5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Sep 19, 2007 | 02:46 PM
  #3001
greentea1's Avatar
ping/knock mileage problems
01' I30, 89k miles, premium fuel, no SES codes...
I'm having a constant problem with ping/knock under light to moderate acceleration. This seems to occur when driving on flat or hilly roads. I have given the car a Seafoam treatment thinking it was due to carbon buildup, but that didn't do anything. I also am getting reduced fuel mileage and sometimes smell rotten egg emissions.
Help!
Old Sep 19, 2007 | 03:59 PM
  #3002
nebojsa_o's Avatar
Originally Posted by Unclejunebug
I'm new to the forum as well as the 2002 Maxima GLE I just bought a few weeks ago and I thank you all in advance for any ideas/advice you can give on how to fix my problem. The car is in great shape but when driving on the freeway the it feels really rough and makes a sort of vibration sound as if I was driving over a lot of really small bumps (I don't know how else to explain it). The roughness and vibration sound go away when I turn the steering wheel to the right maybe 5 degrees or more, but stays when turning to the left or while driving straight. Any ideas? And please let me know if you need more information, I'm new to this.
2002 Maxima GLE
30,000 miles
Sounds like a right wheel bearing. See if you can pinpoint front or rear. Someone correct me if I"m wrong.
Old Sep 19, 2007 | 04:01 PM
  #3003
nebojsa_o's Avatar
Help!
I'd like to hear an explanation for this too. Cat? Do precats do the same rotten egg smell thing as the cat, or how can you tell when the precats are done?
Old Sep 19, 2007 | 04:22 PM
  #3004
Unclejunebug's Avatar
Thanks for the reply. I'm pretty sure that the shakiness is coming from the front end. It does feel however that it comes more from the left (driver's) side than the right (passenger) side. I will try to confirm on my drive home from work today.
Thanks again!
Old Sep 19, 2007 | 04:24 PM
  #3005
NmexMAX's Avatar
dot dot dot ...
They both give off the same odor since they’re made of the same material. The reason the pre cats are referred to as such(pre)is because they are further upstream(closer to the engine). The reason they are further upstream is so that they can heat up faster and lower emissions faster than the main cat can downstream. In order to do their job, they must be warm/hot.
As for the pinging issue, perhaps try colder plugs and an oil catch can.
Old Sep 19, 2007 | 05:42 PM
  #3006
User 12822's Avatar
Why does my car act up in the morning when its cold? Sometimes it sounds like its struggling to stay running.
Old Sep 19, 2007 | 05:44 PM
  #3007
User 12822's Avatar
Help!
I only get pinging if i put anything but premium, perhaps your gas station isn't giving you the proper quality of gasoline?
Old Sep 19, 2007 | 05:58 PM
  #3008
irish44j's Avatar
retired moderator
because the oil hasn't lubricated the system sufficiently....that's why you let your car "warm up" on a cold morning before driving it.
Old Sep 19, 2007 | 06:37 PM
  #3009
User 12822's Avatar
Should the warm up take more than 10 minutes?
Old Sep 19, 2007 | 06:58 PM
  #3010
greentea1's Avatar
I wish that was the problem...I've tried multiple stations with the same result.
Old Sep 19, 2007 | 06:59 PM
  #3011
greentea1's Avatar
I was thinking more like a bad knock sensor or O2 sensor problem. Am I off base?
Old Sep 19, 2007 | 07:02 PM
  #3012
Thanks again!
So after driving home it still seems that the vibration is coming from the front, and maybe more on the driver's side than the passenger's side. Any ideas?
Old Sep 19, 2007 | 08:13 PM
  #3013
SlurpeeKing's Avatar
hey
i read on a couple of pages back that for maximas with an aftermarket headunit, to get the trip button on the steering wheel to work is as simple as grounding the brown wire
does anyone have a DIY or can explain as to how i would go about doing this?
Old Sep 19, 2007 | 08:24 PM
  #3014
NmexMAX's Avatar
dot dot dot ...
If the KS is dead, the car will go into a timing retard scenario. Meaning the ECU will retard timing in order to combat any ping since the sensor would be out of wack.
O2 sensor wouldn’t have any direct affect for pinging either. It will run overly rich, and therefore, keep combustion temps low, if anything reducing the risk of spark knock.
Old Sep 19, 2007 | 08:44 PM
  #3015
GBAUER's Avatar
corrections: O2's can also make the engine run lean. Did it in mine when the O2 went bad... of course, my car was a tad ghey...
