5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Dec 26, 2008 | 07:47 PM
  #7361
Nelsito65's Avatar
Originally Posted by sil07
...i thought that was because of the upper intake manifold gaskeT and cold weather, so what do you guys think bad MAf or IACV? it could rev over 3k rpm when it worked so is it the iacv?
Are you getting any codes at all? Is the SES light on? (assuming it is working)
Old Dec 26, 2008 | 09:46 PM
  #7362
mistur_sleepyass's Avatar
this may seem like a dumb question and it has probably been asked before but is the engine code for all the 00 to 03 maximas vq30dek?
Old Dec 26, 2008 | 11:04 PM
  #7363
hi-tek22's Avatar
No, they are different
00-01 is 3.0 L VQ30DE-K - 222-227hp
02-03 is 3.5 L VQ35DE - 255hp
Old Dec 27, 2008 | 07:00 AM
  #7364
VQP0WER's Avatar
Searched my symptoms for my 2000 max were it wouldn't start it would crank but wouldn't turn over and had a weird idle so i cleaned the MAF and the car worked better it would run then it stopped turning on again so my mechanic replaced the fuel pump and again it worked but soon started turning off while driving the vehicle if the rpms weren't above 600, but then agian sometimes it work just fine and not turn off at all sometimes(more often then it turning off), and though it was working it had a terrible idle but i thought that was because of the upper intake manifold gaskeT and cold weather, so what do you guys think bad MAf or IACV? it could rev over 3k rpm when it worked so is it the iacv?
Do you have a check engine light?
Old Dec 27, 2008 | 12:43 PM
  #7365
so if i were to pull an engine from any 00-01 3.0 L it would automatically be the VQ30DE-K?
Old Dec 27, 2008 | 03:05 PM
  #7366
VQP0WER's Avatar
Yes
Old Dec 27, 2008 | 06:26 PM
  #7367
sil07's Avatar
Does now didn't when it wouldn't start unfortunately i don't what it is because im pretty sure it won't last the trip to autozone....
Old Dec 28, 2008 | 10:28 AM
  #7368
here is another dumb question can i bolt the six speed tranny up to the VQ30DE-K?
Old Dec 28, 2008 | 10:39 AM
  #7369
catnap's Avatar
No start condition 2000 maxima
I hope I am posting properly - Anyway my problem is that my max sometimes will not start, it just cranks and cranks without even a sputter. If I try again in a few minutes she starts right up. I have some ignition keys that have not had the chips programed in them and it is like I am trying to use one of them. I have a couple programed keys and this intermitant no start condition occurs with all of them so it's not the keys. SES light is not lit but I do have some other problems like pinging and abrupt change when I cycle on and off the gas pedal. The car used to be much smoother when transitioning from aplying the gas pedal and taking foot off of it. Thanks in advance for any input
Old Dec 28, 2008 | 05:53 PM
  #7370
WildJuice's Avatar
question
Hey all
I have a question: I have an 01 max GXE, which has the all red tail lights, can I install the 2003 SE clear chrome one's without any problem? thanks.
Old Dec 28, 2008 | 06:01 PM
  #7371
mmihalek's Avatar
Help!
I had a code on my 2003 Maxima SE which I was able to get. I followed the instructions on how to clear the code, but when I attempted it, the car won't start now. It will click and the AT Check light will flash, the headlights and fog lights will flash like 8 times and then repeat the sequence, but it won't let me start the car. Any ideas what I can do to get it started again? Thanks for any help you can provide!!
Old Dec 28, 2008 | 06:05 PM
  #7372
Teddie18's Avatar
Originally Posted by WildJuice
Hey all
Yes, you can. They are interchangeable.
Old Dec 28, 2008 | 06:19 PM
  #7373
mmihalek's Avatar
Never mind...I let it sit for a bit and it started up. Whew!
Old Dec 28, 2008 | 06:55 PM
  #7374
WildJuice's Avatar
So I can use any any tail lights from any of the 5th gens?
Thanks.
Old Dec 28, 2008 | 07:16 PM
  #7375
hdmyg85's Avatar
Now that is a lot of brass air fittings http://www.liangdianup.com/subpages/airfitting_1.htm there is just about every type
of air fitting that you could want. Wholesale prices too. I guess these could be used as small water pipe fitting also. I
used some of the parts to make my babington wvo burner.
