installing home made black carpet
Old Sep 5, 2006 | 05:44 PM
  #41
PAREDLINE's Avatar
Originally Posted by amimaxima
i'll give you 100 dollar if you can find the seams in my car
If you get this excited about carpet I can only imagine what might happen if you got a supercharger.
Old Sep 5, 2006 | 05:58 PM
  #42
Metal Maxima's Avatar
SHIFT_om nom nom nom
If you feel the need to nit-pick a very unique modification to a 5th gen I can only imagine what might happen if you started trolling other threads.
Old Sep 5, 2006 | 06:02 PM
  #43
amimaxima
thank you very much.
just because you dont have the skills it take to pull something like this off dont critique it
Old Sep 5, 2006 | 06:05 PM
  #44
You make it quite hard to stick up for you when you put your foot in your mouth like this.
Old Sep 5, 2006 | 06:06 PM
  #45
PAREDLINE's Avatar
What's so unique about new carpet in a car? It's black. Doesnt even look good. My I30 has black carpet. whoop dee doo. Hell it even has a black interior. Talk about unique.
I just thought it was retarded to put new carpet over old- and then have a 4 day erection about it. Maybe you two can finish each other off and we can move on to something important.
You want something unique- change your headliner fabric to fabric scenes from the Speed Racer Cartoon
Old Sep 5, 2006 | 06:15 PM
  #46
So any car in which a conversion of an existing model is made to mimic another, no credit is to be given?
SO, by virtue of your argument, that would mean that a 4th gen that had a 3.5 swap performed could easily be pissed all over by the likes of yourself because someone elses car comes with the same STOCK.
Hrmm. Moving along...
The man worked hard on this. It's ALOT of work to change the carpet as many items need to be removed. You've done nothing than troll this thread with your worthless drivel.
Nice ninja edit. Judging by the threads you have started I believe it would be safe to say perhaps you should invest your time into fixing the near infinite amount of problems you seem to be having with your ride.
Old Sep 5, 2006 | 06:17 PM
  #47
PAREDLINE's Avatar
Thanks for stalking me. So you're saying laying autozone carpet over stock carpet is tantamount to an engine swap?
My car has problems. As do you and your friend. Only my car can be fixed. You will still be retarded
Old Sep 5, 2006 | 06:32 PM
  #48
amimaxima
Originally Posted by PAREDLINE I just thought it was retarded to put new carpet over old-
If you weren't so stupid you'd know why that was done. But you dont even have the knowledge of a 5th grade school girl.
Also metal maxima's knowledge exceeds all the knowledge you will obtain over your entire life time.
Originally Posted by PAREDLINEYou will still be retarded
That was very well said. Short of words huh?
Old Sep 5, 2006 | 06:41 PM
  #49
Know thy audience.
No, actually I think both deserve respect in their own right. Those were YOUR words.
LOL. Can't say I've had ANY issues with my car mechanically.
...enough. There is not point in continuing this pissing contest. You are tired of seeing this thread bumped to the top, some threads will do that. I can recall someone whom did a 'Cold Weather Car Wash' and it was on top of the friggin pile for over a week. But I did not say anything. No sense in turning this into a flamefest.
Old Sep 5, 2006 | 07:07 PM
  #50
1996blackmax's Avatar
amimaxima comes on here showing us what he did with his carpet. I think it's a cool thing for anyone wanting to do the same thing.
Old Sep 11, 2006 | 10:50 AM
  #51
siren001's Avatar
What kind of sprayer did you use to spray your glue?
Old Sep 11, 2006 | 01:32 PM
  #52
amimaxima
gravity feed spray gun
Old Sep 11, 2006 | 10:37 PM
  #53
siren001's Avatar
went to home depot could not find headliner glue but found contact cement, could you use that and spray that?
Old Sep 12, 2006 | 02:27 AM
  #54
djfrestyl's Avatar
Suspension Yoda
If you can find a spray gun that works with a gravity gun.
There's no such thing as "headliner glue" at least not the eleventybillion times I've gone to HD.
Why not just use spray glue?
Old Sep 12, 2006 | 03:46 AM
  #55
SEmy2K2go's Avatar
Go BUCKS!!!
I don't know if this has already been asked, but the money you spent on doing this install...couldn't you have spent about the same or less to have your carpet professionally cleaned?
Old Sep 12, 2006 | 06:42 AM
  #56
amimaxima
It wasn't the fact that my stock carpet was dirty. Im in the process of completely redoing the interior of my car, and the first step was to change the carpet to black.
Also its not cost affective to buy 3M spray glue in cans. Its 12-18 dollars a can and you will need about 4 cans.
I used 3M headliner adhesive it was $5.90 a qt and $19.90 a gallon
If you cant find the 3M headliner adhesive then you can go to walmart and get DAP contact cement. It's $6 a qt about the same price as the 3M headliner adhesive.
Old Sep 12, 2006 | 06:46 AM
  #57
amimaxima
Also if you are going to use either 3M headliner adhesive or DAP contact cement you can use any automotive paint spray gun. Bottom feed or gravity feed it doesn't matter.
Old Sep 12, 2006 | 09:03 AM
  #58
shurik's Avatar
I think that's pretty nice, looks nice.
Old Sep 12, 2006 | 10:38 AM
  #59
siren001's Avatar
I found 3m contact cement, think that will work? I gonna use the for the headliner carpet and doors.
Old Sep 12, 2006 | 11:01 AM
  #60
amimaxima
yes the 3M contact cement will work. What you need to do when you are doing the carpet is spray a coat on the stock carpet and then spray a thin coat on the backside of the black carpet. like the thin coat on the back of the black carpet tack up and then spray on another coat a little thicker than the first coat. and then allow 5-6 minutes for all the glue to tack up and then apply. (the reason you are going to spray on a thin coat on the back of the black carpet and then a 2nd thicker coat is to prevent the glue from going thru the black carpet the first thin coat will act as a block so the 2nd thicker coat cant go thru.)
  #61
SPiG's Avatar
SomePsychoGuy
The swap is looking very good, but would this be a better option than glueing new carpet over the old?
http://www.stockinteriors.com/
Old Sep 12, 2006 | 11:06 AM
  #62
amimaxima
I think it was well worth 50 dollars to do it myself vs. paying $135 for pre molded carpet
Old Sep 12, 2006 | 06:08 PM
  #63
amimaxima
this is the spray gun that I used
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
