5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Mar 18, 2007 | 07:22 AM
  #1481
irish44j's Avatar
retired moderator
Originally Posted by PandaXpress
Need someone to answer this post about the tein coilovers..Please..
Post Linky
Thanks to anyone who can help!
you'd probably be better served posting this in the suspension forum.....this thread, after all, is mostly n--bs that don't know anything....
Old Mar 18, 2007 | 09:02 AM
  #1482
PandaXpress's Avatar
alright..DONE..thanks and hopefully someone can help me in there
Old Mar 18, 2007 | 02:56 PM
  #1483
CoolMax's Avatar
is invisible
Hmmm, if you really : http://forums.maxima.org/payments.php
Old Mar 18, 2007 | 03:56 PM
  #1484
nk2k2's Avatar
Question about SES light
i have a 02 SE 6spd and i had my ses light came on yesterday while driving. I dont beat on the car at all and i always use 93 octane gas. I got the code looked up this morning and it was a P1147. I know that it is a O2 code but im not sure what steps i should take. I do know that i have to reprogram the ECU from the dealer. I was wondering if that is covered with the Emissions Warrenty. I did a search and ive read a few posts about this but i have not gotten a diffinitive answer as to what to do. As of now, the code has been cleared and btw this is the 2nd time this ses light as come on and it is the same code. The car has about 73k miles on it. Thanks.
Old Mar 18, 2007 | 04:04 PM
  #1485
SoonerFan's Avatar
Cletus
you just need the change the O2 sensor
i changed mine and never "reprogrammed" the ECU. i just went to advance auto and they reset the code. no problems.
Old Mar 18, 2007 | 04:07 PM
  #1486
SoonerFan's Avatar
Cletus
here you go (its the same sensor i had to change)
its the one in front of the precat
it is the one that says "WHITE"
http://forums.maxima.org/showpost.ph...25&postcount=6
Old Mar 18, 2007 | 04:22 PM
  #1487
nk2k2's Avatar
thanks soonerfan. i thought it was the white one because i remember reading about it. thanks for confirming it. so no reprogramming needed, which saves me money i guess. it also says for the TSB, that since p1147 came on, that both rear o2s have to be replaced, true? or just that one with the white plug. also how much from DaveB as a guess. thanks.
soonerfan you live in springfield,va? maybe we should meet up sometime.
Old Mar 18, 2007 | 04:46 PM
  #1488
SoonerFan's Avatar
Cletus
i ordered the white sensor from daveb and it was $115.22 shipped.
i didnt reprogram or replace the other sensor. its been about 2K miles with no problems.
if you need help, lemme know
Old Mar 18, 2007 | 04:52 PM
  #1489
nk2k2's Avatar
yeah if the light comes back on then im ordering it for sure. i might have you give me a hand if thats cool with you. im new to the 5.5s and i really dont want to **** anything up.
Old Mar 18, 2007 | 05:13 PM
  #1490
SoonerFan's Avatar
Cletus
it was a pain in the @ss to get to and it was a little rusted.
lemme know
Old Mar 18, 2007 | 05:59 PM
  #1491
prigrg's Avatar
Odd CEL
I have an ae up north in canada. Having learned to drive manual on this car when I first got it, I figured my ecu mappings were off, resulting in low mileage. As a result I wanted to reset my ECU. I wasnt sure whether the 3 second throttle reset would work since this is 5th gen, but figured it couldnt do any damage. However, since trying it yesterday, my CEL hasnt turned off. Is there any possiblity that I damaged my TB from the procedure? Are there any places in Canada where I could either borrow an OBD scanner for less than the $100 everyone seems to quote me for a scan? Anything you guys can recommend?
Old Mar 18, 2007 | 08:02 PM
  #1492
Originally Posted by CoolMax
I support but im broke...for now...Once i hit 3,000 i will donate for sho, if not earlier..then I have no excuse..
Old Mar 19, 2007 | 09:53 AM
  #1493
Tee00Max's Avatar
i was wondering does anybody have a good picture with a max with the silverstar headlights and fog lights on??? thanks
Old Mar 19, 2007 | 09:55 AM
  #1494
00-01? possibly....
