245/50/17?? too big? input please.
will a 245/50/17 tire fit on a 2000 maxima?
I am lowered on progress springs.
The wheels are 17x7.5 30mm offset (front) and 17x8 33mm offset (rear).
Any opnions would be appreciated!
p.s. I know it's a wide tire.. and is a little bigger than stock, but the price is SO right ($1300 msrp for $250.)
Originally Posted by FriscoMaxima
if you wanna look like dune buggy, then it's a nice wheel size.
try ebay for some tires...i got a pair of pirelli's 255/40/19 with 80% tread for 100 bucks..
Originally Posted by maxS
245 wide tire on a 7.5 wheel? that's a nono. 8.5 width is what it needs.
yes.. 17" g35 coupe rims..
well i hope they don't rub, i just bought the tires..
i am putting on a 245 tire, and not a thinner one because i'm getting a good deal on them...
thanks for the input guys..
Originally Posted by Swafford98
245/45/17 is what i run on my 17" 5zigen corpse. Gives it an aggresive stance. Hardly rubs at all, only on really tight turns. I have even seen 245 on a 6.5" wheel before. A 245 size tire will fit.
what offset are those 5zigen rims?
i'm not too worried about the tires fitting on the rims, more the tires clearing the fenders...
you are definitely going to have rubbing problems. My winter wheels are the G35 17's as well and in the back I ran 235/50/17 and DEFINITELY rubbed in the back significantly, and that was on maxspeeds, which sit ALOT higher than Progress springs.
I hope for your sake that they work, but I'm pretty sure you will have some serious rubbing in the back...and possibly the fronts too.
You guys need to stop giving bad advice to n00bs.
Excuse the grammar fail, Im too lazy to fix it.
It was rolled and still rubbed. If you notice, the wheel face is almost flush with the outside of the fender. As the wheel travels up into the wheel it will eventually hit the fender lip where the tread stops and sidewall starts. Illuminas set to 5 did not stop it. 235's would have probably been OK or far better.
It only rubbed on the passenger side. It rarely did it when I didn't have my sub in the trunk and occasionally did with it (appx 60lbs over the axle). Put passengers in the rear and it rubbed with every medium bump.
Again, it was a rub that did not tear up the tire and barely left a mark (after rolling the fender). It just sounded bad for the most part.
James92SE
142
Jan 2, 2024 09:23 AM
