5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Aug 16, 2010 | 02:52 PM
  #11281
NmexMAX's Avatar
dot dot dot ...
Originally Posted by salesgod
Well, then that's disturbing. I was hoping replacing the KS would be the solution to my lack of low RPM performance. If the KS has been replaced and is reporting properly, then it's obviously not the culprit. So the question is, what to look at next.
The basic symptom is that I get very little response until the RPMs hit about 2800. Below that, it really doesn't matter how much I punch it, I get nothing. From what I've read here and other places, KS was a likely suspect, as well as MAF.
So, here's a MAF question. I've read that when the MAF is replaced, ECU needs to be reprogrammed or reset. If the old MAF was bad and I dropped a new one in, would I see immediate results, or would a reset or reprogram have to occur?
Also, how and where is your IAT sensor?
Old Aug 16, 2010 | 03:18 PM
  #11282
VQP0WER's Avatar
Originally Posted by etrmk
Hi,
Some time ago, my a/c got hot and then I finally just guessed that it was lack of refrigerant, so I got one of those recharge cans, fit it onto the "L" cap, but the pressure said that it had enough refrigerant and none would pump into the car.
Above, I read this:
Quote:
turn your car to accessory and turn the AC on cold and listen to hear if the car drops in idle and the compressor kicks on.. its very possible the compressor went bad..
I turned my car to accessory (first turn), but my a/c won't come on until I turn the key one more time to "on". Even then, my car isn't on, so I can't check idle! When I turn my a/c on, the air just comes out. I don't hear anything switch on under the hood, nor do I see the compressor belt turning.
To be honest, when I bought this car, I've never been able to turn on the a/c without the key being at least at the "on" position. 1) Is that a problem with my car? 2) Since I couldn't put refrigerant in it, I wanted to know if it could be my compressor, and how would I know? What are your best practices for this? I have the FSM, but, I wanted to get expert opinions first. Thank you.
Originally Posted by NmexMAX
I see no problems with this. Personally, I'd go with OEM from Courtesy. But that's just me.
Anyone able to help this guy?
For the love of god. The A/C compressor will not start until the car is started. If the compressor does not turn on after car is started, it can be a few things. Low/High pressure, switch, etc. These AC problems are best left to the specialists.
Old Aug 16, 2010 | 03:27 PM
  #11283
djshwini's Avatar
Prob not as important as some of the other problems people are having, but whenever i have to drive the maxi more then 25 min or so, my lower back starts hurting like no other. (Im 17........) Any way to add cushioning in the seat without laying some ugly a$$ thing on top of the leather?
Old Aug 16, 2010 | 03:29 PM
  #11284
NmexMAX's Avatar
dot dot dot ...
I was referring to the O2 sensors post .. ..
This guy was bumping 5 year old threads with those 2 questions, so I moved them in here.
Old Aug 16, 2010 | 03:55 PM
  #11285
VQP0WER's Avatar
Oh...
Old Aug 16, 2010 | 05:21 PM
  #11286
SoonerFan's Avatar
Cletus
adjust the seat/lumbar support
Old Aug 16, 2010 | 07:30 PM
  #11287
djshwini's Avatar
Yeah i tried doing that, didnt do too much. I might have to keep adjusting the seat to see where it doesn't destroy my back.
Old Aug 17, 2010 | 08:05 AM
  #11288
VQP0WER's Avatar
FWIW, I've had lower back issues for years and the seats in the Max do not help one bit. There are times I get out of the car with my entire leg feeling "asleep" and my back hurtin. It got so bad I shoved a small throw pillow down there when I drive any long distances.
Old Aug 17, 2010 | 10:14 AM
  #11289
salesgod's Avatar
Umm, fixing the KS should solve your problem of lack of performance. Sometimes a reprogram is needed, sometimes it is not. It depends on the behavior of the vehicle after said replacement.
I called the service departments at two dealerships. Both said a reprogram is not necessary after replacing the KS.
Since the symptoms didn't go away, I have to assume that replacing the KS wasn't the solution. What to try next...fuel filter? I can't really see how a clogged fuel filter would cause my problem, mainly that the car lags until it hits 2800 RPM, when there is a noticeable surge in power.
Here are the codes the car has had since I've owned it:
P0135 - B1S1 O2 Code - Replaced front sensor, code did not return
P0430 - Bank 2 precat - Replaced precat (it WAS bad), code didn't return
P0140 - B1S2 O2 Code - Replaced spark plugs, reset code, it returned once, I reset it. Hasn't returned.
