Bose Woofer Cut Off Problem for 2001 Maxima
Old Sep 23, 2011 | 10:07 AM
  #161
tony R.'s Avatar
thanks djcalvin the pics and the explaining are perfect, gonna try it today.
Old Sep 23, 2011 | 10:11 AM
  #162
DjCalvin's Avatar
Do the penny trick wrapped in electrical tape. Works perfectly.
Old Sep 23, 2011 | 10:48 AM
  #163
QT1 5MT AE's Avatar
Gram Lights addict
Birens relay is the ultimate solution. nearly 3 months and the woofer hasnt cut out a single time. cant go wrong with that !
Old Sep 23, 2011 | 10:50 AM
  #164
DjCalvin's Avatar
Same with the penny trick. Hasn't cut out in the 3 months since I put it on. My resoldering trick didn't last unfortunately.
Old Oct 10, 2011 | 10:31 AM
  #165
jruss21's Avatar
4 months on the paper trick and still working great. My previous comments about the bass not having the same punch were incorrect. I have to turn the volume down on some songs as they have a little too much bass. I guess it's just the poor quality of some of my MP3's.
Old Oct 11, 2011 | 06:05 PM
  #166
spock's Avatar
mp3's and quality sound is an oxymoron anyway.
Different recordings are going to have different bass levels. And treble levels and midrange levels...
Old Nov 16, 2011 | 05:41 PM
  #167
Tyler79's Avatar
Interesting.
Old Nov 17, 2011 | 08:01 AM
  #168
Roymg's Avatar
I just got my relay from biren. how did you guys go about installing it ? did you just rip off the old relay? and how do you figure out where to soldier this new one as the dimensions are different? just looking for a heads up before i do this purely on guess work
Why couldn't a small hole be drilled into the top of the relay case and then spray into it with some contact cleaner. It must have contacts in it and temp or ware seems to effect the clearances of the make and break gaps.
I think this relay only turns on the power to the small amp.
Old Dec 22, 2011 | 03:11 PM
  #169
RagittyAndi's Avatar
Been 8 months since I did the paper trick and it still hasn't cut out... I do have the problem with the volume on the steering wheel not always working...
Old Jan 25, 2012 | 07:37 PM
  #170
redrocker67's Avatar
I just registered so I could post in this thread. I stumbled across this while researching my wife's sub problem in her 2004 I35. This lead me down my own road of investigating an exact replacement relay. I ran across Mouser part number 769-CQ1-12V. This is an exact replacement. What I mean by that is the pins are in the same location and the physical dimensions are the exact same as the relay on the cross over board. I replaced the existing relay with this one and it works like a champ! Just thought I would pass this along.
Old Jan 26, 2012 | 07:07 PM
  #171
spock's Avatar
Thanks for the heads up.
One of the best first posts I've seen.
Old Jan 27, 2012 | 05:26 AM
  #172
Thanks. I may be new here, but I am far from new on car bulletin boards. I've been doing this before they became "forums" instead of BBS!
One thing I also noticed when removing the old relay is that the pins came loose very easy inside the relay as I was trying to get it released from the board. This is probably the source of the failure. If they came lose with just a small amount of wiggling, then they probably were lose already to begin with. Also, instead of searching for an exact part number, you can search for the type of relay it is, which is "CQ1-12V". I found them everywhere from ebay to Amazon. I opted for Mouser because I had just purchased a bunch of parts to make an attenuator from them and knew how much shipping would be and how long it would take. In other words, it was EASY!
Old Jan 28, 2012 | 09:35 PM
  #173
vrroom's Avatar
Worked for me
The 3 cent fix worked for me. We'll see how long it lasts. I used a thin plastic material wrapped in cloth tape. If it goes out again, I may try replacing the relay.
Old Apr 2, 2012 | 04:16 AM
  #174
Rob1224's Avatar
hate to revive such an old thread but with the 3 cent fix how thick approximately is the paper/material you guys used when folded or put in, just thought knowing that would make it a little more quick and simple for me.
Old Apr 2, 2012 | 07:25 AM
  #175
Galactica's Avatar
It'll need to be about 3/16" thick. An 1/8" will probably work, but you want it to press on that relay. I did mine about a month ago and it's been perfect ever since. I used a heavier cardboard type paper and just cut pieces to layer on each other and then wrapped it in some 3M Super 33+ (Real electrical tape)
Old Apr 2, 2012 | 10:15 AM
  #176
Rob1224's Avatar
so i did the 3 cent fix as we seem to call it lol, got the sub working now the only problem is it cuts out, so im guessing its a problem with the soldering points? would i be better off going with a whole new stock relay or a relay from the taiwan manufacturer earlier in the thread?
Old Apr 7, 2012 | 06:39 PM
  #177
biren41888's Avatar
The "3 cent fix" wont always work because the vibrations from the sub can knock it loose. The problem is inside of the relay and has nothing to do with the solder points or "cold solder points" as some may call it. I still have the blue relay if you are interested email me bvmp4@yahoo.com
Old May 13, 2012 | 04:12 PM
  #178
dprime's Avatar
THANKS!
