5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Sep 21, 2011 | 12:53 PM
  #13921
derp's Avatar
so... half of my dash lights don't work. the tach half.
can't seem to find a fuse in the fusebox for dash lights... am i just stupid? seem to have found suggestions to check like... tail light fuses and stuff? but that was in the 4th gen forum....
any advice?
Old Sep 21, 2011 | 03:37 PM
  #13922
DennisMik's Avatar
The fuse for the dash lights is under the hood by the battery, but this isn't your problem. All the dash lights, the lights in the heater control, the shifter, all the switches that light up, the glovebox, the ash tray and more all come from one fuse.
What you probably have is a burned out lamp in the instrument cluster, right behing the tachometer.
Old Sep 21, 2011 | 07:50 PM
  #13923
arkangelgabriel's Avatar
kidsweb i had the same problem when i got my 01 maxima. check all your fuses one by one and replace any blown one. and yes theres two separate fuses for both power outlets
Old Sep 21, 2011 | 08:00 PM
  #13924
i have a situation with my maxima as well. aside from having to replace my transmission speed sensor lol but i already know how to. However i had vibration while braking at 60+, thought i had warp rotors so i had them turned and vibration sill there. less but still there and now i can feel like something is loose on the front end. check everything and looks good and tight. ive been meaning to change my tie rod ends since the car makes a clunking noise on small bumps, wondering if it may be something else and if its related to my braking shake problem. any suggestions?
Old Sep 21, 2011 | 08:28 PM
  #13925
piggylover1985's Avatar
Don't forget to check the rear rotors as well as the rear caliper make sure that they're not kind of stuck.
Old Sep 21, 2011 | 09:29 PM
  #13926
derp's Avatar
awesome. sounds like fun.
thanks for the heads up.
Old Sep 22, 2011 | 10:04 AM
  #13927
DennisMik's Avatar
The second time you do it, it's a half hour job. You'll discover it's a lot easier than you thought.
Old Sep 22, 2011 | 10:13 AM
  #13928
Sylcurt's Avatar
Repairs now done...
Picked up my 2000 Maxima last night, with them changing the coils, and the MAF, along with fuel injector flush and iacv. They also did an idle relearn process, and a throttle boddy cleaning.....I wanted them to also to a fuel filter change, since it has never been done in the car since new, but they forgot I guess.
The car seemed to run very well, however, it always does for several weeks after work has been done. (this is my second set of replacement coils after the original ones, and my 3rd MAF after the original one) In the past I've always used aftermarket parts, this time, went with dealer OEM parts, so we'll see if any different this time. The idel relearn is also something that I had never done in the past, when I changed the above parts...
My questions:
I had bought the two little gaskets for the throttle body and the fuel filter, and was going to do them myself, before all the problems got bad and I had to take the car in. They said they cleaned the TB, but did not use any gaskets - is that going to be a problem, or is that telling me they really didn't take anyting apart, and probably just sprayed some cleaner in there? I would think that if totally removed and cleaned on the bench, that they would put in the new gaskets when re-installing?
And even though I had the fuel filter, and asked them to change it, they forgot...do you think this is a job a shadetree mechanic (me) can do? I think if anything, its good maintenance after 11 years..
I will keep you posted if the SES light comes back on, and what codes , if any, come back....as I said, these parts have all been changed in the past, seemingly helps for a while, then stalling returns.
Total repair bill was not much less than the value of the car...ouch!
I must say, highway throttle response is clearly improved, but low RPM idle seems to resonate through the car more now???
As long as it doesn't stall, I am happy...for now anyway.
Old Sep 22, 2011 | 10:27 AM
  #13929
djfrestyl's Avatar
Suspension Yoda
For the gaskets - I would ask them very bluntly what exactly they did. If all they did is spray, then it sounds like you're either getting some money back, or giving it back for them to do the right way.
For the fuel filter - it's definitely doable with some basic tools and basic knowledge. There's a how-to floating somewhere around this forum. Good luck!
Old Sep 22, 2011 | 02:53 PM
  #13930
20thAE Joe's Avatar
2 questions...
Hey everyone glad to be a member I have loved my maxima since I got her in 01 . Beautiful Car with quite the soul. I am glad I found this forum just wish I would have found it sooner cause I already bought an injen CAI about a year and a half ago... But
1. Is there anything I can do to make it gain any performance? I actually feel like I may have lost some power but the noise is pretty nice.
2. My front brakes (i think) are begining to squeek it comes and goes randomly... Not really sure what it is but I am pretty sure its comig from the brakes. Sometimes it makes the noise when off the break and just cruising other times it will make the noise when I have to hit the brakes.. Anyone have any idea? I brought it to a couple shops and they said that the pads are fine and the rotors look ok others say I need new both rotors and pads so I really dont have a clue
Old Sep 22, 2011 | 04:26 PM
  #13931
syrlup i thought maximas had no fuel filter. well fuel filter with the fuel pump inside the gas tank. make sure your maf sensor is in good shape to!
and 20th joe that goes for you to. lack of power may be cause of bad maf sensor. i had gotten a 2nd generation one for my 01 max and when i burned it and got a stock one i fell the drop on power. and the breaks...well you can check them yourself. or if you trust they good according to what you were told then it might just be lack of lube on the outside plate of your brake pads. you can get the lube (looks like gel, they sell them at any auto part store) and apply it to the back or outside part of your brake parts.
