5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old May 12, 2010 | 08:48 PM
  #10641
drumham's Avatar
I need help taking apart my headlight housing so that i can smoke out the trim of the housing!! Help me please! I also need help changing my side marker light bulb!
00 Maxima SE
Old May 12, 2010 | 09:25 PM
  #10642
m.xie's Avatar
I just got my 2000 Maxima GLE and had it inspected. I'm really lucky that, with 160+k miles, the overall condition is quite good. The only problem is the upper strut bearings need to be changed. I'm a newbee that I know nothing about it.
Do anyone can give me a picture to let me know the difference between strut bearing and strut mount? If I want to DIY, will it be very difficult? If the problem is ignored, how serious will it get to be and how can I tell the situation?
Every reply will be appreciated because I need any suggestion from you guys. Thank you.
Old May 12, 2010 | 09:32 PM
  #10643
m.xie's Avatar
Another question, for a 2000 GLE with 163K miles, is it helpful if I use highmileage engine oil? What's the difference will make? Thank you.
Old May 13, 2010 | 06:11 AM
  #10644
exandr's Avatar
m.xie...I would say use the high mileage oil. I have an 03 SE and I use the Mobil 1 10w30 High Mileage. But then again, my car has been burning oil and I just got it. I'm not an expert, but I think you should.
Old May 13, 2010 | 06:22 AM
  #10645
exandr's Avatar
I have a question...who has a list of recalls for the 03 Maxima? I don't think the one I just bought has been taken in for any of the recalls issued, if any.
Old May 13, 2010 | 08:50 AM
  #10646
mdrache's Avatar
2000 i30
Not sure if 2000 i30 questions will get answered, but it's worth a try.
The car start cutting out a few days ago. The codes it threw were P0158, P0159 & P0160. I replaced the MAF and when I started it again it ran horribly for about 5 minutes (would not idle, cutting out when you pressed the gas), and then cleared up and ran fine.
I checked the codes again and got the one for Coolant Temperature Sensor (P0115). This part was replaced about 6 months ago, but I pulled the connectors from both it and the thermal transmitter. The connector on the thermal transmitter was extremely gummed up, so I cleaned it and reconnected it. I then cleared the codes.
I had no SES for about two hours, and then it came back on, although the car ran perfectly. Now four days later, it has started doing the cut out thing again. In addition, in both cases, the fans started running full bore from the moment you turned the car on, whether the AC is on or not.
I just hooked it up at Autozone, and it's now throwing all of the following.
P0115 Coolant Temperature Sensor
p0138 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit high voltage)
p0139 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit slow response)
p0140 Heated Oxygen Sensor Bank 1 Sensor 2 (Circuit condition)
p0158 Heated Oxygen Sensor Bank 2 Sensor 2 (Circuit high voltage)
I bought another CTS and will change it tonight, but I'm wondering whether the thermal transmitter should be changed as well.
Also, I've read different opinions on whether the ECM should be flashed after MAF is changed or whether it's enough to disconnect the battery for half an hour.
Any opinions are truly appreciated.
Old May 13, 2010 | 11:27 AM
  #10647
exandr's Avatar
Is that Block PLate really worth it? Has anyone had any problems with their Max since the install?
Old May 13, 2010 | 12:07 PM
  #10648
NmexMAX's Avatar
dot dot dot ...
That's up to you to answer.
No known issues. Unless you do not follow instructions, but that would be your issue, not the product.
Old May 13, 2010 | 12:33 PM
  #10649
cschnider's Avatar
I tried searching and found these questions asked but couldn't find a definitive answer.
1) Will a 00-01 stock head unit (non-bose) work in an 02? I may just go aftermarket but want to know if this is an option. Right now the car has a cheap pioneer head unit in it that I am not thrilled about.
2) What is required to make 00-01 se tails work on an 02? Some people said you need a new harness, others didn't.
Old May 13, 2010 | 02:31 PM
  #10650
homeyclaus's Avatar
Originally Posted by cschnider
I've been a member for a while but am still a newbie
I'm considering purchasing a 2002 Maxima that was purchased from Canada. It still has the metric guage cluster. What are my options other than just reading the small mph under the larger kph? Would I need to do a full cluster swap? Any idea on cost?
How about the climate control?
If you swap the gauge cluster you'll reset the mileage. Between that and trying to convince your local DMV that the Canadian "certificate of ownership" is the same as a "title" it's more trouble than it's worth.
As far as going to Fahrenheit on the climate control, you can swap out the circuit board with a used one from a wrecker. I could not find a C/F switch in photos of the circuit boards, and while the display as spots for it, for all we know it's hard-soldered to go one way or the other.
