trimming the bump stops
Young, when the car is sitting on the ground the bumpstop should stay up there. Many people recommend not even trimming the bumpstops but i guess thats too late in ur case. Goodluck...and post some pictures!!!!
are they the fronts foam or rubber? the foam ones stay up if you cut the bottom, your out of luck with the 1 piece rubber fronts/rears. just zip tie the boot to the strut so the whole shebang stays up.
yeah theyre the 1 piece ones. i was just following housecors direction, but how did he get his to stay up? thats what im wondering. ill post some pics when i get done. hey kelvin, you coming out to cruise night next month?
i didnt even kno there was gona be one next month. I dunno i might go if i can roll with someone locally. When is it? Im takin summer courses....yeh...sucks...
In regards to the bumpstops, i assumed that they were the foam ones but i guess you have the rubber ones.
im just gonna work on the rest of it, and get new boots tomorrow, they were torn apart anyways. theres cruise night every month, and july 8th theres gonna be nissan/infiniti meet. hope to see you out there.
Always cut bumpstops when lowering car, even a mild drop requires bumpstops to be cut. This will allow you to regain some of the strut travel that you lose when lowering the car.
Both Tokico and KYB recommend this as well.
What works for me with the rubber bumps it to cut the bottom section of the bump and toss the boot. I then get rancho boots and zip tie them around the remaining bump stop. The boots are $3-4 each at my local parts store in the offroad section. Stock boots are over priced.
Originally Posted by Teufelhunden
i know, but the top part of the bump stops fit into the top hat. and when i cut it, it didnt fit anymore. so all i have is the boot just hanging loose in there. so i dont know how any one else did theirs.
But, I do like the idea of using the Rancho replacement boots now that I think about it.
I am running Tokico HPs with Maxspeed and cut my bumpstops. 7k miles later and no issues with them.
ok, i decided to just trimmed the bottom part of the boot, instead of cutting the top part, which is the area thats connected to the top hat, it seems like it doesnt interfere with the movement of the strut
REDinLV
08-15-2024 12:30 AM
Need help
23
10-02-2015 08:56 AM