Old Dec 28, 2008 | 07:18 PM
  #7376
hi-tek22's Avatar
dont forget that he needs the 02-03 tail light harnesses, as the stop light and the turn signal uses different sockets
Old Dec 28, 2008 | 07:19 PM
  #7377
CustomLowz's Avatar
huh?
Old Dec 28, 2008 | 07:44 PM
  #7378
WildJuice's Avatar
Where can I find this harness?
Also are these lights legal, even though there is no red on them? They sell them on ebay in black and clear. They're the Euro style one's.
Old Dec 28, 2008 | 08:25 PM
  #7379
hi-tek22's Avatar
nah they are not street legal....I had all clears on my maxima I drove with my tails all clear like this for close to 2 years Ive long since put back in the OEM ALL RED ones back in. I smoked out the all red ones with VHT nightshade...sorry i dont have a current pic
as far as the harnesses, you want to call either Dave Burnette..who is a parts dealer, and a member here on the .org, he is good with parts and does his best to get the parts to you with EXCELLENT service...or you could go to your closest nissan dealership...the dealership may even have to order them
but they are called "02-03 Maxima Tail Light harnesses"
Old Dec 28, 2008 | 08:53 PM
  #7380
WildJuice's Avatar
Is there an official ruling that says theyre not legal. I really like those lights. What if the brake light is red and the turn signals are orange?
Old Dec 28, 2008 | 11:00 PM
  #7381
Feldman's Avatar
how easy is it to swap in an auto climate control for a manual one? i have an 00 maxima se
Old Dec 29, 2008 | 06:14 AM
  #7382
hi-tek22's Avatar
It still illegal ACCORDING to the National Highway Traffic Safety Administration, you cant have all clear tail lights UNLESS there is some type of red reflector on the bumper.....if you look at any newer car that has all clear "altezza" style tail lamps, they ALL have red reflectors somewhere on the bumper or on the trunk lid. Now as far as the putting a red bulb in FOR THE TAIL/BRAKE light...you can do it, yes......CAN AND WILL YOU GET PULLED OVER FOR IT.......thats hard to say,
Like i said i never got pulled over with mine When i had them close to 2 years, but actually looking at in IN THE BRIGHT OF DAY, even LED's are NOT as visible as they should be...THEY LOOK GREAT AT NIGHT, also, you can expect those LED's to die pretty quickly, if you do opt for the tails....and MOST RED 7443 REGULAR filament bulbs that fit those tail lights will be pretty DIM and pinkish anyway, unless you go for LED's
I'm getting ready to go for these, because i dont really like the blacked out ones on my car...IDK if its because i still have my clear sides and my headlights are cleared....
http://www.ilovebodykits.com/product...X00RPWKS_.html
Old Dec 29, 2008 | 10:09 AM
  #7383
rroderiques77's Avatar
Demodded and Forgotten
May need tuned-up. Also may have bad fuel pump. Have it pressure tested.
Old Dec 29, 2008 | 12:02 PM
  #7384
AbSoLooT's Avatar
Originally Posted by Ahmad_1290
Anyone have an How to on Installing a grounding kit on a 5.5gen?
I responded as soon as your asked this one on the last page..
VQpower, Where did u get all those links like that? looks nice hehehe....
As VQ said, there is a ridiculous amount of info on those links for your hyperground.. I built mine off it with more than enough information. the 3.5 is very similar to the 3.0 which most the links are for.
Stick you head under the hood and you will see the points. Follow instructions, enjoy the HG.
Old Dec 29, 2008 | 07:52 PM
  #7385
Berto210's Avatar
need help with pcv valve. call me blind, but what the diagram shows doesnt appear that way in front of my car. a little help locating it. according to the diagram it should be where everything is circled, but dont look the same!! thanks!
Old Dec 30, 2008 | 01:12 PM
  #7386
AEMAXIMA01's Avatar
not worth it. you have to wire in a bunch of temp sensors, very time consuming. http://forums.maxima.org/5th-generat...l-2k2-2k3.html
also it doesn't matter that you have a 00, it would be just as difficult, no matter what year you have.
Old Dec 30, 2008 | 01:37 PM
  #7387
emBLAZE's Avatar
I have a 2000 maxima gxe and am looking to start picking up some performance bolt ons now that I have a job again.
