5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Sep 25, 2011 | 02:26 PM
  #13961
DennisMik's Avatar
Originally Posted by 00MaxMayne
I'm currently in the process of changing my outer tie rod on my 00 GLE. But the nut that supposedly connects the outer tie rod to inner seems to be just a part of the outer tie rod that's there. So basically there's no loosening the nut then simply unscrewing the outer tie rod, so when I turn the outer the whole piece (inner and outer) turn. Basically I'm unable to remove the outer.
How can I do this? I need the car to drive back to school in a couple hours :-(. Am I seeing things and the nut and tie rod really aren't one? Or is there a way to remove this... Help pleaseee
That nut is a separate nut that is used as a lock nut for the tie rod end. It is evidently corroded to the tie rod end. You'll have to uses lots of Liquid Wrench or PB Blaster or WD40.
Old Sep 25, 2011 | 03:01 PM
  #13962
00MaxMayne's Avatar
Alright, I figured that. I went and bought some PB blaster because the WD40 wasn't getting the job done. I guess I'll let that sit for a bit then go back at it. When I turn the nut I should be turning it clockwise which would be moving it away from the outer tie rod correct?
All these "quick and easy to-do" jobs manage to be a royal PITA for me and my car. Rust galore is terrible for working with.
Old Sep 25, 2011 | 03:40 PM
  #13963
djfrestyl's Avatar
Suspension Yoda
If he took the Bose speakers out, you would probably be better off using a non-Bose head unit. It would be a lot less work.
Why downgrade?
Old Sep 25, 2011 | 09:24 PM
  #13964
landon.256's Avatar
I own a 2001 vq30 5 speed maxima and am thinking about putting the 6 speed out of the 02/03 vq35 maximas in it... Will it bolt right up?
Old Sep 26, 2011 | 01:08 AM
  #13965
JuiceyMAX's Avatar
hey guys, just bought myself my first maxima, it's an 02 auto. i love it!
Looking to do a CHEAP/INEXPENSIVE pop charger (looking to keep it mostly stock) any suggestions?
also, looking for an inexpensive front lip, any suggestions on where to look?
Old Sep 26, 2011 | 06:36 AM
  #13966
landon.256's Avatar
I got my lip from stollen and love it
Old Sep 26, 2011 | 07:08 AM
  #13967
landon.256's Avatar
Stillen**
Old Sep 26, 2011 | 12:16 PM
  #13968
McSteve's Avatar
Is there a way to tap into the manifold to get manifold vacuum pressure? I can't tap into my intake piping and am wondering whether I could splice into the evap hoses or any of the other connections on the back of the DEK.
I need to reconnect my power steering vacuum and also will need a vacuum line for a BOV in future
Old Sep 26, 2011 | 03:18 PM
  #13969
DOODOOCHIP's Avatar
hey guys,im planing on changing my turn signal to a clear lens and would like to know if anyone here done it. i looked online for a clear lenses to replace current ones but cant find anything, maybe someone has a link or something. im kind of scared doing cuz my friend melted his headlights in the oven :S
have anyone installed CAI on automagic tranny
Old Sep 26, 2011 | 10:30 PM
  #13970
03Curiel's Avatar
My 03 maxima is having the same problem with the O2 sensor and the 0139 code i want to know how much does it cost for the reprograming of the ECU
Old Sep 27, 2011 | 05:28 AM
  #13971
djfrestyl's Avatar
Suspension Yoda
^^ Cold Air Intake on an auto tranny?
Transmission doesn't matter for intakes. And yes, PLENTY of people have.
Old Sep 27, 2011 | 06:34 PM
  #13972
randalk's Avatar
iat sensor location 3.5
does anyone know where intake air temp is measured on our cars? is it incorperated into the maf? thnks
Old Sep 27, 2011 | 07:03 PM
  #13973
djfrestyl's Avatar
Suspension Yoda
There's another sensor on the intake that measures Idle Air Temperature. It's called the IAT sensor
Old Sep 27, 2011 | 08:24 PM
  #13974
randalk's Avatar
ok that sort of awnsers my q but, where specifically is it, i finished my custom CAI today and wanted to hone in on accuracy of iat sensor, if its located on the mnifold itself then ive done a pretty good job of cooling that air dwn.
Old Sep 27, 2011 | 08:35 PM
  #13975
scarface4522's Avatar
the iat is on the maf sensor
Old Sep 28, 2011 | 05:48 AM
  #13976
djfrestyl's Avatar
Suspension Yoda
What is the sensor on the snorkel then?
