cheap wheel bearings?
Old May 19, 2006 | 07:37 AM
Teufelhunden's Avatar
i had a shop change my hub and wheel bearing not too long ago, like in december. now its may and the same wheel is strating to make that damn grinding noise again. do these cars have a cheap wheel bearing or is it just my car? or did the shop use some cheap wheel bearing? damn i hate this, i just fixed this damn thing!!!
Old May 19, 2006 | 08:22 AM
MaxBoost925's Avatar
Drug Money
I just bought a brand new OEM wheel bearing from Infiniti. I ended up buying a whole new spindle from a dismantler because my screwed up wheel bearing totally screwed up my hub so much so that the new wheel bearing slips in and out of the hub effortlessly.
If you want it, PM me.
Old May 19, 2006 | 09:15 AM
meccanoble's Avatar
Sports Button FTW
i hate having an install done and later the same year it acts up again...i learned my lesson. If i cant do it myself or too lazy to do it myself, get it professionally done and make sure you installer purchases part so it has warranty. I know they normally give 3 months which would suck but maybe mileage will save you? how many miles do they give u for warranty?
Old May 19, 2006 | 01:33 PM
808MAX-SPEC's Avatar
That's weird. Take it back to the shop and tell them to fix it. You paid them to fix it and it wasn't fixed so they need to follow through.
Old May 19, 2006 | 05:00 PM
PeteusMaximus's Avatar
I just got mine fixed and it has a 60 day warranty I hope it lasts......
Old May 19, 2006 | 05:01 PM
which one was bad? Mine was the front left
Old May 19, 2006 | 07:55 PM
sascuderi's Avatar
How do you know wheel bearings are bad?
Old May 19, 2006 | 09:04 PM
its my front passenger side, i did ask about the warranty, but i didnt ask how long, its really weired because the noise is gone now, im praying that it wont come back, but im afraid that it will. im gonna jack the car and shake the wheel just to make sure. the sound is like something is on your wheels and you hear it grinding, like shik, shik, shik, kind of noise. almost sounds like your pads are stuck or something.
Old May 20, 2006 | 04:27 PM
steven88's Avatar
Need A Light?
is this shik shik shik noise more high pitched? as in a rubber duckie squeaking?
under what conditions do you hear this noise? straight line drving? only on turns? etc...
definitely jack up the car and wiggle the wheels
Old May 21, 2006 | 08:30 AM
MAXRB8's Avatar
Wheel bearings are covered under the powertrain warranty (5yr), I found this out after I paid for one at my local mechanic shop but got the other side done under warranty at the dealer.
Old May 21, 2006 | 05:59 PM
are you sure?? power train is, engine and tranny, no?? how could that be coverd for power train??
Old May 21, 2006 | 06:01 PM
its sounds like something is griding, like metal to metal, not high pitched, but medium pitched. ive replaced bearings before so i know what it sounds like. i was just explaining to the guy who was asking.
Old May 21, 2006 | 06:28 PM
It depends on the dealership. I tried and they said powertrain is only limited to the engine. Lucky dogs who got them bearings fixed under the powertrain warranty.
Old May 21, 2006 | 06:30 PM
ctrent86's Avatar
Your car will make a clunking noise when you turn at slow speeds.
Old May 21, 2006 | 06:32 PM
SEturner's Avatar
It is not dependent on the dealership. It is clearly in the warranty terms. It is absolutely covered under the powertrain warranty.
Old May 21, 2006 | 06:37 PM
Noise appears when driving...
- bad wheel bearing = ...straight line and turns
Other problems that sound like a bad wheel bearing.
- worn bump stop caps = ...turns
- loose axle nut = ...turns
- dry drive axle spline = ...turns/ straight line when wet (noise get louder when streets are wet)
Old May 21, 2006 | 07:03 PM
Arek's Avatar
I just had same problem five month ago, brough it to the dealer and they fixed it under warranty and I didn't even know that it was covered under power train.
Old May 21, 2006 | 10:08 PM
Time for me to do some research.
Old May 22, 2006 | 06:18 AM
SEturner's Avatar
Check out the link, specifically under powertrain warranty,Drivetrain top left of page 5.
http://www.nissanusa.com/pdf/warranty/2003_Wrnty.pdf
Old May 22, 2006 | 07:00 AM
MAXRB8's Avatar
I don't understand your question, I didn't dream it! I took it to the dealership with a wheel bearing noise and when I picked it up the noise was gone and the bill said replaced front passenger side wheel bearing with a part # and the price was "N/C". I don't know how else to explain it better. Powertrain includes what makes the wheels drive ( aka drivetrain/powertrain) such as axles and bearings.
Old May 23, 2006 | 11:14 AM
Thanks SEturner. I was able to dig up my warranty booklet(2001) and it does state that Powertrain coverage includes wheel bearings listed under drivetrain. I stand corrected.
Old May 28, 2006 | 05:03 PM
do you know where exactly that says wheel bearings are covered in the warranty? i just want to make sure before i take it in to the dealers. i dont want to get ripped off by them.
Old May 28, 2006 | 05:57 PM
FriscoMaxima's Avatar
how hard is it to put the new bearing into the hub. if i am not mistaken, they are pressed in, right? so how do you take it yout to begin with?
Old May 28, 2006 | 06:21 PM
Arek's Avatar
Please pay attentionn what people said above.
Look at the top of the page 6 at http://www.nissanusa.com/pdf/warranty/2003_Wrnty.pdf
Old May 28, 2006 | 10:04 PM
It's actually on page 5 under drivetrain per SEtuner. Powertrain coverage heading starts on page 4.
For those of you who have 2001 models, powertrain coverage details are listed on page 4 of the 2001 warranty booklet. Other years should be listed in the same area, page 4 or 5, but review your booklets because they lists detailed info.
Old May 30, 2006 | 08:44 AM
you need to take it to a shop with the press, if you have that then it shouldnt be that hard. someone done a write up on it, but i dont have the tools or the press, but if its covered under warranty, then its free.
bbsitum
Sep 6, 2019 07:31 PM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
boomerbrian
Sep 4, 2015 08:25 AM