Old Sep 19, 2007 | 08:51 PM
  #3016
NmexMAX's Avatar
dot dot dot ...
Do you have AFR readouts that prove this? My primaries are not connected right now and I'm in the high 12's/low 13's @ part throttle under 40 MPH/1200. Anytime after that, I'm @ 14.7 or a touch leaner (15.0).
So, are you going by what a mechanic told you, or by what you actually know?
Old Sep 19, 2007 | 09:16 PM
  #3017
greentea1's Avatar
So I'm baffeled as to why the ECU wouldn't try to compensate anyway...could it (ECU) be faulty?
Could a faulty O2 sensor cause it to run too lean making it ping?
Old Sep 19, 2007 | 10:29 PM
  #3018
nebojsa_o's Avatar
Wouldn't a bad o2 sensor or knock sensor set off the SES light though??
Old Sep 19, 2007 | 10:32 PM
  #3019
majesticmaxima's Avatar
anyone know about putting 350z seats in the 5.5?
Old Sep 19, 2007 | 11:52 PM
  #3020
Solebreaker's Avatar
i cant seem to get the front weatherstrip off i peeled it off but some pieces of plastic are still there. any suggestions to get it all off to install http://cgi.ebay.com/ebaymotors/WEATH...QQcmdZViewItem
Old Sep 20, 2007 | 06:51 AM
  #3021
NmexMAX's Avatar
dot dot dot ...
Instead of trying to thinking about it too much, be simple. Get colder plugs and an oil catch can.
Old Sep 20, 2007 | 07:47 AM
  #3022
SoonerFan's Avatar
Cletus
i think one person did it. needed all new mounting plates. it was a lot of work
Old Sep 20, 2007 | 08:07 AM
  #3023
CCS2k1Max's Avatar
Originally Posted by cjandura
just a general tire question my car(2003 White MaxSE) came with the 225/50/17 size tires and right now i`m looking to go a little wider i know about the whole speedo thing i was just wondering if anyone has put on the nissan factory rim any of the following sizes and if so did they rub?
245/45R/17--.66% speedo difference
275/40R/17--.74% speedo difference
275/45R17s are 2 inches off spec. 245/45R17 is still pushing it.
Go 235/45 and take to 2% or so error, or get wider rims.
Old Sep 20, 2007 | 09:43 AM
  #3024
greentea1's Avatar
Ping/Knock
Ok I'll try colder plugs...can you recommend a brand and type?
What is the oil catch can for?
Old Sep 20, 2007 | 01:43 PM
  #3025
choopster's Avatar
Need Help
My ecu fried cuz of bad IACV... i got a new IACV but dunno where to get the same type of ECU.
It says A56-Q77 Z98 type of ecu and they are hard to find. Can i get a second hand ECU and will the dealers be able to program it or can my car take a donor ECU without troubles.
Old Sep 20, 2007 | 01:53 PM
  #3026
hoboscratch's Avatar
I have a couple of issues on my 2001 GLE w/ 98K.
1) I feel every bump I go over. Makes a thumping sound as if my springs are completely worn or something and nothing is absorbing the bump. If I continuously push down on the front of the car to get it bouncing up and down and let go it stops almost immediately. I was told that was an effective way to check the shocks/springs to see if they need replaced, and if it stops quickly then they're good. I checked my tie rods and they are tight and the bushings look good. The transverse link feels solid too. Does it sound pretty much like my shocks or springs are just shot? This was something that just started about 1.5k or so ago and has gotten progressively worse. Its not a vibration or anything, its just a hard thump.
2) My driver side window screams at me when I roll it up. Sounds terrible. Anyone experience this?
Thanks!
Old Sep 20, 2007 | 02:00 PM
  #3027
Kyle00's Avatar
WSH for teh cup
Don't hold me to this, but i think you can get an ecu and have them program it to your key.....
Old Sep 20, 2007 | 02:01 PM
  #3028
Kyle00's Avatar
WSH for teh cup
Thanks!
It's typical. Mine does the same
Old Sep 20, 2007 | 05:02 PM
  #3029
Tee00Max's Avatar
Does anyone know how much is a harness for the parking light in a 2000 Max?
Old Sep 20, 2007 | 06:11 PM
  #3030
User 12822's Avatar
How do I wash my seat belts? My friend needed a ride home from soccer practice and well uh...he like ruined the passenger's seat one.