P0325 - KS "ghost" code - Replaced KS, cleaned throttle body, etc.
Couple of questions. Could the P0140 code (rear O2) signal the ECM to run lean? If the code isn't present, shouldn't the ECM revert to a richer mix? The consensus seems to be that a rear O2 monitors cat function, and the forward O2 is a more accurate measure of the proper fuel mix. A P0140 shouldn't be affecting overall engine performance, right?
Conventional wisdom also says blame the MAF (which has been replaced previously -- by the dealer, with an ECM reprogram -- and cleaned), but I would think a failing MAF would continue to degrade and performance would get worse over time.
Engine doesn't have noticeable knocking, but does exhibit some injector "clicking". Thoughts for what to try next?
Old Aug 17, 2010 | 10:23 AM
  #11290
NmexMAX's Avatar
dot dot dot ...
Ah yes, I was referring about the MAF regarding the reprogram, sorry about that mis-clarification.
Have you checked your IAT sensor and verified that it is attached to the intake tubing in its proper place?
And how did you replace the KS? Did you remove the IM and use a torque wrench to properly torque it onto the engine?
Old Aug 17, 2010 | 10:24 AM
  #11291
salesgod's Avatar
I checked the IAT sensor per your previous advice. It's attached, not dangling, and isn't throwing any codes (these would be P0109-P0114).
If I had an IAT issue, wouldn't it present a code?
Old Aug 17, 2010 | 10:27 AM
  #11292
salesgod's Avatar
Yes, on the KS. IM was removed (that's a PITA), gaskets replaced, TB cleaned while it was apart. Properly torqued.
And, BTW, you're quick with the responses! Thanks!
Old Aug 17, 2010 | 10:36 AM
  #11293
NmexMAX's Avatar
dot dot dot ...
Good man on that KS job. One of the few that does things right.
Any luck locating that IAT sensor? Should be in near the MAF, in between the MAF & TB.
Old Aug 17, 2010 | 10:47 AM
  #11294
salesgod's Avatar
My understanding is that the IAT on the 2002 and later is built into the MAF. On the 00, it's located in front of the filter box. If I'm looking in the right place, it's properly attached.
Old Aug 17, 2010 | 10:49 AM
  #11295
NmexMAX's Avatar
dot dot dot ...
That's correct on year difference, and well that shoots down my other theory.
Old Aug 17, 2010 | 10:57 AM
  #11296
salesgod's Avatar
That's a shame, 'cause I'm pretty low on theories over here too!
Old Aug 17, 2010 | 02:21 PM
  #11297
VQP0WER's Avatar
Your car is a manual tranny?
Old Aug 18, 2010 | 06:28 AM
  #11298
NmexMAX's Avatar
dot dot dot ...
Old Aug 18, 2010 | 12:48 PM
  #11299
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 2k1seae
I just bought a 2000 Maxima SE. The doughnut is in the trunk but no tools are in with it. Is there a separate compartment for the tools? Thanks in advance!
It's on the right (passenger) side removable compartment in the trunk.
Old Aug 19, 2010 | 06:01 AM
  #11300
VQP0WER's Avatar
Originally Posted by Little John
Simple question: while researching some potential fixes for my pinging (it's been doing it for about 100K miles now, since I bought it), I keep seeing that people are replacing their MAF. What is it??? Thanks -LJ
Mass Air Flow- it just measures the amount of air going into the intake.
Old Aug 19, 2010 | 03:31 PM
  #11301
00Blacked's Avatar
2000SE (trans problems)?
I have a 2000 SE with warpspeed y-pipe and EVo2 catback. up until recently i had no problems with any of the exhaust after about 6 months one day i park my car get out look at a car on the Nissan dealers lot.. get back in.. and my car will barely move... I can't accelerate above 2000rpms. have no reverse and seemingly no 1st gear.. to my knowledge their on the same "gear" if you will and some say its a "safe mode" however OD light doesn't flash. I have never gotten a solid answer on how i might get it out of "Safe mode" if it is in that. and i have never gotten a full run down on a proper 2000-2001 ECU reset either... i found the 02-03 one.. maybe im just terrible at navigating or maybe they're not clearly posted anywhere.. however all fluid levels are good.. i've only ever used 91 octane in it. and as far as a complete flushing of the fluid i honestly can't say i know when it was redone... all i know is.. the engine starts and runs just fine. no stuttering or rough running.. just when i put the car in Drive it seems very bogged down and only revs up to 2k RPMS and reverse just doesn't work at all.. The problems didn't come slowly losing gears or anything of that sort.. it all stopped at once.. in a literal 45 second time frame.,, sorry for a huge post.. but any help would be awesome
Old Aug 19, 2010 | 05:57 PM
  #11302
Sternzy's Avatar
2000 Nissan maxima
After researching for a week or so I haven't really found a definitive answer for the p0171 code (lean bank 1).
