P0011 & P0021
Old Jul 17, 2008 | 04:59 PM
nismomaxx's Avatar
P0011 & P0021
I recently had my clutch changed, after the clutch swap my car threw a Service Engine Soon light, I have a OBD2 reader and the codes were Camshaft Positioning Actuator Banks 1 & 2.
After doing some research, that partciular piece is under recall... Mine never got replaced, therefore I'm going to get my swapped. Figured I'd post it up, and let everyone know.
http://www.internetautoguide.com/aut...ima/index.html
Pulled directly from that website :
Recall Summary
ON CERTAIN PASSENGER VEHICLES, THE CIRCUIT BOARD FOR THE CRANK POSITION SENSOR OR CAM POSITION SENSOR MAY HAVE AN IMPROPER SOLDER JOINT DUE TO SOLDER DEFORMATION CAUSED BY HEAT STRESS ACCELERATED BY THE EXISTENCE OF FLUX RESIDUE DURING THE SOLDERING PROCESS.
Consequence
THIS COULD CAUSE THE "SERVICE ENGINE SOON" WARNING LIGHT TO COME ON, CREATE A NO START CONDITION, CAUSE REDUCED ENGINE POWER, OR CAUSE THE ENGINE TO STOP RUNNING WITHOUT WARNING DURING VEHICLE OPERATION, WHICH COULD RESULT IN A CRASH.
Old Jul 17, 2008 | 06:08 PM
VQP0WER's Avatar
Well, if your car is not effected by the recall, here are the possible causes:
Harness or connectors
(Intake valve timing control solenoid
valve circuit is open or shorted.)
valve
Crankshaft position sensor (POS)
Camshaft position sensor (PHASE)
Accumulation of debris to the signal
pick-up portion of the camshaft
220k+ A32
Sep 23, 2015 03:38 PM
dizmax03
Oct 5, 2014 09:48 AM
Nismo_max04
Aug 8, 2012 09:27 AM
misiek
Oct 15, 2006 09:18 AM
