K's Avatar
I dont know if somthing shorted out or what. But The car turned off about 3 times and it seemed as if the battery had died. I go back out to the car and it started right up. But with keyless entry, auto dome light, lock switch all not working. Could it be the relay or should I try disconecting the battery. I need a little help. All input will help troubleshoot this.
Max_Vader_2K is offline
Old 09-05-2005, 09:48 AM
BewstAdd1ct's Avatar
check all the fuses, i believe there are 3 for the smart entrance control unit, which is what the problem seems to be.
BewstAdd1ct is offline
Old 09-05-2005, 10:16 AM
SHIFT_om nom nom nom
Metal Maxima's Avatar
Replace fuse #13...its a 10A fuse.
Metal Maxima is offline
Old 09-05-2005, 10:27 AM
lol ^^^
someones had that problem before
Old 09-05-2005, 12:59 PM
Originally Posted by BewstAdd1ct
lol ^^^
Damn, you caught me!
Old 09-05-2005, 01:05 PM
Ok thanks guys. I will look at that fuse and replace if necessary. I will post back the details.
Old 09-05-2005, 01:13 PM
where is fuse # 13, What is it called. They are not numbered.
Old 09-28-2005, 01:58 PM
Ok first of all I was able to find fuse # 13. Each fuse is numbered on the same panel were the fuse is put in. That fuse is not blown. And the rear defrost is not working.
Second I check every single fuse in the car and still none are blown. Nissan wants way to much to look for this problem. Do anybody have any sugestions?
Old 09-28-2005, 05:22 PM
check 12, 13, 10, and 1. also, theres a 40A ckt breaker providing power to the SECU.
ck power at the secu, pin 11, 32, 10, 33, and 21, key on.
you can PM me your email and ill send you a wiring diagram...
Old 02-26-2008, 09:06 PM
Manzies1's Avatar
Keyless entry, auto dome light, lock switch all not working, HELP
I'm having the same problem with my 2000 Nissan Maxima SE except my car is starting just fine. My power locks, keyless entry, rear defrost and interior lights are all dead. I have looked for the white plastic box with the three connectors (smart entrance control unit) that everyone talks about but I can not locate it. I did locate a tan box with two plugs which I think is the SECU. Am I the only one that thinks this tan box, which is located to the right of the steering column is the right part? Any help with this situation would be greatly appreciated.
Manzies1 is offline
Old 02-27-2008, 03:18 AM
NewfoundlandDud's Avatar
I had the same problem over the summer. It was also draining my battery if the car sat for any amount of time.
It was the Smart Entrance Control Unit. It is a white box with 2 plugs IIRC. I have an exam today so I don't have time to search for the pics right now.
It is right under the steering column, and has a number on it that's something like 285-95 4y900 or something.
Can't recall exactly right now, but that seems to be your culprit.
$592 from Nissan, so try to find one in a part-out.
NewfoundlandDud is offline
Old 02-27-2008, 07:53 AM
the org...not what it was
alicious's Avatar
.....and you checked/tested fuse 13, correct?
alicious is offline
Old 02-27-2008, 02:24 PM
Manzies1's Avatar
I checked all the fuses and all are good. No, I didn't test fuse 13. If all the fuses are good, why would I need to test fuse 13?
Manzies1 is offline
Old 02-28-2008, 05:40 AM
alicious's Avatar
Because otherwise how are you gaging that the fuse is good?
alicious is offline
Old 12-30-2008, 05:02 PM
loveofmylife00maxima's Avatar
Oh and yes am the same too SECU will noy turn off my keyhole light therefore drainig my BATT nissan says its 90 dollars just to diagnose. oh well.
loveofmylife00maxima is offline
Old 12-30-2008, 05:17 PM
Toolie
knight_yyz's Avatar
i have a SECU for sale in the classifieds
knight_yyz is offline
PPPPLLLLEEEEAAAASSSSEEE HHHHHEELLLLLLPPPPP MMMEEE
Does anybody know if the SECU from a Sentra will fit an 00 maxima SE? i cant post yet so i figured i do it this way. I know it is what my problems is because my keyhole light stays on all the time and drains my batt. Nissan said 90 just to diagnose but i got one from a junk sentra my uncle bought for parts, opened it and all is the same with no difference. im just thinking about swapping but just waiting for a response first thanks.
Old 12-30-2008, 05:22 PM
Toolie
knight_yyz's Avatar
check if the part number is the same
Old 12-30-2008, 07:01 PM
Where will it be
Where will the part number be.
on the sentra i couldnt pull the whole case out of the car so i opened it and pulled the circuit board out. NOw will the part number be on the case or somewhere on the circuit board thanks.
Old 12-30-2008, 08:08 PM
Maxim24's Avatar
I had the same power lock, dome lights, keyless entry etc...problems several months back. I checked ALL the fuses and all of them ohmed good. Checked the relays and they were good too. Checked the voltages on the pinouts at the SECU and diagnosed it down to a bad SECU. As mentioned above, it's located below the steering column and on the right side. Mine was tan colored and had the part number on it. You can easily remove the SECU and get the correct part number, then look for same part number at an online yard. I found mine in WA and cost me $80 bucks. After that, it's easy to reprogram the keyfob. Just ask if you need help to verify the SECU pin voltages.
Aloha!
Maxim24 is offline
Old 12-30-2008, 09:33 PM
Toolie
knight_yyz's Avatar
it's stamped on the outside of the plastic box.