  #1495
SoonerFan's Avatar
Cletus
link to headlight pic (the fogs will look the same)
http://forums.maxima.org/showpost.ph...0&postcount=45
Old Mar 19, 2007 | 09:57 AM
  #1496
I did a search and found a member with a sig pic that shows what they would look like..
Hope he doesnt mind me showing this because it is the best pic I've found
CLICK link and LOOK in the SIG
Linky to the Silverstars Pic
Old Mar 19, 2007 | 11:08 AM
  #1497
Maximo070's Avatar
2k ECU/OBD11 scanner prot issue
Hello there,
I have 2000 max with a strang issue. I bought a nice OBD11 scanner and I an unable to connect it with the ECU in my car. I have tested the scanner on other cars and I am able to link with them. I took the car to several shops and no one has been able to fix the issue. I just replaced coils, full exhaust ( Cattman with headers), plugs, PCV, Struts, shocks, springs, drive shafts, intake, and brakes. Before I did all of this work, the SES light was on and the scanner would not connect. After the work was done, the light has gone away but I still can not hook up to the scanner port. Also, I have traced all of the wires going from the scanner port to the ECU and other sensors and found nothing. Would it possible to get a hand. Thanks, Brian
Old Mar 19, 2007 | 11:19 AM
  #1498
Maximo070's Avatar
Could anyone in my area ( northern Va) be able to help me out with the issue above??
Old Mar 19, 2007 | 01:30 PM
  #1499
nk2k2's Avatar
some issues with the 5.5
ok something with my 5.5 doesnt seem right. ive had the ses light come on and it was cleared and the code was P1147 as stated above. Soonerfan told me that i need a new o2. Now the ses light has been cleared and is not on but once the car warms up all the way, the rpms sit at about 500-600. is that normal? also there is a slight hesitation when idling. it seems like a really minor misfire or is that just normal? im the 2nd owner and so far its been treated very nicely. 93 octance from Shell, not beating on, and it hasnt even seen redline in my hands. as far as the hesitation goes, could it be related to the P1147 code even though it has been cleared? it doesnt hesitate through the rpms but only at idle. So i dont know if im parinoid or what but i just want to make sure that the 5.5 lasts for a long time. ohh btw, it has 72.5k on it. I dont know if the plugs have been changed or not. Im not at all familier with the 5.5 motor so how much would it cost to do plugs on this car? i know the intake manifold has to be removed and im not trying to get too involved in that.
Old Mar 19, 2007 | 02:13 PM
  #1500
Maximo070's Avatar
nk2k2,
I had this same issue that was solved by replacing the coil packs. You can get the coils from NAPA autoparts for a good deal. I paid about $375 for all 6 coils
Old Mar 19, 2007 | 02:27 PM
  #1501
nk2k2's Avatar
Originally Posted by Maximo070
nk2k2,
see i want to make sure they are the coil packs before i swipe my card. i want to identify it before any purchases. i have a feeling it has to do something with the spark plugs or o2 sensor. im sure replacing the coils would go hand in hand with the plugs.
Old Mar 19, 2007 | 06:10 PM
  #1502
d40sithui's Avatar
hey guys,
do you think its safe to splice power from the headlights to fog lights?
Old Mar 19, 2007 | 06:22 PM
  #1503
irish44j's Avatar
retired moderator
Originally Posted by d40sithui
hey guys,
why would you want to? There should be wiring already installed for factory fog lights, even if the lights aren't there.....
Old Mar 19, 2007 | 06:37 PM
  #1504
what if we have aftermarket fogs..we can still tap into the fog light harness for the stock ones and it will work? (splicing)??
Old Mar 19, 2007 | 07:20 PM
  #1505
Tee00Max's Avatar
i know this is not a car question but how do you put a avatar under your name?? thanks
Old Mar 19, 2007 | 07:24 PM
  #1506
The Law's Avatar
I R The Law
If you know it isn't a car question then don't ask it in here. This isn't the general thread forum. Also read the Feedback/Suggestion forum, you might find your answer there.
