Projector Head Lights
Old Jan 4, 2007 | 11:23 AM
  #41
Majestic Ken's Avatar
hmm wonder if these M45 shrouds would look nice http://cgi.ebay.com/ebaymotors/Infin...spagenameZWDVW
Old Jan 4, 2007 | 07:20 PM
  #42
cefiro80's Avatar
Yes the e46 are a good budget option but in reality if you are going to the work of baking/fabing up why not just get the tsx or s2000. I guess I am one to go for the best if I am goind to do something. Also, another good budget option is murano projectors.
Old Jan 4, 2007 | 10:15 PM
  #43
ChromeSE5's Avatar
TSX I would understand but the going rate for s2000's are close to $400 sometimes. On top of that, S2000's take a lot of cutting just to take off the highbeam portion. But I do agree, if you are going to do a retro and spend all that time, might as well go with the TSX.
Old Jan 6, 2007 | 05:07 PM
  #44
kdaullary's Avatar
Slickcar.com looks like they have a pretty good set of aftermarket projectors with the angel eyes built in check um out
Old Jan 6, 2007 | 05:42 PM
  #45
ToneG
Originally Posted by shift_2kmaxima
okay...whats everyone saying is that Ebay ones suck ****...and that is true, i was going to buy them but I decided not to after some research BTW: you should def. search the org there are A LOT OF THREADS on this topic...but here is the thing "ebay projector headlights suck...you can buy them for 200 bucks and buy new Projectors from some on HIDplanet or w/e else you can get them, and you take the Projectors out of those headlights from ebay and put new ones in (it takes some work man, so if you are scared to do that kind of work STAY AWAY FROM RETRO FITTING.....But I went the other way, I bought 02/03 headlights..(that look really good on 00/01 maximas) and YES 02/03 maximas' have HIDs so yes you can have Hids in them and I think that is what you are looking for...OEM hid bulbs are 4300K which is not as BLUE as some of the other HIDs are...but it does have the best output (you can see really well)...but you can also upgrade to 6000k or 8000k to make it look really blue/purple...
good luck man
huso
Hold up, I was told the 02/03 headlights won't fit the 00/01 models because they are slightly shaped differently. So you're saying that I can fit those in my 00 Max? More info please.
Old Jan 6, 2007 | 09:52 PM
  #46
ChromeSE5's Avatar
Whoever told you that is wrong. A lot of people have done it. All you need is to do the wiring and buy the headlights.
Old Jan 7, 2007 | 10:21 AM
  #47
ToneG
What wiring has to be done and do you have an estimate as to how much it would cost to get wired? Ok and to get the record straight these will fit my '00 Max:
http://cgi.ebay.com/ebaymotors/2002-...spagenameZWDVW
Old Jan 7, 2007 | 11:05 AM
  #48
ChromeSE5's Avatar
Those will fit. You will have to wire the ballast (the amplifier for the bulbs) into the stock wiring that powers the stock h4 bulbs. Here is a 2k/2k1 (Huso's max) with the 2k2/2k3 headlights.
Old Jan 7, 2007 | 05:15 PM
  #49
ToneG
Damn that sounds like a pain and pricey too!
Old Jan 21, 2007 | 06:36 PM
  #50
scmax2000's Avatar
Buy it from Ebay, but there are other places like Custom Enterprise that will sell them for a higher price.
Old Jan 23, 2007 | 04:45 PM
  #51
Big_E-Dog's Avatar
2nd Gen Boostinator
you should of moved back like 15 more feet youll get a better i deal of how migh your lines are off
Old Jan 24, 2007 | 01:02 PM
  #52
NYMAX02's Avatar
^^^ looks good ....great job ...take some pictures to see the range !!!
Old Jan 26, 2007 | 05:04 PM
  #53
piotroosh's Avatar
I will sell my projectors for.. hmm.. $50? + shipping.
used 1 year. brackets are a little damaged, and one plastic is a little bit scrat ched ;D but still in pretty good quality ;-)
I went back to stock cause i think those projectors suck big time ;-D
Old Jan 26, 2007 | 08:35 PM
  #54
piotroosh's Avatar
Yeah, I meant original ebay projectors + housing as is... ;-) it sucks. ;-)
Old Jan 26, 2007 | 09:23 PM
  #55
Teddie18's Avatar
kdaullary how do you know if the projectors at Slickcar.com are better than the ebay projectors? Do you have inside info that would be helpful???
Old Jan 26, 2007 | 10:40 PM
  #56
808MAX-SPEC's Avatar
$299!?! Sorry, but that's a rip off. You can get them on ebay for as low as $200.
