Lowered Maxima pulling to one side
Old Nov 17, 2008 | 08:41 PM
waltj2k's Avatar
Hello
I have a 2k maxima that has been lowered with Maxspeed springs.
The problem is when I turn the wheel hard to the left the car pulls left. When I turn the wheel hard right the car pulls right.
I just had the CV axles replaced along with the tie rods.
What is causing the car to do this?
Walt
Old Nov 17, 2008 | 08:45 PM
IHAVEA2KMAXIMA's Avatar
That is very weird...
You didn't mention having your alignment done. Maybe it's off after you got lowered.
Old Nov 17, 2008 | 09:18 PM
NissanTun3r's Avatar
when you turn your steering wheel counterclockwise the car should turn left....
Old Nov 17, 2008 | 10:43 PM
PulsarGTS's Avatar
LOL, dude seriously.
Old Nov 17, 2008 | 11:22 PM
nismology's Avatar
Are you referring to the car having more of a tendency to want to turn like the steering is being "sucked" into a certain direction? What you are experiencing might be caused by the toe-out after the drop. The car will also have more of a tendency to follow ruts in the road (tramlining) when there is excessive toe-out. You need to get it realigned.
Old Nov 18, 2008 | 12:47 AM
maxboy325's Avatar
^^^^^ thats what I was going to say
Old Nov 18, 2008 | 05:30 AM
jasonmax's Avatar
do the alignment.
Old Nov 18, 2008 | 06:00 AM
Tee00Max's Avatar
yea try the alignment, i was just recently dropped on maxspeeds and i have a 2k and i haven't had any alignment problems but im going to get one this weekend probably...
Old Nov 18, 2008 | 06:01 AM
waltj2k's Avatar
OK so over the last week I had the axles replaced along with the Tie rod ends. I had the car worked on at NTB. They stated that they aligned the car twice to get it as close as possible.
Now I am sure they did the Laser alignment and just pulled up the Maxima specs and tried to get the car aligned based on those numbers. But my car is different. Lowered car on 18 inch rims. Wheels and tires aspect ratio is close to the stock numbers though.
Old Nov 18, 2008 | 06:08 AM
Tee00Max's Avatar
yea i have 235/40/18 i dont know why it would be pulling....take it to a shop and see if they can figure it out.
Old Nov 18, 2008 | 08:18 AM
RickyBobby's Avatar
alignment should be done after lowering the car
Old Nov 18, 2008 | 09:03 AM
maybe the shop didn't replace the outer tie rods LOL.
IT sounds like a something's wrong with your rack and pinion....
Old Nov 18, 2008 | 09:18 AM
tbergma1's Avatar
I dont understand what he's talking about, thats what its supposed to do. Is this a joke?
If not do this for some troubleshooting.
Drive on a level surface, let go of the wheel, if it pulls to one side or the other, than you have an alignment issue or a tire issue.
The cheapest thing to do for testing purposes
1. is to make sure the tires are inflated to the same psi, test it.
2. Still has the problem, flip the front tires, test it.
If that doesnt do anything, then the tires are not the problem, no money lost. Then you have a suspension issue.
I used to do a lot of suspension work and would say that half the time the tires were to blame. the other half was alignment and worn out balljoints or tierod ends. Once in a while you get a car in with a bent LCA, usually the old people get this.
Old Nov 18, 2008 | 10:01 AM
CMax03's Avatar
How much did you lower your car? Maybe you're experiencing an over torqued upper strut shaft nut or two bad strut bearings, was all that New....
Old Nov 18, 2008 | 03:57 PM
waltj2k's Avatar
Went back to the shop and based on what I am experiencing it seems as though it's the rack and pinion.
Waiting on the quote.
Old Nov 18, 2008 | 06:24 PM
VQP0WER's Avatar
Sorry to hijack but I need some help..
Whenever I apply the brakes, the car slows down....
please help.
Old Nov 18, 2008 | 06:48 PM
Blitzfist's Avatar
please help.
oh thats an easy one just start putting milk in the gas tank and your good to go.
To the op sounds like a rack and pinion problem. does the wheel still turn back normally after making a turn or does it have resistance?
Old Nov 29, 2008 | 10:46 AM
waltj2k's Avatar
To the op sounds like a rack and pinion problem. does the wheel still turn back normally after making a turn or does it have resistance?[/QUOTE]
I have had 3 estimates and everyone has concluded rack and pinion replacement will cure what ills this car. Now looking to see where I would like to get the service done. $1600 @ the Nissan shop $900+ @ the other shops.
Old Nov 29, 2008 | 12:10 PM
foodmanry's Avatar
Da Roller Coaster!
Honestly....I wouldn't get the work done. Just wait and see if the problem (is it really a problem?) becomes worse. If you have to replace or rebuild the rack and pinion what have you go to lose if you wait?
It seems like you are very sensitive to changes in the car. After a drop or lowering, and even after alignment, you will still be slightly off or outside the specs. It is normal. Rack and pinion porblems on 2k's are not normal.
CRizz
41
Jun 7, 2021 05:42 AM
twotonezed
Aug 16, 2015 08:10 PM
Balkins
Aug 12, 2015 06:39 AM
cmpowell86
Aug 10, 2015 12:35 AM
BassAddictJ
Aug 4, 2015 11:38 AM