I appreciate the metric measures, really, but yeah, the odometer readings really seem to confuse Nissan mechanics and DMV people stateside.
Old May 13, 2010 | 02:36 PM
  #10651
homeyclaus's Avatar
Pick a used one up with your used Fahrenheit-measuring climate control and try it. The other thing to try is to look at online places like Crutchfield's and see if they group harness adapters for stereos for 00-01's differently than 02's.
To get the climate control and the stereo out, there is some guy who has videos on how to do it on YouTube.
There are only two bulbs in each side, one for turn signal and one for tail/brake lights, so I'd say that's unlikely.
Old May 13, 2010 | 02:44 PM
  #10652
homeyclaus's Avatar
Swapping strut bearings pretty much requires removal of the front strut. Most people replace the whole front strut mount, and think long and hard about the strut too.
Cliff's Notes:
Loosen the three bolts at the top of the strut that hold it to the car, mark the two bolts that hold the strut to the knuckle so you're close on reassembly, jack up the side of the car, remove those bolts, unhook brake lines and ABS wire from strut, and remove. I don't remember if you need to compress the spring and stuff to get the bearing out, but it's two pieces of plastic between the top plate and the lower one on top of the strut. Reassemble in reverse order. Repeat on other side.
You can do it, but you'll need a wheel alignment after. It should not be your first DIY car repair.
There are a bunch of threads on this - use search and look for "front strut mount".
Old May 13, 2010 | 04:09 PM
  #10653
digimon001's Avatar
Having problem with my AC fan control. Everything was working fine then last week my fan control stop working correctly. The fan control from 1-3 no longer work but 4 still work fine. So now i either have my AC off or FULL blast. Heat and AC still working fine, I think it might just be the control is broken ?
btw, i have a maxima 02 SE. Everything is stock in the car, head unit and all, so the electrical never been messed with.
Old May 13, 2010 | 04:33 PM
  #10654
cschnider's Avatar
I ended up passing on the car that was brought in from Canada. I found one much closer to home that I'm picking up Saturday. Thanks for the info though.
Old May 13, 2010 | 05:00 PM
  #10655
dtp308's Avatar
Ok is there a secret to removing the clearance light on a 2k2 max. I pulled on the connector but nothing happens a little help, already tried to do a search
Old May 14, 2010 | 05:40 AM
  #10656
SoonerFan's Avatar
Cletus
00 Maxima SE
you have to heat them up so the adhesive loosens up then you can take them apart...put them on a wet towel on a cookie sheet and put it in the over for a few minutes
Old May 14, 2010 | 11:41 AM
  #10657
NmexMAX's Avatar
dot dot dot ...
Does the oven/cookie sheet deal work with 00-01 housings too? 250*F?
Old May 14, 2010 | 01:59 PM
  #10658
rsolusod24's Avatar
Nmex - yes it does I've done it to mine within the last month, only difference between what i did and some of the writeups I've found on the .org and elsewhere was i used a dry towel and i had to "substitute" something for a cookie sheet. (was moving and stuff was packed)
250 degrees, i checked on mine quite a bit just because i had never put anything like headlights in an oven before.
Old May 14, 2010 | 02:04 PM
  #10659
NmexMAX's Avatar
dot dot dot ...
. That's good to know.
I still need to do my 03 headlights...5 years after I got it
Old May 14, 2010 | 02:11 PM
  #10660
matt06's Avatar
hey guys, this is my first post here. just wanted to start by saying i have been on here browsing even before i picked mine up last week. its an 02 with 140 kilometers. i love this car so far, especially when i heard the vq35 came in the 02 with the 6-speed and factory HID's and all the other options, it was hard to pass up
now the issue is my service engine light came on last week but i was wondering how to reset the engine light or if there were any trick ways to get the code or narrow it down without a reader (i am a honda guy and there was a way to do this, but im new to nissan)
this site has been great, ill be around alot more
Old May 14, 2010 | 02:14 PM
  #10661
NmexMAX's Avatar
dot dot dot ...
There is a way to read the codes with the pedal dance, but a reader is so much easier.
Old May 14, 2010 | 02:17 PM
  #10662
rsolusod24's Avatar
i recall seeing somewhere that you could do the diagnostic screw thing on the ECU and read the lights blinking on the dash and get your code that way, but only from 95-99 and 02-03 I THINK....apparently my 2000 won't do it.
Old May 14, 2010 | 02:18 PM
  #10663
NmexMAX's Avatar
dot dot dot ...
That doesn't work for 02-03.
Old May 15, 2010 | 12:50 AM
  #10664
PBMAXX's Avatar
What's a jwt pop? Where do I get one for a 2k0 Maxima?