Old 12-30-2008, 09:36 PM
thanks 4 then quick response.
and i def know it is the secu because it leaves my keyhole light on for more than half an hour when it shoiuld only be on for 30secs therefore drainng my batt. i dnt have a keyfob so i guess am free and dnt need to program.
the questionn is will a SECU from sentra work on the maxima? everything is the same on the circuit board with no difference.
i cant verify part numbers bcos i cudnt remove SECU from supports so i opened it and took the circuit board.
i just wanna swap. Will it work?
Old 12-30-2008, 09:46 PM
Toolie
knight_yyz's Avatar
to remove the SECU, just push down towards the floorboards and jiggle it a bit. It will work it's way off the metal bracket. You need to match the part numbers to answer your question.
Old 11-07-2009, 04:09 PM
coldfear13's Avatar
Hey, I was changing the trunk light bulb and as I was putting it in, it flashed for a second and went out. Now the Keyless entry remote doesnt work, the key ring light, the door lock switch doesnt work unless the car is on, door step light and dome light do not work at all. Normally I would be able to turn on the headlights with the car off, now they turn on only when the car is on. First thought was a fuse? Will check them tomorrow, but if they turn out to be okay, then I would have to replace the SECU for sure? Thank you!!
(2002 max)
coldfear13 is offline
Old 12-19-2009, 11:35 AM
avciugroar's Avatar
(2002 max)
Had this issue happen to me yesterday. Did you find anything out about this one?
Does anyone have the wiring diagram for the SECU to find which pins to test?
avciugroar is offline
Old 12-20-2009, 02:58 PM
maxxed_boi's Avatar
(2002 max)
I have this same problem, except mine was caused from messing with radios but i have the same symptoms.
maxxed_boi is offline
Old 12-22-2009, 03:15 PM
VQtHuRtY's Avatar
I have the same issue with my 2000 Maxima SE. I was messing with the fog lights and I guess I caused a short. Now my power locks, interior lights, rear defroster, key less entry doesn't work. I replaced the SECU and nothing. I purchased the SECU at a local junk yard today, so, I dont know if it's no good or it just didnt fix my issue. I'm gonna return it tomorrow, maybe exchange it and I'll let y'all know what happens...
VQtHuRtY is offline
Old 12-23-2009, 11:33 PM
mrjamaica98mx's Avatar
Secu solved all problems posted above==== but now my driver side headlight not working any help?
mrjamaica98mx is offline
Old 12-24-2009, 01:48 AM
avciugroar's Avatar
Did you check to see if it was just burnt out?
Old 12-25-2009, 01:47 PM
it's not burnt out there is no power i put a tester to actual light socket no red light i put old box back on light is now working
Old 07-31-2014, 10:55 AM
SE-Rfornow's Avatar
So I had these same issues but had trouble finding a SECU at a local junkyard. I'm glad I didn't because...
THERE MIGHT BE AN EASIER WAY!!
****Try disconnecting the two plugs going into the SECU, waiting 5 seconds and then reconnecting them. After about a year of no interior lights, power door locks, and rear defrost.... they all work!! The first time I plugged them back in the horn started honking like the car alarm going off and again when I opened the trunk. So the second time I made sure the keys were in the ignition and turned to accessory, unplugged the plugs and reconnected them starting with the white plug first. After this I had no more alarms. Also, FYI I took off the kick panel under the steering wheel by removing two screws to make unplugging the unit easier.
This is the box that I assumed to be the SECU: Click the image to open in full size.
I found this thread: http://x.nissanhelp.com/forums/maxim...defroster.html and thankfully tried unplugging it before buying a brand new unit from a dealer. Finally no more using a flashlight inside my car!
SE-Rfornow is offline
Old 02-17-2016, 01:08 PM
ibuybrits's Avatar
I need help on a 2000 Maxima. What is the pin voltage on the SECU and how do you reprogram the key fob? Thanks
ibuybrits is offline
Old 02-17-2016, 01:13 PM
ibuybrits's Avatar
On my 2000 Maxima, I have no door locks, no power seats or power windows. I have tested all fuses. The SECU clicks when i hit the power door locks. Help
Old 02-17-2016, 01:54 PM
Derrick2k2SE's Avatar
Check this fuse. it's in the long fuse box under the hood by the battery.
Derrick2k2SE is offline
Old 02-17-2016, 02:11 PM
ibuybrits's Avatar
I tested the fuse with ohms meter. It's got power like it should where fuse plugs in to box. I am thinking it's the SECU. The SECU clicks when I hit the door locks or power windows. The power seats do not work either.
Old 02-17-2016, 11:27 PM
DennisMik's Avatar
If that fusible link that Derrick2K2SE told you about (fuse # I) is truly good, then the circuit breaker for the windows and seats may be the problem. It is kind of rare that the circuit breakers go bad, but they can. Personally, I would try swapping that fusible link with one of the others as a test.
The circuit breaker is under the dash, somewhere behind the fuse panel. It looks like a relay with a black cover
DennisMik is offline
Old 10-26-2019, 07:18 PM
Msled's Avatar
This SECU worked out great for my 2000 Nissan Maxima it even fix other things that haven't worked for years. Thanks
Msled is offline
carguy96
20
02-06-2021 06:21 AM
Btheman80
05-01-2018 04:03 PM
vingodine
45
05-21-2016 12:46 PM
ah2002
03-09-2016 01:42 PM
jerrod99_se-l
08-27-2015 08:27 PM
Quick Reply: keyless entry, auto dome light, lock switch all not working, HELP