Old Sep 22, 2011 | 05:45 PM
  #13932
tron2012's Avatar
Hi I just registed for this fourm last week and It wont let me post anything does anyone know why?
Old Sep 22, 2011 | 06:10 PM
  #13933
Nelsito65's Avatar
When you registered, there was a message that stated the amount of posts you need to have before you can create a thread (I'm not sure how many posts you need these days). Until you reach that number, you can post your questions or comments, just like you did in this thread. This particular thread was precisely created for that purpose.
Old Sep 22, 2011 | 06:16 PM
  #13934
djfrestyl's Avatar
Suspension Yoda
It also encourages new users to SEARCH because likely, their questions have been answered countless times before in existing threads.
Old Sep 23, 2011 | 10:56 AM
  #13935
Sylcurt's Avatar
Yup, its the one i the gas tank that I have, and will change. Can't hurt....MAF sensor and entire assembly was changed for a new OEM Nissan one...so should be ok for a while (I am hoping)
Old Sep 23, 2011 | 02:18 PM
  #13936
00MaxMayne's Avatar
I need to replace my outer tie rod on my passenger side. Is it required to do both sides inner/outer at the same time? Or would I be fine with just doing both outer tie rods, or even just the one that needs to be replaced? Thanks in advance.
Old Sep 23, 2011 | 03:00 PM
  #13937
DennisMik's Avatar
There is no requirement to do them in pairs. If you want to, fine.
If you want to only replace the one(s) that is bad, fine. The only argument that can be used against this is that you have to get the front end aligned when you replace a tie rod end. Tie rod ends aren't that expensive to replace them all and only get one alignment.
It all depends on how much of a gambling man you are.
Old Sep 23, 2011 | 03:05 PM
  #13938
00MaxMayne's Avatar
Ahh well that makes things easier on my pockets. I think I'll go ahead and get the one side replaced, and I had gotten an alignment about a week ago at FireStone so maybe if I take it there to get the work done then they'll re-align it under warranty or something. Or am I hoping for too much there...
Old Sep 24, 2011 | 05:54 AM
  #13939
djfrestyl's Avatar
Suspension Yoda
It's actually a very easy job anyone can do.
If you went to Firestone why didn't you get the lifetime alignment?
Old Sep 24, 2011 | 06:23 AM
  #13940
hey 00maximain to be honest with you i recomened you change both inner and outter tie rod ends. depending how many miles in your car thou. but since you gotta get a front end aligment and your old tie rod ends will go bad (mine are bad and planning to change them all soon). i know it may be more money but i think its worth it. Also i recommend you get parts from nissan. yes they are more expensive but think its best (DO NOT take it to the dealer thou, they will charge you A LOT of money for something that can be easily done yourself)
Old Sep 24, 2011 | 06:26 AM
  #13941
By the way i just discovered yesterday a minor oil leak on my 01 maxima. i can see it comes from the back top passanger side of the engine on the base of a metal tube thats wrapped with foil. im guessing theres a gasked that went bad? any ideas?
Old Sep 24, 2011 | 08:47 AM
  #13942
buddywh1's Avatar
.. can see it comes from the back top passanger side of the engine on the base of a metal tube thats wrapped with foil. im guessing theres a gasked that went bad? any ideas?
Not sure what you're talking about... is it actually on the engine? or the shock tower? That could be an A/C line... maybe the pressure switch. Leaking a little refreigerant oil maybe?
A picture or something would help.
Old Sep 24, 2011 | 08:49 AM
  #13943
02nissanlover's Avatar
oops posted this in the wrong section, so here is where it needs to be.
i have a question... i have a 02 maxima 6 spd, in the entire rpm range i get a weird clicking/ticking sound. the higher the rpms the louder it gets, the only mods i have done are a CAI and 2 1/2 in exhaust. the higher octane gas i put in the louder it gets. the ticking sounds are so close it sounds like its a continuous noise. im kinda worried about it. i have no loss in power at all. i added a octane booster and it just got louder. i can now hear it over my exhaust now. and my exhaust is LOUD.
Old Sep 24, 2011 | 11:58 AM
  #13944
DennisMik's Avatar
I think that the leak is your high pressure power steering hose. It is wrapped in insulation to try and protect the rubber from the engine heat.
