My car won't start
Old 07-20-2007, 05:32 AM
CKOTuHA's Avatar
My car won't start
This morning I was leaving to work and my Maxima gave me a little surprise. It won't start at all. Radio worked fine, all the cluster lights were illuminated normally. With a turn of a key, it would try to start for a split second and then I would hear clicks. This is a 2003 Maxima GLE.
I did an oil change yesterday. My car does it oil. It never had any starting problems and its not winter right now so I doubt its a battery.
Any ideas what else it could be.
I just hope its not something serious because I won't be able to fix it tomorrow.
CKOTuHA is offline
Old 07-20-2007, 05:36 AM
Cletus
SoonerFan's Avatar
low battery most likely caused by bad alternator that isnt providing power and changing battery.
SoonerFan is offline
Old 07-20-2007, 05:56 AM
CKOTuHA's Avatar
I still do have an original Nissan battery, but like I said all the light are bright. They are not dim. Plus I didn't see a single sign of battery going bad, nor I ever had a problem with it. I understand if the car was parked for a few weeks, but its being used every single day.
So you still think its just the battery?
CKOTuHA is offline
Old 07-20-2007, 07:06 AM
jkayca's Avatar
It could be the starter itself although not having dim lights is not necessarily a sign that the battery is OK. It takes an awful lot of amps to crank and only a few to light up the dash.
If you can get the car started by boosting then that rules out the starter and leaves the battery/alternator as the culprit.
jkayca is offline
Old 07-20-2007, 07:50 AM
MichMaxFan's Avatar
I agree w/ trying a jump to rule out starter issues. By the way, when my original battery took a dump, it was July! Don't let the nice weather fool you.
Actually, nice and hot weather is hard on a battery cause of the heat in the engine compartment.
I would: Try the jump. Then buy a battery.
MichMaxFan is offline
Old 07-20-2007, 08:23 AM
pyroz's Avatar
Sounds like the battery to me. I had the same problem and though it was the starter, but it turned out to be the battery.
pyroz is offline
Old 07-20-2007, 08:58 AM
LACEY DAVIS's Avatar
same problem the warm weather destroys a battery just like the cold the oem battery you have to check the water level unscrew the six ***** they are low refill with water if damaged to bad replace
LACEY DAVIS is offline
Old 07-20-2007, 10:09 AM
SuperStasiu's Avatar
Try jump starting the car first then get back to us
SuperStasiu is offline
Old 07-20-2007, 01:59 PM
CKOTuHA's Avatar
I'm going to do it right now, in case if it is the battery, what should I get? A red top? What is the model for our Max? I know that by book they don't make one for us.
CKOTuHA is offline
Old 07-20-2007, 03:03 PM
NOOB
ktranne's Avatar
I think this one would work........
ktranne is offline
Old 07-20-2007, 03:07 PM
CKOTuHA's Avatar
Yes guys, it was the battery. I'm glad it wasn't anything mechanic related.
So for Red Top I need 35-910, right?
CKOTuHA is offline
Old 07-20-2007, 04:11 PM
CKOTuHA's Avatar
I just went to Costco, Pepboys, AutoZone and Sears and nobody has a 35-910 model.
Where could I buy one?
CKOTuHA is offline
Old 07-20-2007, 05:00 PM
Drug Money
MaxBoost925's Avatar
Remy Battery from ebay. Low prices.
MaxBoost925 is offline
Old 07-20-2007, 05:02 PM
CKOTuHA's Avatar
I need something local, I can't wait for the battery for a week.
Maybe I could buy a battery thats is very similar to Red Top?
CKOTuHA is offline
Old 07-20-2007, 05:03 PM
jkayca's Avatar
I went to Walmart an bought an Energizer. Works fine.
jkayca is offline
Lakersallday24
06-16-2019 01:35 AM
kjlouis
11-24-2018 06:09 AM
Btheman80
05-01-2018 04:03 PM
MAXSE5SPD
08-23-2015 12:06 PM
BobMax
08-15-2015 12:35 PM
Quick Reply: My car won't start