Old May 15, 2010 | 02:31 AM
  #10665
01-maxima-24's Avatar
Did my 01 headlights just 2 days ago, set the oven to 225* and left them in about 12 mins....i also checked on them a lot since it was my 1st time. I painted the bottom part of the reflector while I was at it to minimize the glare from the HID's I just installed
I used a cookie sheet and wet towel as well
Old May 15, 2010 | 07:35 AM
  #10666
Nelsito65's Avatar
... you don't know what it is, but you wanna get one....
Old May 15, 2010 | 08:22 AM
  #10667
NmexMAX's Avatar
dot dot dot ...
is our friend.
Old May 15, 2010 | 11:36 AM
  #10668
MizzMaxine's Avatar
What are your opinions on the Sarona hood NS-003-HD?
Old May 16, 2010 | 07:48 AM
  #10669
m.xie's Avatar
Thank you for your valuable advice. I will change to high mileage oil next time. Burning oil is really an alloying problem. I just got rid of my 97 Camry because of the oil problem, and only this problem.
Old May 16, 2010 | 07:53 AM
  #10670
SoonerFan's Avatar
Cletus
honest opinion?
ugly and rice
Old May 17, 2010 | 09:17 AM
  #10671
MarkKlooster's Avatar
Originally Posted by MarkKlooster
Is there a specific part to fill in the frame around the radio? Thanks!
Thanks for the reply. I bought the car this way. I think there was an aftermarket sound system installed at one point.
Are there aftermarket accessories that allow for DIN style car stereos to be installed? Where would I find one?
Thanks!
Old May 17, 2010 | 09:24 AM
  #10672
Nelsito65's Avatar
Thanks!
You might want to look into Crutchfield. They have accessories to go with the sound systems they sell that are car-specific. No other place comes to mind now.
Old May 17, 2010 | 12:34 PM
  #10673
Newguy101's Avatar
I am looking to buy my first car, and i have been looking for quite some time, i am just wondering if this car is worth the price for what it has.
I Dont know all that much about cars and their worth, but i love the look of this car, and the fact it has speakers and sub.
Is this car a legit price.. too much? iuno
http://cgi.ebay.ca/Nissan-Maxima_W0Q...item20b0f03f5b
Please help!
Also - if anyone has a car like this for sale if u could tell me about it i would appretiate it.
Old May 17, 2010 | 02:37 PM
  #10674
drumham's Avatar
after that, what do I do to put them back together? do I just push them together and stick it back in the oven and wait for the adhesive to restick and let it cool?
Old May 17, 2010 | 04:44 PM
  #10675
RLNY's Avatar
Im looking to buy an 02 maxima , can anyone tell me whats a fair price to pay for one with under 150k. Im seeing a lot of ridculous prices like 7-8k with over 100k on dash. Is it me or are these people buggin. I could get an 03 for that price. Or add 2k more and just get a 6th gen. KBb is saying 5100 in good condition with over 100k. So why the hell do people want 7k for theirs?
Old May 17, 2010 | 10:38 PM
  #10676
SoonerFan's Avatar
Cletus
reheat them...then hold it together in several places with pliers until it cools and dries...if you dont do it right and the headlights will get water in them and fog up
Old May 18, 2010 | 09:04 AM
  #10677
anggraz's Avatar
Im looking at a wrecked 2000 max auto 3liter, not too bad, only $200. I plan to use it at a local circle track where usually only 2nd gear is used. I cant find it anywhere, does anyone know how fast this 3liter auto will go in 2nd gear?
Old May 18, 2010 | 01:50 PM
  #10678
NmexMAX's Avatar
dot dot dot ...
Depends on the overall diameter of the tire/wheel used. On the correct size, ~ 60 -65MPH.
Old May 19, 2010 | 05:37 AM
  #10679
matt06's Avatar
so about my earlier post, i pulled the code and it was the gas evap code... maybe the gas cap got loose, i cleared it on saturday and it hasnt come back, so thats good
now for the next issue, i know many of you know that the BOSE HU cuts out on the drivers side sometimes and the sub also seems to go out sometimes. Is there a DIY to fix this. i know its not easy but i have done more complicated **** so i dont seem worried plus my dad is an electrical hardware engineer so that helps lol
thanks guys
Old May 19, 2010 | 10:33 AM
  #10680
nespino's Avatar
Transmission Slips 2001 maxima
2001 maxima transmission slippage when I run around town. RPMs go down, push throttle, revs up but car does not move. Check engine light came on, indicated transmission. Dealer says they check it and nothing wrong. Does anyone have any ideas on what it could be? change tranny oil, filters, etc? Any guidance would be appreciated.