The actual symptoms of this code are presently rough cold starting. Throttle response seems exelent once it is warmed up, though the idle can be a little rough it is nothing that say a novice would probably even notice.
After looking the car over this past week and learning all the functions of my code scanner and such, I have noticed a few things...
Cat, and o2 sensor monitors are n/a even after an hour of driving. Now I'm guessing the cat monitor being n/a could be directly related to the o2 monitor not being available.
After reviewing the live data on my Actron 9180 I have found that at a flat idle my o2 sensors look like this, through the entire 35 frames or so:
o2s11 - 0.000
o2s12 - 0.240
o2s21 - 0.000
o2s22 - 0.250
11 and 21 do fluctuate when the idle is revved but still lower then spec i believe. Am I understanding this correct in that i have two bad sensors, and two others that are on their way out?
I have cleaned the MAF, and for the data recording it averaged 1.8 - 2.0 throughout the recording. I also cleaned the air filter, and will be getting a new one, along with a new fuel filter tomorrow before I get into buying new o2 sensors.
Two other things I should mention:
First, the air duct on this car is a mess. The air-box containing the filter is fine, other then the dry rotted seal that attaches it to the scoop. Is this air-duct a priority to repair? The entire rest of the engine compartment looks immaculate, but for some reason this intake scoop is a mess.
Second, when reeving the car from under the hood I can hear a suction noise coming from somewhere around the bank one side, though as hard as I tried I couldn't pinpoint where it was coming from. For all I know this could be a normal noise the coming from the intake as more air-flow is being sucked into the system. I did read about a bad intake gasket on these cars though so i thought I would mention it, where I am having a lean condition.
Thank you in advance for any help!
P.S. Is it possible to still buy aftermarket MAF and o2 sensors which are OEM and do not require a dealer ECU reprogram? If so what differentiates the two seperate models? Maybe an "a" or a "b" in the part #?
Old Aug 19, 2010 | 07:09 PM
  #11303
djshwini's Avatar
Is it possible to plug and play a 6.5 inch sub to replace the stock bose sub? There are alot on amazon that are pretty cheap and i am sure they are a lot better then the stock sub.
Old Aug 19, 2010 | 07:39 PM
  #11304
jusecar's Avatar
Compression Ratio
Hi Guys,
I'm currently looking into a 2001 Maxima, and just want to be sure that the mileage hasn't been messed with. I am planning on running a compression test on the engine. I was wondering if anyone knows what the compression ratio should be if the car is around 120,000 kms (75000 mi). I know brand new it is at 10:1, but I'm not sure what it should be at when its a little worn out.
-J
Old Aug 19, 2010 | 08:40 PM
  #11305
arcueda's Avatar
so ill figure ths out tomarrow...but if someone could answer me before then it would be greatly appreciated
my clutch petal has been dying off for a few months. noticed some fluid on the lower clutch line.
figured it was my line/slave cyl
bought a ceramic coated ss clutch line.it was the upper (my bad)
just bought a slave cylinder(i will do a small write up if my questoins answered)
bled the brakes properly
clutch pedal is still dead to the floor.
(ive searched)
what am i doing wrong?
thanks, jason
Old Aug 19, 2010 | 08:51 PM
  #11306
prizmeye's Avatar
Need Longer Disconnect
Originally Posted by homeyclaus
When you install new sensors and whatnot, a good mechanic will disconnect the battery for > 10 minutes the swap takes. That will reset the ECU.
There is an idle re-learn procedure listed in the FSM as well, although IIRC a MAF swap should not need that.
Haynes manual (also Nissan FSM? Don't recall exactly) says you need 24 hrs to clear the ECU. I believe them, as my ~45 min. disconnection did NOTHING. The codes were STILL STORED.