I'm trying to decide what to get first, a new intake or a ypipe. Cattman no longer has the CAI available for my gen maxima, only the JWolf POP intake - anyone have experience with these in a tropical environment? I live in FL, and am not sure it would be worth getting a warm air intake over a CAI, even when saving $200.
Also, I keep seeing WarpSpeed ypipes for $200. They're the aluminized ones with a ss flex. I can't seem to find any reviews on them, and am not sure I believe their claims of 18-20 hp gains.
To sum up - is a warm air POP intake still going to give me reasonable gains knowing I'm always driving in 80 degree weather or more? Do they have the same awesome rushing sound that CAI deliver? And are these 2" down 2.5" aluminized ypipes by warpspeed a worthwhile purchase?
Thanks.
Old Dec 30, 2008 | 04:16 PM
  #7388
VQP0WER's Avatar
Thats it. The diagram just doesn't show the hose.
Old Dec 30, 2008 | 08:07 PM
  #7389
WildJuice's Avatar
Guys
I got a question: Would 2009 maxima 19' rims fit my 01?
If so, what ya think of these for $1000??
They come with the tire aswell, Goodyear Eagle RS-A 245/40/19. With only 2000 miles on them
thanks
Old Dec 30, 2008 | 08:21 PM
  #7390
maxim2003's Avatar
12v outlet for 2003 maxima trouble shoot
I am new here and want to know how to check my 12V outlets ,because neither one of them is working? Thanks!
Old Dec 31, 2008 | 06:39 AM
  #7391
SoonerFan's Avatar
Cletus
check the fuses under the dash
Old Dec 31, 2008 | 06:40 AM
  #7392
SoonerFan's Avatar
Cletus
Thanks.
y-pipe is the single best performance mod for a 3.0. i had the warpspeed and loved it.
get a berk intake.
Old Dec 31, 2008 | 06:42 AM
  #7393
SoonerFan's Avatar
Cletus
yes.
brakes lights must light and reflect red. as mentioned, if the tails dont reflect, you need a red reflector on the bumper (lexus RX)
Old Dec 31, 2008 | 08:19 AM
  #7394
hi-tek22's Avatar
get a berk intake.
also realistically Y pipes do gains of anywhere from 8-12 HP, i believe
Old Dec 31, 2008 | 10:10 AM
  #7395
marcrobson's Avatar
I have an 08 Maxima (base SE). Am now wishing I had gotten the nav system. If I find someone selling a factory nav system (i.e. a totaled vehicle or someone upgrading to aftermarket), is it possible to install into my Max and still have steering wheel controls, proper climate control/display, exterior temp, trip computer info, etc? That is, would it have all the 'normal' features of the upgraded stereo?
Would the dash need modification?
Old Dec 31, 2008 | 10:25 AM
  #7396
SoonerFan's Avatar
Cletus
Originally Posted by marcrobson
New Question - I have an 08 Maxima (base SE). Am now wishing I had gotten the nav system. If I find someone selling a factory nav system (i.e. a totaled vehicle or someone upgrading to aftermarket), is it possible to install into my Max and still have steering wheel controls, proper climate control/display, exterior temp, trip computer info, etc? Would the dash need modification?
this section is for 00-03 maximas (5th gen)...please post in the 6th gen forum
Old Dec 31, 2008 | 10:33 AM
  #7397
marcrobson's Avatar
sorry - got here by search and did not notice 5th gen forum
Unfortunately I dont seem to have rights to post anywhere except in this thread. I just joined - maybe I will have more rights tomorrow.
Old Dec 31, 2008 | 11:22 AM
  #7398
SoonerFan's Avatar
Cletus
you need 15 posts to start a new thread.
Old Dec 31, 2008 | 11:32 AM
  #7399
Koby's Avatar
You have limited rights to post until you have 15 posts!
I just jhoined too and have a bunch of questions even after I think 3 days reading here!
I just got a 2002 SE loaded with 122k miles, automatic, leather, traction control and need opinions/help on several things.
I paid $7200.00 base price at a used car lot and $8000.00 out the door after fees.
Is that a fair price?
The Car has a history of 2 small accidents in 2004 and 2006 and looks real clean inside and out except for a small rust spot by the passenger side wheel & rear door.
The car is an upstate Ny car as per Carfax and has some rust under the car (expected for a car in this area).
Some problems I found:
  • Drivers side rear parking break cable is frozen.
  • Coolant lines by the oil pan are rusted and one is leaking.