Old Sep 28, 2011 | 08:51 AM
  #13977
silver9's Avatar
Hey guys, im missing the small screen that covers the AC controls. Anyone know where I can buy this peice? Thanks
Old Sep 28, 2011 | 09:19 AM
  #13978
djfrestyl's Avatar
Suspension Yoda
Junkyard. You'll probably have to replace the entire fascia.
you can also try to see if someone has a non-working HVAC control. Make sure you indicate you need an AUTO HVAC control, as the manual one doesn't have a screen.
Old Sep 28, 2011 | 04:32 PM
  #13979
DOODOOCHIP's Avatar
i noticed a lot of headlights with no chrome, so are they painted or i can buy them like that somewhere? also has anyone had problems with the *** warmers, the one on drivers side is barely working.
Old Sep 28, 2011 | 05:22 PM
  #13980
Donmige's Avatar
its intergrated with the mass air flow sensor.
Old Sep 28, 2011 | 05:35 PM
  #13981
Donmige's Avatar
stillen makes a good lip kit.
Old Sep 28, 2011 | 06:42 PM
  #13982
djfrestyl's Avatar
Suspension Yoda
AE style headlights. You can open them up and black them out or buy them for about $80 for the pair.
Old Sep 28, 2011 | 07:50 PM
  #13983
REDL1NE's Avatar
I have a good one for you guys. In my 03 with Bose. Ever since I purchased the vehicle, the radio display only illuminutes as the lights come on. No song display, etc. AM/FM worked well and steering wheels controls worked well, but no cd.
I bought a used radio(mine had a cracked face) and installed it. No sound. Only a heartbeat type noise from the speakers. So I re-install my other and same thing..No more sound..
Thoughts?
Checked fuses under the hood and to the left of the steering wheel. All are good.
Old Sep 28, 2011 | 07:53 PM
  #13984
djfrestyl's Avatar
Suspension Yoda
Check fuses.
Any sign of cut/respliced wires?
It IS possible you bought a faulty unit. Why do you think they were selling in the first place?
Old Sep 28, 2011 | 07:56 PM
  #13985
REDL1NE's Avatar
Check fuses.
Fuses seem ok, unless I am overlooking a location(under hood and to the left of the wheel right)
The wires have been cut before, but its odd that I had audio before. Perhaps I moved a wire.
It was a salvage yard so its very possible. Hard to find these units I have learned!!
Any kind of reset or fuse I am missing?
Old Sep 28, 2011 | 11:15 PM
  #13986
DennisMik's Avatar
There are 3 fuses associated with the Bose. 10 amp fuse # 1 left of the steering wheel. This powers the head unit and the CD changer.
Fuse # 56, 15 amp, under the hood by the battery. This powers the head unit and CD changer memory.
Fuse # 67, 15 amp, under the hood by the battery. This powers the sun woofer.
There is no reset that I know of. What maybe happened is that one of the splices pulled apart when you were changing units. I'm a believer in soldering splices which would prevent something like this.
Old Sep 29, 2011 | 08:35 AM
  #13987
REDL1NE's Avatar
I appreciate it. Late last night I was going through the connections(which BTW I didnt do) and noticed a few weak ones.
The radio started working again so hopefully thats my only issue!!
I appreciate all the help fellas. Before I finish the install Im gonna get it ipod ready. I believe I saw a thread somewhere about this.
Old Sep 29, 2011 | 08:15 PM
  #13988
L36's Avatar
L36
This might be a somewhat weird question.
Sometimes, and by sometimes i mean about 4/10 times when i shift from first to second, the shifter feels like the gear grinds, but there is no grind sound.
Is this typical? Does not happen on any other gears but second. I'm using MT-90 GL4 gear oil. And no, i do not have trouble engaging the gear, furthermore, its regardless of the car being warm or cold.
This is a 5 speed.
Thanks.