Old Sep 24, 2011 | 12:16 PM
  #13945
yeah power steeting house sounds right. must not be leaking much since my power steering fluid has not gone down. to be more clear (dont have a pic yet...would be hard to take anyways) the hose attaches to the engine on the bottom right side just above cv shaft. it leaks down to a o2 sensor and to the cv shaft itself (thats how i noticed oil leak) im pretty sure the oil is coming from where the hose bolts onto the engine. kinda like a regtangle shape base with two bolts. ill c if i can take a pic
Old Sep 24, 2011 | 03:23 PM
  #13946
01a33's Avatar
'01 maxima "mysterious" electrical noises.
Question: I've got an '01 20th with 120,000 on the clock and just noticed recently that whenever the car is running and throttle is applied, i hear some kind of electric motor actuating in repetitions of 6 in the nose below the airbox somewhere...Anybody got any potential solutions?
Old Sep 24, 2011 | 04:54 PM
  #13947
DennisMik's Avatar
What do you mean by "the nose"? Is this inside the car or under the hood?
Old Sep 24, 2011 | 08:34 PM
  #13948
Newly MAxxeD's Avatar
Clutch
ok So im new to the Maxi world. I just bought a 2000 Maxima 5-speed. when in first got it the clutch pressure was really stiff. now it is very soft and i feel like i need to press it though the floor. Any suggestions on what to try or do?
Old Sep 24, 2011 | 09:07 PM
  #13949
djfrestyl's Avatar
Suspension Yoda
Check your master/slave cylinder. I *think* it's a common problem but not 100% on that.
Old Sep 25, 2011 | 05:03 AM
  #13950
Check the fluid level. If you put it in 1st gear and hold the clutch in, does it hold or the car gradually move forward even with the clutch pedal to the floor ?
Old Sep 25, 2011 | 08:12 AM
  #13951
DOODOOCHIP's Avatar
hi guys i have a question. on my 03 gle i would like to but back my original bose cd player since its a 6cd changer and take out current aftermarket deck that previous owner installed. Have anyone done this, im just curious if i need to buy a harnest or i can just plug it back in as is?
Old Sep 25, 2011 | 08:46 AM
  #13952
The car holds still. and the fluid doesn't seem to be leaking out anywhere but i will do some more looking.
Old Sep 25, 2011 | 09:23 AM
  #13953
block215's Avatar
Hi, I have an issue where whenever I drive the car for like the first 15 mins no matter the weather I stop at a light or stop sign & if I take my foot off the break or gas while in drive the car will just sit there like in neutral. When I press the gas the car wont move but if I tap it a few times it will move but the car has to like jump back into gear, its weird..only happens when I first start driving for the day..
Old Sep 25, 2011 | 09:26 AM
  #13954
DennisMik's Avatar
It all depends on what the previous owner did. Bose speakers are different from the rest of the electronics world, so he could have taken the Bose speakers out. The Bose head unit can't run the standard 4 ohm speakers. Also in the dash, did he cut the wire harness connectors and splice wires or did he use adaptors? Then we have the radio mounting. Best case all you will need are the special screws that hold the head unit in. Worst case - who knows. If you have any Maxima friends that know the Bose details and can look at your car, that would be extremely helpful.
Old Sep 25, 2011 | 09:47 AM
  #13955
DOODOOCHIP's Avatar
well what i got is this, previous owner took out the head unit and put it amp and a sub. Now that the aftermarket deck is slowly dying i gotta replace it, plus the sub is huge and heavy i just want to take everything out and go back to old stock system. i guess i got lots of work to do
Old Sep 25, 2011 | 10:40 AM
  #13956
COil
My ses is on and codes all lead to the coil. I have read on the posts about checkin the coils. I have looked them over and the one in the 3rd firing order or middle one in the back well the insulation boot has came off and is stuck. Any opinions if this could be the main source of my coil issue and does anyone know the best way to get it out?
Old Sep 25, 2011 | 02:02 PM
  #13957
00MaxMayne's Avatar
I'm currently in the process of changing my outer tie rod on my 00 GLE. But the nut that supposedly connects the outer tie rod to inner seems to be just a part of the outer tie rod that's there. So basically there's no loosening the nut then simply unscrewing the outer tie rod, so when I turn the outer the whole piece (inner and outer) turn. Basically I'm unable to remove the outer.
How can I do this? I need the car to drive back to school in a couple hours :-(. Am I seeing things and the nut and tie rod really aren't one? Or is there a way to remove this... Help pleaseee
Old Sep 25, 2011 | 02:05 PM
  #13958
DennisMik's Avatar
If he took the Bose speakers out, you would probably be better off using a non-Bose head unit. It would be a lot less work.
Old Sep 25, 2011 | 02:12 PM
  #13959
DennisMik's Avatar
Maybe, maybe not. The coil broke when you took it out, before that it was ok. If any of the codes were P0301 thru P0306, that is a bad ignition coil. The last number, 1 thru 6, is the cylinder number.
Old Sep 25, 2011 | 02:21 PM
  #13960
candt's Avatar
Does rain-x break down? I have a bottle from 1998, is this going to be safe to use or do I need to chuck this?
