Identification of this griding "creaking" noise from front end
Old Jan 13, 2009 | 12:19 PM
  #41
Jreed2008's Avatar
Originally Posted by hi-tek22
oh man, im not even gonna lie, lol....the dealer is going to SCREW U THE FIRST CHANCE THEY GET
But the mechanic is have is like the family mechanic, hes a friend of my dad's so i kind of get the "lookout", and he is the only one that ive let really touch my car as far as mods......SS LINES, BRAKES, Illumina's upgrade, Progress RSB, Megan racing exhaust installed
Hey Tek im in B-more on the west side, Im having the same issues wondering if your mechanic could use anymore work. Because I need my wheel bearings change desperately and I'am afraid of what the stealership will quote me.
Old Nov 20, 2009 | 06:50 PM
  #42
slidewayzm5's Avatar
Sometimes after I turn to the lock in either direction (eg - parking lot), then straighten out and accelerate - I hear a slight grinding noise only while accelerating. The closest way to describe it is almost stalling a vehicle - too much load, not enough RPM. It only happens from time to time - I was thinking CV joints? How would I diagnose this problem?
Thanks.
Old Dec 15, 2009 | 09:50 AM
  #43
timmyg1's Avatar
I would suspect Strut Mount Bearings. Could also be the Bearings in the HUB. If over 125k miles, I would replace both
Old Feb 10, 2010 | 09:36 AM
  #44
tchenku's Avatar
Hey guys sorry for the old bump.
I'm having a similar issue as the OP, but his videos are no longer available.
Here's mine:
http://www.youtube.com/watch?v=HY6zfRNfoTc
new axle time? I've got an autozone one waiting to go in (*cross fingers*) but I want more assurance that the problem IS the axle/CV joint. Someone mentioned their problem going away with a new wheel bearing and it just added to my doubts.
My symptoms:
noise happens on decel, louder with brakes and pretty faint without brakes
noise gets loudest doing full-lock circle to the left
no steering wheel vibration
no brake pedal vibration
no car vibration
engine belts look good and are tight to spec
all brake hardware good and no interference/scraping between visible parts
Thanks for any input. Feel free to leave Youtube comments; I'm sure it will help some others. FWIW there aren't many videos showcasing bad CV axle symptoms while the axle's still on the car.
Old Mar 12, 2010 | 04:28 AM
  #45
Alex01's Avatar
Tchenku, I'm having the same noise. I think it was diagnosed in post 36 as the hub assembly. Going to have mine replaced today.
Old Mar 27, 2010 | 09:06 PM
  #46
cleanfil's Avatar
Let me know if that solves it alex because i am just getting that noise with hard right turns, and let me know how much you paid if the hub assembly fixes it
Old Apr 3, 2010 | 08:53 PM
  #47
AJ~'s Avatar
AJ~
If it was a CV joint, it would make noise turning both right and left.
If it makes noise only when turning in one direction, look to things rubbing, and look at the wheel bearings.
Old Apr 3, 2010 | 08:58 PM
  #48
PulsarGTS's Avatar
I have this noise now...After changing out my Eibachs to H&R springs in the front coincidentally enough.
Old Sep 4, 2010 | 10:24 AM
  #49
eldonbrockman's Avatar
Finally figured out that weird squeaking/grinding noise coming from the front end
Originally Posted by Max_Gator
I get the same noise when slowing/coming to a stop - but only while going STRAIGHT. It is not brake related as it makes the sound whether I'm braking or not.
And it is speed sensitive in that the speed of the noise correlates to the speed of the vehicle. But it does not make the sound other than when coming to a stop.
Drives me batty.
I don't think it is a strut bearing - I recently replaced my struts with Tokiko and replaced all the parts.
My guess is that it will turn out to be the hub/wheel bearing. I've already had that side replaced and have an raxle - but it really is the only thing that makes sense.
However, I'm only going to fix it if the car wasn't totaled when I was rear-ended last week!
I had the same problem. Weird squeaking/grinding noise sounded like it was coming from the front left. It wasn't constant, and seemed like it was in sync with wheel rotation. Definitely wasn't brakes as I pursued that to death. The noise was only noticeable when at slower speeds. It made it while going straight or turning. And if I just barely touched the accelerator the noise would go away.
Turned out to be the hub assembly. Had it replaced and now the car is quiet and smooth.
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
Justin Kroll
Sep 2, 2015 11:06 AM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
