Neon Undercar Install
Old Nov 3, 2001 | 11:02 PM
Raf2kMax's Avatar
I want to put on the blue neon undercar kit tomorrow morning. For those of you who have already put it on your car..anything tricky about it?? any drilling underneath the driver seat and stuff?? need some help guyzz.
thanks
Old Nov 3, 2001 | 11:05 PM
BigDogJonx's Avatar
Yeah, be VERY VERY VERY freagin careful when drilling. Cause you need to make sure you aint drilling into anything like the fuel line that runs on the driver's side.
This aint gonna be a fun job, hope you got the whole day free for this one.
Dixit
Old Nov 4, 2001 | 12:53 AM
adman's Avatar
Re: Neon Undercar Install
thanks
You can also use Silicone...
Don't worry, it will stay.
ADMAN
Old Nov 4, 2001 | 01:05 AM
BigDogJonx's Avatar
Re: Re: Neon Undercar Install
ADMAN
Wait wait wait, ADMAN for one minute here be serious. How you put a whole undercar neon kit on with silicon? This i wanna hear.
I had to drill my whole freagin set into the car underbody.
Dixit
Old Nov 4, 2001 | 07:31 AM
SkyMax Jr.'s Avatar
Dixit
It'll will only take long if u are working by yourself. Do you have any buddies to help with the install? Let me know when u get the sides mounted.
Old Nov 4, 2001 | 01:48 PM
Raf2kMax's Avatar
guess what guys?? i connected everything together..soldered it and all..and even connected a 7 amp fuse goin to the battery..i was just testing to see if it works or not this morning. ohhhhh boy. NO BLUE LIGHT!!!
this sux
Old Nov 4, 2001 | 01:54 PM
SkyMax Jr.'s Avatar
this sux
Why did you need to solder? What kit did you buy?
Old Nov 4, 2001 | 02:48 PM
Greg's2kGLE's Avatar
this sux
Better check your connections.
Oh and do you have any more pictures (or bigger ones) of your car with the Nija kit. I haven't seen one in Gray Lustre. Thanks!
Old Nov 4, 2001 | 03:30 PM
Raf2kMax's Avatar
heres two pics that NyCe MaXiMa and 2dMax took at the NE Meet.
http://wsphotofews.excite.com/001/xw/bY/I1/3n46927.jpg
http://jkim3.homestead.com/files/WOO...-102701-14.jpg
The reason i need solder is to make the connections stronger and stuff between the wires.
Old Nov 4, 2001 | 09:16 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Uh oh... did you check if the neons worked before installing them?
Old Nov 4, 2001 | 10:05 PM
Raf2kMax's Avatar
Oh yeah..i never installed the lights themselves to the car. I just layed out the lights and hooked it up to the battery. Imagine that though..installing the lights to the car and finding out that they dont work!! woww..wouldnt that be somethin'?
Old Nov 5, 2001 | 06:30 AM
Y2KevSE's Avatar
That would suck, wouldn't it?
Old Nov 5, 2001 | 07:57 AM
AudioMan's Avatar
Neon Lights now working
Did you ground the lights or just give them power?
Old Nov 5, 2001 | 08:02 AM
SkyMax Jr.'s Avatar
What kind of kit did u buy? Was it the Lite Glow kit from custommaxima.com?
Old Nov 5, 2001 | 08:19 AM
Raf2kMax's Avatar
yeah i got it from greg from custommaxima. the first time i got it..the bulbs were cracked inside. i just got the new ones like a week ago..after a month of liteglows slowness. its arite though. greg had my back.
Old Nov 5, 2001 | 08:21 AM
Raf2kMax's Avatar
Re: Neon Lights now working
hoooooldup. i gotta ground em too when i just test it out?? ohhhh boy
back to the garage for me..next week when i get back home
Old Nov 5, 2001 | 08:46 AM
Y2KevSE's Avatar
Re: Re: Neon Lights now working
Touch the metal piece (of the transformer thingy) to the negative terminal.
Old Nov 5, 2001 | 08:49 AM
AudioMan's Avatar
Ground
Were you serious about not grounding them or just joking? Yes, anything on a DC circuit has to be grounded to work (AC too but it is not a "ground"). The ground completes the circuit kind of like a maglight flashlight with batteries in it but the bottom not screwed on. Also, is the 7 amp fuse what came with it? That seems a bit small. I would assume a whole neon kit to need at least a 20-30 amp fuse. If it is too small it will blow very quickly, and also cause the lights to not work.
Old Nov 5, 2001 | 11:43 AM
Raf2kMax's Avatar
Re: Ground
on the instructions, it didnt have anything about the "extra" wire going from the transformer to the negative on the battery. i knew somethin was up but still..didnt want all the lights blowing up on me u know? also, theres a built in fuse from the transformer to the switch already that came with the undercar kit. a 7-10 amp fuse is recommended going from the transformer to the positive on the battery. i bought a slow blow 7 amp fuse from radio shack and just soldered it on. sooo...connect the wire to the negative also and i should be gettin em lit huh? damn i luv this forum!
thanks alot guys
Old Nov 5, 2001 | 11:53 AM
AudioMan's Avatar
Ground
Yes, the ground should solve your problem. You may want to be carefull about soldering on the fuse. If it ever blows you will have to re-do all of it. There are fuse holders that make that job a snap. However, it should never blow unless there was a problem somewhere else such as a short. Remember to clean your ground off if you are going to attach it to the metal on the car somewhere. Some steel wool works ok, just make sure the ground is clean and the metal is bare. Be really careful if you are just touching it to the negative terminal of the battery or anywhere else with your bare hands, you will probably get a short spark. Have fun.
Old Nov 5, 2001 | 12:07 PM
adman's Avatar
Re: Re: Re: Neon Undercar Install
Dixit
Look, I did the neon thing 13 years ago. Back then, you couldn't buy a kit at Pep Boys. You made your own tubes and housed them inside plex tubing. Then, you either drilled and "clamped" them under your car or you ran a bead of clear Silicon and stuck the tube there. Prop it and/or tape it in place over night and you're set for life. That is, until the dealer jacks your car up and break everything.
Maybe, some day, I'll post some pictures of the good ole days...
ADMAN
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
