Replace Brakes/Rotors
I need new brakes/rotors and I finally decided it was time for me to learn how to do it myself. Plus right now I just don't have the money to have a shop to do it.
Anyway I just wanted to know if these are the exactly instructions for replacing my brakes/rotors on my 2K1 Max SE.
http://home.comcast.net/~i1k/2000MaximaBrakes.html
Those instructions are perfect for you. Do not be afraid to get your hands dirty you can do this. Make sure you get the anti-squeal paste on your pad and if you need a caliper piston compressor, Autozone will rent you one for free.
Fat
Fat
Thanks guys, question though. In step 5 the guy removed the Torque Member/Bracket with Pads still in place so that he would know how to install the new pad. If that's the case then I am confused about step 6. It says to Remove both Torque Member Fixing Bolts. Is he showing you what you are going to be removing in step 5 and how to remove it in step 6?
Stupid question I know, I just want to make sure I can follow step for step.
Yeah i actually just did the front brakes a few days ago on an 01, he's right after you get the wheel off its just the two bolts on the caliper bracket- i took the caliper off the bracket adn just hung it and then took the pads out. Get some good anti-sieze to put on the caliper slides too. Its actually pretty important, and make sure the little boot on the slide goes back over the lip on the caliper. It sounds confusing but when you get it off youll know what i'm talking about. I didnt attatch the pin boot to the caliper when i did the back pads, and ive had to take the wheel off and re grease the slides twice cause they were sticking and causing the pads to rub against the rotor constantly.
Originally Posted by dank104
I have this problem...pads lightly rubbing against my rotors after I replaced my rotors and pads. Can you explain what the "little boot" is? I noticed my pads don't move on the slides too easily.
Not to threadjack, but it seems he already has his question answered. I have an 5.5 gen and I'm getting ready to do the brakes. Any thoughts on what pads and rotors to get and where to get them. One of my pad has been grinding my rotor for a week. I may be able to have it turned, but don't know if it's worth the time or hassle. Obviously I can get the parts at the stealer. Can I get the same or better parts at the local auto parts chain. I'm not looking to go BBK and just want to stay stock. Should I replace both rotors?
My front brakes are about gone, and I plan to replace them with Hawk HPS. Also, whenever I slow down moderately or more, my pedal shakes slightly, so I plan to replace the front rotors with Brembo Blanks. I have no idea how much turning costs, but IMO, you may as well get new rotors.
If you didn't want to get anything really performance-oriented, you could get parts from Auto Zone or someplace similar. Just go ask them the prices everything and they'll be happy to help you.
Use that to find all the threads on brakes that people have used. If you have been grinding for a week its probably not worth turning the rotor. Plus you can get aftermarket Brembo blanks MUCH cheaper than Nissan rotors...and they are a million times better. Also, search the group deals, rotors and pads are always on sale by the vendors. Last answer, YES always repace both rotors (or even pads)...never ever only do one side when it comes to brakes. There are much better parts out there than the ones sold at local auto stores. Use this forum, its your best friend to find those parts.
Howdy, long time lurker, first time poster.....
Anyway, quick question for you brake replacement experts. I'm planning on replacing my front pads and rotors with Brembo blanks and ProAct ceramic pads as they're almost worn out. I'd like to do this without bleeding my brakes however, as this seems to be a bit more complicated than I'd like to get into during my first brake replacement job. I had my rear brakes serviced by the local Nissan dealership just over a year ago (Pads, rotors and calipers - took it in the can on that one, I'll tell ya!), so my brake fluid isn't that old.
Is it kosher to skip the brake bleed? Any advice would be appreciated.
I'd say you don't need to bleed your brakes. I plan to change my pads Saturday, and have no intention of doing this. On my last car I changed the pads and never bled the brakes. The only real reason to bleed your brakes is if the brake pedal feels spongy or sinks to the floor when you press it. Or if you disconnect the brake line from the caliper... Good luck!
Agreed, you probably don't need to bleed for just pads. I too just got my hands dirty for the first time. Here's 2 other links to help.
http://forums.maxima.org/showthread.php?t=469787
http://www.motorvate.ca/mvp.php/300
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