Old Aug 19, 2010 | 10:36 PM
  #11307
showtime's Avatar
2001 20th anniversary question
So I bought my 2001 20th anniversary edition 5 speed about a month ago it's the Icelandic pearl with black leather interior fully loaded heated seats the whole 9 yards and only 71,111 miles... This is my third max and needless to say it runs like a charm, anyway I was jus wondering if anyone knew whether or not a factory bra would fit the car considering the lip kit in the front? If anyone knows holla. Thanks
Old Aug 20, 2010 | 06:44 AM
  #11308
sontakke's Avatar
Sternzy,
All of your issues are because of the air leaks. Our cars are equipped with MAF, any air leak will cause problems in the fuel metering. Please fix them one way or another. Even a duct tape might be better if you can not afford to get the new ducting!
- Vikas
Old Aug 20, 2010 | 10:25 PM
  #11309
djshwini's Avatar
Sorry if this is a dumb question, but to remove the driver and passenger seat, do you just unbolt the 4 bolts on the bottom of the seat, or are there connectors for example to the battery for the pwr seats.
Old Aug 23, 2010 | 07:06 PM
  #11310
efanatic's Avatar
There are 5 bolts that hold the seats in. Just undo those and there are a few connectors to undo on the bottom. Not a big deal . I had mine out in minutes
Old Aug 24, 2010 | 09:54 AM
  #11311
SEMaxima2000's Avatar
dumb and vague question
I have an 01 anniversary edition, and my car shuts off some times whenever I have it in park, it doesn't do it all the time just sometimes, but it doesn't do it if I have it in drive and just sitting there, its been doing that for a little while and my check engine light just came on this morning, does anybody know what could be the problem, any help is appreciated thanks
Old Aug 24, 2010 | 10:32 AM
  #11312
SoonerFan's Avatar
Cletus
Originally Posted by jusecar
Hi Guys,
-J
to pass a compression test, all the cylinders just need to be close...if one is way off, the rings are bad
dont think it will fit...and bras are a terrible idea and worse for the paint...dirt gets drapped under it and rubs the paint
wire harness for power seats (and heated if equipped)
Old Aug 24, 2010 | 11:16 AM
  #11313
NmexMAX's Avatar
dot dot dot ...
From the FSM,
Standard is 185 psi, minimum is 142 psi, and the difference between cylinders should be no greater 14 psi.
Old Aug 24, 2010 | 03:31 PM
  #11314
cool_A-Ksuited's Avatar
NMEX ... Im sorry to bug you with this ... but how do I search for a thread anything related to ...
Well when I turn my car off and remove the key, the dashboard lights up and the radiator fan stays on... I have to remove the negative post and then I can start the car up fine again. The pre-lude to this was 5 days ago i stomped on the gas the car acted like the engine was dieing and i pulled over and noticed these symptoms.
Old Aug 24, 2010 | 04:58 PM
  #11315
SoonerFan's Avatar
Cletus
From the FSM,
thanks...dont have the FSM on this computer and couldnt remember the allowable difference
i know when i had it on my oil burner, two were under 130
Old Aug 24, 2010 | 05:37 PM
  #11316
ataris7's Avatar
I have two questions...I had a '92 Toyota Camry with 262,000 miles and have upgraded to a 2006 Maxima SE. Since getting the vehicle I have noticed a grinding noise when accelerating around 1500 rpm. It goes away once either above or below 1500rpm and only makes the noise during acceleration. I read some threads about a exhaust bracket or something. Where is this located...I don't know really my way around so a description and a picture would be helpful.
2nd question: The front bumper doesn't have a mounting point for a license plate, and previous owner drilled holes into the bumper to mount license plate...only foam behind so no way to keep license plate from falling off? Any suggestions how to mount properly and cover holes without plate falling off?
Old Aug 24, 2010 | 05:40 PM
  #11317
pmohr's Avatar
No more Maximas...
There was a TSB about an bracket/clamp at the base of the rear pre-cat, or maybe it was for the heatshield.
Self-tapping screws should work fine just run into the front bumper, there's not much force acting on the license plate during driving.
And just FYI, this is the 5th gen section ('00-'03), your car is a 6th gen.
Old Aug 24, 2010 | 05:43 PM
  #11318
ataris7's Avatar
sorry one other question. I have the engine light on, and have had it reset twice for O2 sensor. Is it really important to replace the O2 sensor... or having the engine light continually on a big deal?
Old Aug 24, 2010 | 05:45 PM
  #11319
ataris7's Avatar
Sorry thanks will post to 6th generation thread
  #11320
pmohr's Avatar
No more Maximas...
A faulty/lazy O2 can significantly affect your fuel mileage as well as performance at part throttle. Are you sure it's actually an O2 sensor code, or is something else causing it? Have you tested the sensor?