Old Mar 19, 2007 | 07:26 PM
  #1507
you need to donate to the org...
Originally Posted by The Law
If you know it isn't a car question then don't ask it in here. This isn't the general thread forum. Also read the forum rules, you might find your answer there.
Old Mar 19, 2007 | 07:29 PM
  #1508
Tee00Max's Avatar
thanks for that
Old Mar 19, 2007 | 07:33 PM
  #1509
thanks for that
no worries...he means well...just he gets a bit carried away and forgot the name of the thread is "I am new here but have a Question"...
Dont think im hating on him even if he might not come down to LA and help me seafoam my damn car...
Old Mar 20, 2007 | 06:30 AM
  #1510
d40sithui's Avatar
well, i know the wiring is there, but two things.1) I don't have the switch. 2) I dont have fog relay. I have a current setup where the fog goes into the battery and theres a 3rd party swtich that i installed in my dash, but i'm lazy and just wants to splice the fogs with the headlamp so they come on when the lights are on just wondering if thats safe.
Old Mar 20, 2007 | 08:40 AM
  #1511
dsada4324's Avatar
thanks i'll check them out.
Old Mar 20, 2007 | 03:56 PM
  #1512
WeeZyFellA's Avatar
what do i need to keep my stock hd non-bose in a 2001 max, upgrading the system. i was told a sort of adapter/harness, but not sure where to buy it from. thanks
Old Mar 20, 2007 | 04:12 PM
  #1513
SoonerFan's Avatar
Cletus
check the audio/electronics forum
Old Mar 20, 2007 | 05:16 PM
  #1514
imported_D_Roc's Avatar
i start any new topics or send pm's says i do not have permission to do it or the administrator didnt verify or something my account does any one know y? I already made two accounts this is my 2nd and still the same
Old Mar 20, 2007 | 05:23 PM
  #1515
SoonerFan's Avatar
Cletus
if you had read all of the rules when you registered, you would know that you have to have 15 posts to start a new thread or use PM.
use those posts wisely or things will get ugly fast
Old Mar 20, 2007 | 06:13 PM
  #1516
GigEmAgs07's Avatar
as for the AC blower motor fix, what is involved in dropping the motor to clean it out? i have seen the TSB and my cover gets to nissan in the morning, but i wanted to know how to drop the actual motor to clean it out.
6 screws, move the airbag wires, disconnect light, and pull right?
I think i read somewhere that it's just 3 screws to drop the motor right? I did a google search and read everything i could there. anyone wanna clarify? tia
Old Mar 21, 2007 | 07:11 PM
  #1517
Magista's Avatar
LCD in ventilator Assembly
I was wondering if anyone has installed a touch screen LCD flush mount where the vents are in 5th gen dash. I'm thinking of getting one of those assemblies and attempting it, but I'm not sure what screen to use. The working dimensions i measured were about 200mm x 100mm. Thats cutting it close with most 7" LCDs it seems. I was wondering if anyone has any pictures of this installed or suggestions as to a LCD Touchscreen that has a height under 100mm. I'm having trouble finding accurate dimensions.
Magista
Old Mar 21, 2007 | 09:45 PM
  #1518
CoolMax's Avatar
is invisible
Magista
Audio forum could probably help you out best.
Here are the some threads that I dug up:
http://forums.maxima.org/showthread....11#post3765111
(4th gen, but plenty of pics, instructions)
http://forums.maxima.org/showthread....42#post4203442
http://forums.maxima.org/showthread....62#post2959962
What units are you looking at? Eclipse? Pioneer?
Old Mar 21, 2007 | 10:07 PM
  #1519
JDMGLE's Avatar
i have a question about swapping stock hid's in my car. i was wondering if it is a straight swap or do i need to do some rewiring? my 00 GLE has the standard crappy headlights and i want to put the 02 up SE hid's in but i'm not sure if its a straight plug and play or is there some rewiring needed. i'm talking about swapping the whole headlight assembly. thx
Old Mar 21, 2007 | 10:54 PM
  #1520
rewiring is needed...
ALSO
WHY the hell DO only 1/6 of the HOW-TO's work??
