Do you have issues with HID going off when high-beam is on? Here's the fix...
Old Jan 12, 2006 | 07:28 PM
NYPD-Arnold's Avatar
Z
Ok, if your HIDs cut out when you turn on the high beams (and you're a 2001/2000 with a retrofit, obviously) the solution is simple -- check your grounds. I was at Maximum Tuning today, and Jeff fixed this instantly. If both cut off, then both headlights need a ground -- if just one cuts off, then only one does. I'll take a pic tomorrow of which wire was grounded and to what point. But yeah, grounds are your friend. =)
Old Jan 12, 2006 | 07:30 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
hey arnold... quik question... went i set my alarm off... my hid's come on,off,on,off, etc... now i no theres an alarm fix... but thats only went u engage the alarm... but im actually talking about the red alarm button wen u hit quite naturally ur alarm comes on....
Old Jan 12, 2006 | 07:44 PM
MIXXMAX's Avatar
Good to know. Yeah, when I installed my HID's, I had already known the ground issues of the headlight harness as compared to the '02-'03's. But, just for the record, it's best that the HID's don't cut out when the high beams are on, because this will definitely shorten the life of the HID's. Actually, when making the conversion of HID's in the '00-'01's, if your HID's cut out when high beams are on, then you definitely hooked them up improperly. They should stay on with the high beams.
Z
That's normal. All cars do that with HIDs.
Old Jan 12, 2006 | 07:45 PM
Z
Yep. Now all of my lights stay on with the high beams engaged. =D
Old Jan 12, 2006 | 07:50 PM
MIXXMAX's Avatar
Did you have problems before? Were your HID's cutting out with your high beams on?
Old Jan 12, 2006 | 08:00 PM
Z
Yeah, that's what I said in my original post. I had the issue remedied today. It was just one HID cutting out.
Old Jan 12, 2006 | 08:03 PM
MIXXMAX's Avatar
OK, I gotcha.
Old Jan 13, 2006 | 05:11 AM
Gemini67's Avatar
got it , nevermind
Old Jan 13, 2006 | 07:30 AM
NiZMo1o1's Avatar
any pics yet? so you mean I would need to have the OEM black ground also spliced to the chassis for extra ground so my Highs wont cut them off?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
MidnightMaxima_22
Sep 12, 2015 06:02 AM
mpbclutch33
Sep 8, 2015 06:21 PM
