grinding noise
Old Apr 23, 2008 | 03:32 PM
  #41
6SPD02SE's Avatar
I had my brakes completely gone over. And mine is still making the grinding noise. Im going to replace the wheel bearing next.
Old Apr 24, 2008 | 12:25 PM
  #42
CMax03's Avatar
Grinding noise
Originally Posted by ajsuper7
My max is an auto, so its not the clutch. I'm getting it looked at in thursday morning. if they can't figure it out ill let you know. I really think its a dragging brake pad. i dont think its a cv joint because im not getting a clunk sound its just a metallic gridning and from what my friends heard by walking next to my car as a drive its definitly something in the brakes.
Ajsuper7 check your private messages!
Old Apr 24, 2008 | 06:37 PM
  #43
docuk22's Avatar
AJ did you find out what the problem was?
Old Oct 17, 2008 | 09:58 AM
  #44
1chewabacha1's Avatar
Update?
Old Oct 18, 2008 | 06:57 PM
  #45
docuk22's Avatar
my problem ended up being bad barings, i dunno if the hub wa bad but had it changed out anyways $450 at the dealership
Old Oct 23, 2008 | 10:42 AM
  #46
96maxi's Avatar
So it was you front passenger bearing?
I've just recently been getting a groaning type noise from my rear passenger side. Once I hit 40 it starts and it sound like a jet engine. I've took it to a few shop but no one can figure it out. The noise started when my mom did a 180 in the rain and the car slammed against the curb. Do you guys have any thoughts of what the problem might be. I don't have any braking issues and just that that is sounds like something is rubbing.
thanks for the help
-d
Old Oct 23, 2008 | 02:35 PM
  #47
kcx1112's Avatar
change your breaks!
Old Oct 24, 2008 | 09:50 PM
  #48
CMax03's Avatar
Dam! I found those same exact bearings @ NAPA for $70... and I'm sure the hub could be replaced for cheaper than the Stealership and the same exact part! That bearing R & R by a machine shop approx $40 total. I sure If you would have done this yourself, you'd spend less than $250 total....
Old Nov 8, 2008 | 07:13 AM
  #49
6SPD02SE's Avatar
Sorry for the late response, but it ended up being the wheel bearing. My mechanic said when he unbolted the hub it fell out in his hand. No more sounds and it as smooth as ever.
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
