technosquare L-Spec
Old Feb 23, 2006 | 03:46 PM
inspiredbykev's Avatar
You should thank my D***
technosquare L-Spec
I plan on sending my ecu out soon. I am getting the technosquare L-Spec.
I know that timing isn't done with the L-Spec. But I was planning on having the dealership advance it to 17. If I take it to the dealership is there a way that they could reset my ecu and wipe out the reflash from technosquare?
Old Feb 23, 2006 | 03:58 PM
lex3015's Avatar
umm yeah i think there might be a chance that could happen. im not 100%. but where did you plan on going to get your timing advanced? were both in the same area and ive only asked 1 dealership so far (smithfield) and they said no without even knowing what i talked about. send me a pm or something if you know a place around here that will do it.
Old Feb 23, 2006 | 04:55 PM
NisMo-Max's Avatar
Are the 00-01 Maximas able to get just the L-Spec, Since they havent made the computer reflash for the 5th Gens.
Old Feb 23, 2006 | 05:55 PM
Lets just say I ask technosquare to advance it to 17 degrees. I would I be able to find out if they did, would I need the consult II?
Old Feb 23, 2006 | 06:04 PM
NmexMAX's Avatar
dot dot dot ...
When did you get ahold of TS?
Check the AM forum, www.howstuffworks.com.
DL an FSM, and do some research on and any other source you can on ignition timing, base ignition timing(BTDC)
because it doesn't seem as if you know what timing you're talking about.
Old Feb 24, 2006 | 04:49 AM
I know what timing I'm talking about its ignition timing. I want it 17 btdc. This is done through the ecu with the consult-II. I remember seeing that technosquare messes with timing but I think that it might be for valve timing. I figured that if they can do all these other things to our ecu they could advance the ignition timing.
Old Feb 24, 2006 | 09:34 AM
NisMo-Max's Avatar
bump.......
Old Feb 24, 2006 | 09:47 AM
NmexMAX's Avatar
dot dot dot ...
bump.......
Why don't you call them and ask?
310-787-0847
Old Feb 24, 2006 | 03:59 PM
k2max_driver's Avatar
technosquare will mess with your ignition timing, fuel, remove the governor, raise the rev limiter to 7100rpm, and play with the timing on your VTC (variable timing control)
Old Feb 24, 2006 | 04:01 PM
im a little hesitant to spend $500 on it because im going nitrous and as you all know you cannot advance the timing when dealing with nitrous.
timing advance + nitrous = boom
Old Feb 24, 2006 | 04:46 PM
what would be the negative effects of advancing the timing to 17 degrees?
Old Feb 24, 2006 | 05:59 PM
nothing as long as you do it correctly by always using the highest grade octane 91 or higher. by advancing the timing your firing a little earlier than stock timing and by using higher grade octane which burns slower you can get the best power stroke. what you want is to fire as the piston is just reaching top dead that way you get ignition as it is starting to come down thus providing a stronger power stroke, higher octane burns slower thats why you advance timing on higher octane within reason, sometimes you can end up losing power by advancing the timing or using high octane alone. remember timing is everything.
IceY2K1
424
Jan 17, 2006 01:02 PM
csnow
19
Feb 22, 2004 08:10 PM
stang233
Feb 3, 2004 11:21 AM
krmaxima
83
Nov 16, 2003 08:44 PM
Ceasars Chariot
Oct 16, 2003 01:37 PM
