belt problem
Old Oct 22, 2005 | 02:23 PM
merovi's Avatar
belt problem
Ok so i'm pretty sure i have everything down.
Only when its raining i get this terrible belt squeel. It happens when i start to move in first, or when i down shift to 3rd or 2nd to slow down. it squeels for about 2-3 secs. its extremely annoying and i'm sick of hearing it. had the belts checked a few weeks ago and they said they appeared to be fine.
anyone have any idea why or do i just need a belt replacement?
Old Oct 22, 2005 | 04:54 PM
BewstAdd1ct's Avatar
meh... just because it looks okay, doesnt mean it is. did they check the tension?
Old Oct 23, 2005 | 10:18 AM
merovi's Avatar
i dont know how they checked it. the guy came up to me and said that he checked the belts and they appeared fine.
Old Oct 23, 2005 | 08:40 PM
NmexMAX's Avatar
dot dot dot ...
Check them yourself ...
Old Oct 24, 2005 | 04:41 AM
ZIPPIN's Avatar
Mauja He Mauja
adjust the belts. sounds like they are too tight. looking towards the engine, on the right side of the alternator belt is the adjusting bolt. i think you need a 10mm to adjust it. i did mine by starting the car and then adjusting it..good luck
Old Oct 24, 2005 | 06:59 AM
NmexMAX's Avatar
dot dot dot ...
Or opposite.
Old Oct 24, 2005 | 07:56 AM
merovi's Avatar
yea it was my b-day weekend so i didn't have time to take a look under my hood, although i really wanted too. today me and my friend are going to take a look during my class break and possibly change them depending on what we determine. its just weird that it only happens when wet. it was wet out again last nght and on startup last night it 10 minutes for the squeeling to go away while i warmed up the car. this monring it took about 5 minutes and now its gone. its not wet anymore either.
Old Oct 24, 2005 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
Wet = slipping = too losse/not tight enough ...
Old Oct 24, 2005 | 08:13 AM
merovi's Avatar
thanks, in a few hours we are going to tighten the belt then with the "directions" that were given above, i'll let you know how it works out.
Old Oct 24, 2005 | 08:16 AM
NmexMAX's Avatar
dot dot dot ...
What directions.... .. I see nada above?
Make sure and loosen the pulley bolt.
Old Oct 24, 2005 | 02:26 PM
merovi's Avatar
not so much directions but a helpful hint.
i loosened the pulley bolt and turned the idle control thing a little tighter then re-tightened the pulley bolt. its kinda raining here now so i'll see if it made a difference later. thanks for the help. all else fails im going to just replace them. is it easier to just take the tire and tire well off to do this?
Old Oct 24, 2005 | 03:30 PM
NmexMAX's Avatar
dot dot dot ...
Much easier.
Old Oct 24, 2005 | 03:37 PM
merovi's Avatar
well so far io'm satisfied because i drove about 5 miles or so in the rain with no noise at all. i'm trying not to get my hopes up because they i can let myself down but hopefully overnight i will wake up tomorrow and have no problems.
Old Oct 24, 2005 | 09:10 PM
ZIPPIN's Avatar
Mauja He Mauja
[QUOTE=merovi]not so much directions but a helpful hint.
[QUOTE]
What did you expect, a write-up???
Old Oct 24, 2005 | 09:49 PM
lol...
i can copy and paste the svc manual page
05' MaximaMan
Oct 8, 2017 06:36 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
markevans999
Oct 25, 2015 08:27 AM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