  • Belts need to be replaced.
  • Needs 4 tires real soon (225/50/17 performance tires)
  • Heat shield rattle (gonna rip that off for now) rusted up exhaust but no leaks - will replace later with upgrade or a stock good one that someone wants to let go cheap.
  • Drvers door needs to be adjusted as it makes noise when it hits the latch and will not close easy like the other doors. (it is aligned good with the body lines)
  • Left fog light is broken an will need to be replaced. Ebay?
  • Auto window down buttons not working. (is there a way to set the up?)
  • Trans could use a service. Should I take it to the dealer for that or a trans place?
  • Alarm key fob broke off and only have 1 key
The Used dealer lot said they would look at the brake cable and coolant leak.
The car runs good and is quick but not sure if it had any tune up or other sevice.
What other stuff should I look for?
Any input would be great!
Thanks!
Steve
Old Dec 31, 2008 | 12:23 PM
  #7400
AbSoLooT's Avatar
Whats up Steve, Welcome to cardomain, Here are my suggestions. As for the price. I wouldn't say you got a good deal, definatly not ripped of either. Hard to say without seeing the car. As for the problems you have, they are not major ones, but still quiet a few. They should have replaced the tires, coolant leak, and fixed the cable at least. Heres what I would do as for your problems. Some problems I found:[LIST][*]Drivers side rear parking break cable is frozen.
The first, I had an issue with my parking break cable being frozen as well, which would cause my passnger side (rear) caliper to be stuck. ended up having to replace the caliper. As for your situtiaton, most likely why its stuck and frozen, is because of moisture in the line. YOur local nissan dealership will readjust your parking brake assembly for about 40 dollars. Great thing to do (they did that to my clutch pedal also, which fixed this major problem I could not fiqure out) they will return your E-brake assembly to original OEM specs. Do that first. That may defiantly fix the problem. At how many miles you have. You may mostly likely have to replace your caliper. Common for this many miles for the rears
[*]Coolant lines by the oil pan are rusted and one is leaking.
-Really try and get the dealer to fix this one, if not. . Just get yourself a new hose. Nothing to much to it.
[*]Belts need to be replaced.
At this milage. they are ready to go, do it soon, you dont want it to snap on you...
[*]Needs 4 tires real soon (225/50/17 performance tires)
since the vehicle is already purchased, not much you can do, but pick up some new ones. my generals were125 a piece, good all season tires. (same size as you listed)
[*]Heat shield rattle (gonna rip that off for now) rusted up exhaust but no leaks - will replace later with upgrade or a stock good one that someone wants to let go cheap.
-good idea... no suggestions needd.
[*]Drvers door needs to be adjusted as it makes noise when it hits the latch and will not close easy like the other doors. (it is aligned good with the body lines)- dealership maybe. pending price, or a body shop. For this, you shouldnt expect to pay to much.
[*]Left fog light is broken an will need to be replaced. Ebay?
ebay is okay.... for foglights. Look for aftermarket places that selll parts for the maximas... i have a HUGE list of places, PM if you want it..
Perfect example here...YOu should not have to pay more than 100 for the pair. Tops.... Ive seen em for 76 alot of places
http://www.ilovebodykits.com/product...og_Lights.html
[*]Auto window down buttons not working. (is there a way to set the up?)
-get a new switch, you can replace them seperatly. easy to do also.
I would go to a junk yard. As a matter of fact, i believe i have one for the D side for the 02s that wouldnt fit on my 00
[*]Trans could use a service. Should I take it to the dealer for that or a trans place?
- Look for a known good tranny place to have it recondtioned
[*]Alarm key fob broke off and only have 1 key-ebay!! on this bad boy. on ebay they cost about 15 dollars, and come with programming instuctions.
The dealer ship charges about 80 dollars for this... no need. Ebay for this one for sure. you get a great condition used one, Just keyword maxima, they will be on the first few pages...
My local dealership sometimes has a special where they will look over the whole vehicle for free, sometimes they charge. I would have them just tell you all the problems if you can, than you can be resourceful and look into themfor the best way. For little odds and ends for your car, try the junk yards for sure.. I am in the middle of restoring any little worn and torn anything on my car, besides modding. with the goal of a new appearance, and alot of things i have found there. and im not even going to mention the dollar savings i get to put into aftermarket performance parts.... Good luck, welcome to the .org. PM me if you need the parts list....
