FSTB Installation
Old Mar 30, 2006 | 07:35 PM
Penguin215's Avatar
FSTB Installation
Ok, so installed it the first time around, and as expected got the knocking like noise, so did the:
NOTE FOR '02/'03 MAXIMAS:
For '02/'03 Maximas, there can sometimes be problems where the FSTB will not clear the intake manifold collector when the car is in reverse which will cause a knocking sound. If this is the case, add the following step between steps 2 and 3 above:
- Place a 3/8" or 10mm washer over each tower bolt.
From the How-To thread, and it still hit, but barely...(if looking at the engine, it's the part towards the driver's side) So I tried doing two washers on that sturt tower. I just took it all off because it still hit, and I didn't want to go for three as I was out of washers, and I wasn't sure if the nuts themselves would have enough grip after that, any suggestions?
Edit: This one if it helps.
Old Mar 31, 2006 | 07:40 AM
DrKlop's Avatar
Driving is the next best thing
Which FSTB do you have? It might be a good idea to try returning it...
Old Mar 31, 2006 | 07:43 AM
SEmy2K2go's Avatar
Go BUCKS!!!
<<< using 3 washers for over 2 years.
ebay FSTB
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