Old Sep 20, 2007 | 06:31 PM
  #3031
NmexMAX's Avatar
dot dot dot ...
Scrub it with tide. Should come clean. I‘ve had similar occurrences with Cola.
Old Sep 20, 2007 | 07:22 PM
  #3032
TurtleHead
A window screaming at you is typical?
Try spraying some silicone down in the window jams. Often dirt and grime get in there and cause those issues.
Old Sep 20, 2007 | 07:24 PM
  #3033
SoonerFan's Avatar
Cletus
he is asking about the SEAT BELT...not the window
Old Sep 20, 2007 | 07:28 PM
  #3034
TurtleHead
Post 3028 doesn't mention any seatbelts?
Old Sep 20, 2007 | 07:53 PM
  #3035
ss1248's Avatar
Hi,
I have a modding question, to which I've searched, and browsed much of the 5th gen thread to no avail. I'd like to build a flip/switchblade (i.e. VW) key for my 5th gen. Has anyone done this, or is there another place on the forum I should look? I found some ideas on a G35 forum, but they use the newer remote and key. (see links) Please let me know of any thoughts.
see post #216 http://g35driver.com/forums/showthre...ight=VW+remote
It's the subject of this thread:
http://g35driver.com/forums/showthre...light=flip+key
Old Sep 20, 2007 | 10:41 PM
  #3036
choopster's Avatar
Has anybody tried fixing their ECU when it got fried. My IACV fried the STA509A (MOS FET Array). Having an elect engineering background i can easily solder a new chip. but then again will the ecu function properly.
thx
Old Sep 21, 2007 | 06:42 AM
  #3037
alicious's Avatar
the org...not what it was
thx
I went to a guy that own's a Nissan specialty shop and he got me a fresh ecu and reprogrammed it for me when mine blew. Best $180 I ever spent.
Unless you know someone who can do it then you are pretty much stuck going to the dealer.
Old Sep 21, 2007 | 07:27 AM
  #3038
triksterut's Avatar
Just picked up an 02 SE...
Hey all,
I'm Maxima noob but not really a car noob. I co-run celicatech.net and make custom turbo's for BMW's so I can wrench with the best of them. Just have a few specific questions about the Maxima. I just picked up an 02 SE for my commuter and had a few questions. I would search, but for some reason I don't have permissions to search - or post in any forums (noob status rocks!):
I. It's a 6-spd. When I'm WOT and I go to shift; even after I release the gas peddle, the engine continues to rev for a bit. I know the 02's are drive by wire - is this a slow response from the system or a programmed in "feature"? It does not do this under normal driving conditions and I just noticed it to be odd.
II. This engine has a timing chain I know, my car has 88k miles on it. Is there anything I just rip apart and get taken care of now while I'm in the mood? When does the water pump normally go out, and should I replace the tensioner's and whatnot on the chain?
III. Road noise - is it me or is this car way noisy?
IV. Do you know of any stereo's that I can re-use the steering wheel controls for? I needs me my ipod and have a nice deck but I don't want to to loose the steering wheel controls because I like them
Also - anyone want to buy a nice brand spanking new BOSE 6-disc? The guy I got my car from just got a new one before he sold it to me.
Thanks guys!
Jeremy
02 SE 6-spd (Black/Black)
99 M3 Cabrio (Boosted to an inch of it's life)
91 MR2 Turbo
93 Honda Accord (Rice On!)
89 Ford F250 (hahah)
Old Sep 21, 2007 | 08:00 AM
  #3039
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/showthread.php?t=309404
http://forums.maxima.org/showthread.php?t=282780
My TPS shows that it closes (with respect to voltage) as soon as my foot leaves the pedal. But my car is 4AT, so It should be the same for you. I have not heard of this behavior being common on the boards though.
One of those if it aint broke, why bother? Older gen VQ's would typically have a small intermittent coolant leak, and that was the indicator that the pump was n its way out. But I have not heard of it happening with later VQ's just yet (Model years 02+).
What tires do you have?
Also, check out:
http://www.nissanhelp.com/Ownership/.../NTB01-029.htm
http://forums.maxima.org/forumdispla...aysprune=&f=21
http://forums.maxima.org/forumdispla...sprune=-1&f=42
Old Sep 21, 2007 | 09:05 AM
  #3040
JusJon's Avatar
I have a problem when i turn right or left i hear clicking sounds coming from the front driver and passenger side wheel well.i didnt start noticing it til a week ago,could t be my cv joints?ho would i go about replacing them if it is?