Old Sep 29, 2011 | 10:34 PM
  #13989
slimI30's Avatar
Hi guys,
I got a 2001 I30 with 137k mi on it. Every once and awhile the car develops a miss when in gear (not sure if it does it in park), but if you jump on it (say..getting onto the freeway) it'll clear out. It doesn't seem to do it cold because I had to drive >7 miles before I saw the issue (it's the wife's car, she told me about the prob but it never did it for me). The car seems low on power even when it doesn't have a miss and gas mileage is down from normal by about 1.5-2mpg. I don't have a CEL. I just changed the plugs and they were clearly original but it didn't change anything. I'm thinking O2 sensors (my car is from CA so I have 4, right?) or a coil pack. My hesitation is, from the searches I've done on here, these things would throw a code. I need some help before I just throw money at this thing. Thanks
Slim
Old Sep 30, 2011 | 05:05 AM
  #13990
djfrestyl's Avatar
Suspension Yoda
Originally Posted by slimI30
Hi guys,
Slim
Wait until a code is thrown, or have Autozone link to the car to see if there are any pending/hidden/stored codes. If it's general sluggishness you could try a MAF. I wouldn't change o2 sensors just for the hell of it - and bad coils are very noticeable and WILL throw a code so it's probably not your coils.
Old Sep 30, 2011 | 05:34 AM
  #13991
buddywh1's Avatar
... from the searches I've done on here, these things would throw a code...
First thing is get a scan tool so you can read out codes whenever/wherever: there could be what's called a 'pending' code. The computer doesn't always light the CEL, sometimes it just holds it in memory. If the problem is infrequently intermittent and doesn't reoccur in some defined period or set of conditions it will clear the pending code.
When my coils started to go I'd get intermittent misfires like that too. Having your own scan tool is a real benefit when trying to deal with them.
Old Oct 1, 2011 | 09:54 AM
  #13992
DOODOOCHIP's Avatar
hello again,
i ordered the tail lights and they came with a strip of rubber glue or something like that. Can that be used for the headlights after you bake them?
Old Oct 2, 2011 | 05:02 AM
  #13993
djfrestyl's Avatar
Suspension Yoda
Butyl.
For headlights use silicone.
Old Oct 2, 2011 | 09:59 AM
  #13994
Alias6's Avatar
I know this question has been asked before, since i not only searched this forum and went through multiple pages, but i also search google. I sorta got an answer, but not an exact answer like i want.
I have an automatic transmission, when i'm in drive and am accelerating to 45mph i like to shift from D to 3 to accelerate faster than if i left it in drive. My question is, is that bad for my transmission? I know your not supposed to shift an automatic like a manual, but is shifting into 3 from drive bad for it?
Please no answers like "if you want to shift, get a manual" or "automatics suck" lol thanks
Old Oct 2, 2011 | 01:17 PM
  #13995
Jccampbell85's Avatar
First Nissan
Ok guys I just bought my first Nissan Maxima, I have only ever owned Civic's and a few Stang's. Its a 02 3.5L 6MT blue in color. I love the handeling and power of it so far. Are there any major problems I should look out for besides the obviuos I have read so far.
I am planning on lowering it, maybe a lip , and a better set of shoes. But the old lady doesnt want another modded car so my options for mods have to be subtle.And Im not posting pics of a car you can see everytime you search 02 maxima on google
Old Oct 2, 2011 | 02:03 PM
  #13996
DennisMik's Avatar
No. The transmission would downshift if you stomped on the gas pedal, so you doing it manually isn't any different. And if you want to control the shifting as if you had a manual trans, go ahead. Again, its you or the little box under the console. If shifting the transmission manually was so bad for it, why would they put in a shift lever with the different gear ranges?
Sometimes old wives tales just won't die.
Old Oct 2, 2011 | 02:48 PM
  #13997
L36's Avatar
L36
If there is a whining noise coming from the power steering pump when the car just idles and the steering wheel not turned (if turned, the whine gets slightly louder), then its safe to assume that the pump is faulty?
Also, no leaks, yes the fluid is clean, replaced it with Dextron 3.
Old Oct 2, 2011 | 04:27 PM
  #13998
gavin68's Avatar
Hi, two questions here.
1.) Is it possible to change out the factory Oil Temperature gauge for an aftermarket digital one? Meaning, could I pop out the old one, and put the digital one in its place? I'd be using the one at this link (http://cgi.ebay.com/ebaymotors/ws/eB...84.m1436.l2649)
2.) I have a manual climate control unit, and the sliding button **** thing is missing. I know its not a big deal, but it's driving me crazy and I would really like to replace it. Does anyone know where I could find one?
Old Oct 2, 2011 | 05:31 PM
  #13999
Alias6's Avatar
Wow I always thought it was a HORRIBLE thing to do haha. thanks for clearing that up
Old Oct 3, 2011 | 06:33 AM
  #14000
djfrestyl's Avatar
Suspension Yoda
1. I'm not sure if you can or not...but why do that in the first place? Adding gauges is a bit ricey if you're not boosted.
2. Junkyard or classifieds section here.