Old Jan 27, 2007 | 08:35 AM
  #57
Teddie18's Avatar
Thanks 808MAX-SPEC. I thought the Slickcar.com projectors were the same as the ebay projectors. Thanks for verifying it.
Old Jan 27, 2007 | 12:37 PM
  #58
Just by looking at the pics they should be the same. ebay lists these projectors with better pics and product description for less $$$.
Old Feb 9, 2007 | 04:30 PM
  #59
romefolk's Avatar
I have a 2001 Infiniti I30 - Stock without HIDs.
What is the difference between HID Projectors vs. a Halogen Projector.
Many Newer car claim that they use halogen lights, and the the projector lens make it look as if it is a HID setup? am i right?
I've also read that HID Kits do not come with HID projectors and they only enable you to use an hid light bulb in your car. and u might have to buy the project seperatly.
Also, there was a write ups stating that all HID Kits are not worth the money because they dont work (effective) as well as some of the HIDs that come stock on the new Lexus cars. Any truth to that?
My question is: could i just purchase a halogen projector for my stock halogen lights, instead of using a HID Kit? Will my light output be effected. I want the HID look, but i dont want HID kit cons.
Old Feb 9, 2007 | 04:49 PM
  #60
romefolk's Avatar
This is the Link that say Aftermarket HID kits are not worth the money:
http://www.danielsternlighting.com/t...nversions.html
The 00' Infiniti I30 has a different headlight setup, so i cant use the 03 maximas or I30 Stock - Hid housing.
Im not sure if the I35s have HIDs and even if they do, i dont know how well they work with the I30s.
I just want my low beam to have the projector lens "look" without losing light quality. I would love it if i could get the "look" plus gain light quality!
Someone please shine some light on me....
Old Feb 9, 2007 | 07:12 PM
  #61
lowincash's Avatar
No More Maxipad
www.hidplanet.com/forums get all your answers there
Old Feb 9, 2007 | 09:20 PM
  #62
n3985's Avatar
大陆弟弟
Go to the I35 section and read the "NOOBIES thread", you'll see what I've typed on the eBay headlights. And search, as may I30 owners hae converted to HID headlights from the I35.
Old Feb 14, 2011 | 09:13 AM
  #63
showstoppa01's Avatar
Originally Posted by 01maxhawth
if you want the true look on a 01 max with a retro look for a 02 max headlight, check out my ride with my retro fit done by http://www.customlightz.com/ check out my pics, this is true retro fit. projectors from ebay really suck.
NICE LIGHTS man. I have an O3 Max. I was looking through that website. How long did it take to get that completed? Did you ship them the lights or you went to them and they did it on the spot. Im in Ny and i see they work out of Long Island on weekends so I'm trying to hit that up. And the big Question how much did all of that cost?
Old Feb 14, 2011 | 12:37 PM
  #64
Seansib's Avatar
How hard is it to put in HIDs from a 5.5 gen in my 2000?
Old Feb 14, 2011 | 03:02 PM
  #65
Waxima's Avatar
For a straight swap, not difficult at all. You just need to switch them out and set up all the wiring, the fit right in.
If you're talking about doing a retrofit like a lot of the guys in here have done, that's a whole different story.
I actually don't even mind this thread being bumped. I love reading about retrofits, the craftsmanship that goes into them and resulting light output fascinates me.
Old Feb 14, 2011 | 04:07 PM
  #66
TunerMaxima3000's Avatar
You should have PM'd him, supposing he's even still on the site, that was 4 years ago man WTF.
My .02 cause I wasted my time reading this, that looks foolish, light output is great but the headlights look like something off an 80's futuristic movie robot Beady eyed little bugger!
Old Feb 14, 2011 | 04:35 PM
  #67
Waxima's Avatar
After looking a little more closely, I just saw that on this same page at the top someone posted details and a picture of installing 02/03 headlights in an 00/01.
Noobs these days...
Old Feb 14, 2011 | 05:56 PM
  #68
Mr. Brett's Avatar
I think projectors can be more flushly retrofitted on our cars. It's just a matter of being innovative.
Any projector that sticks out past the OE composite lens looks ridiculous IMO...
Old Feb 14, 2011 | 06:43 PM
  #69
^That's what I'm saying
It would look good if it was flush. If that's possible.
Old Feb 15, 2011 | 03:22 PM
  #70
keepitclean's Avatar
http://www.andysautosport.com/nissan...adlights/anzo/ check these out.pricey but they have others also.ANZO ive never had a problem with them past.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Maxima30
Sep 7, 2015 06:13 PM