Gotta love the internet. Re-solder didnt work for me but the penny trick did. Im going to order a new relay (I have issues with duct tape fixes) but if the penny trick holds then I may just leave it. I had a rear speaker out and this issue with the sub. Fixed them both at the same time... BIG difference in the sound system.
Old May 13, 2012 | 11:37 PM
  #179
kedarox's Avatar
Did the re-solder on my 01 SE. Been working great for about a month so far. Zero cut-out.
Old May 16, 2012 | 03:01 PM
  #180
dprime's Avatar
Ordered the relay from the post above and soldered it in today... works like a champ... hope this one holds up for a while.
Old May 16, 2012 | 07:23 PM
  #181
spock's Avatar
A new relay seems to be the fix. I've had mine in for over a year without issue, (thanks Biren).
Old May 17, 2012 | 02:04 AM
  #182
Grand_hustle17's Avatar
Any links on what to order?... I'm a sound noob... I also have n 01 n bose goes in n out
Old May 17, 2012 | 10:17 AM
  #183
NmexMAX's Avatar
dot dot dot ...
My Blose hasn't worked in cold weather for the past 5 years or so. No screen anytime, rain or shine, only my steering wheel buttons work, and only the power button on the head unit work.
FML
Old Jun 7, 2012 | 10:09 PM
  #184
KeeWay's Avatar
if anyone is interested i found a few of the blue relays, they had 5 in stock when i ordered mine for 89 cents. it looks to have all the same numbers as posted by biren41888. i will try to install it this weekend.
http://www.surplus-electronics-sales...roducts_id=580
Old Jun 8, 2012 | 10:44 AM
  #185
2000MaximaSE's Avatar
ripping apart the sub and busting out the soldering iron can be a fun project untill you solder the **** out of every connection you see and it still doesnt work... Do what I did.. find an Infinity Bass Link on craigslist and wire it up using the bose sub stock wiring.. better bass and no cutting out! and you can find them for like 100 bucks now.. Plus my idiot friend thought I was running 2 10's back there after that..
Old Jun 10, 2012 | 06:02 PM
  #186
spock's Avatar
Just buy the fukcing relay for $5 and fix the sub amp!
Old Jun 10, 2012 | 09:48 PM
  #187
KeeWay's Avatar
I replaced it this weekend with not too much trouble and I now have my base back . great fix thanks again..
Old Jun 10, 2012 | 11:48 PM
  #188
No dice
Old Aug 20, 2012 | 10:11 PM
  #189
Trouble916's Avatar
I got tired of the cut out and i had already replaced the relay once before and the cut out happend again so i came to the conclusion that the relay was a POS and must go. so this is the end result remove relay and jump the circuit works perfect no problems whatsoever Name:  e03438a2.jpg
Old Aug 20, 2012 | 10:12 PM
  #190
Trouble916's Avatar
Old Aug 30, 2012 | 07:26 AM
  #191
Yankee's Avatar
Just throwing in my $.03 ...
My sub was cutting out constantly, tried the .03 cent trick about a week ago and it hasn't cut out once since.
I'll probably order the new relay redrocker posted (Mouser part number 769-CQ1-12V) anyway just to get it fixed right but the work around has been great so far...
Old Sep 6, 2012 | 06:48 PM
  #192
m21bmr's Avatar
Do you get a thump from the subwoofer when you turn the stereo on with the relay removed and the circuit jumped?
Old Sep 16, 2012 | 12:59 PM
  #193
Trouble916's Avatar
No not at all that was one thing i was kinda worried about when i first did it. I have had absolutely no after affects from removing the relay at all.
Old Sep 16, 2012 | 09:39 PM
  #194
CaTalyst.X's Avatar
I am going to try the .03 fix, and if that doesnt work, I will do this. This is brilliantly simple.
Also, I am CONVINCED that biren had a source for those relays for less than a buck, and was selling them for $15, kept making new accounts to come on this thread and say how great they were.
I dont know how long the site keeps track of MACs and IP's, but if all of those can be linked to the same MAC (provided this fellow is not too smart), then he needs a ban. I just read through 5 pages of this thread and at least a page of it was either his or his troll accounts spam.
Old Oct 2, 2012 | 10:52 AM
  #195
Bloodklot's Avatar
Originally Posted by biren41888
here it is...if any one wants a relay like that and if you want your sub to work for sure...send me $15 to my address so i can drive 1 hour to dayton and get it ..and then i can mail it to you....if you would like to do this...email me at bvmp4@yahoo.com
Uploaded with ImageShack.us
I know you uploaded this ages ago but can you tell me where you bought those relays? A link would be helpful. Thanks.
Old Oct 2, 2012 | 05:43 PM
  #196
CaTalyst.X's Avatar
I think they are about impossible to find. They are (and have been) discontinued for a long time. Those relays arent any better than as far as design then the bose relay, but Bose bought the cheapest piece of crap relay they could find.
See this thread:
http://forums.maxima.org/5th-generat...-once-all.html
Old Oct 3, 2012 | 06:05 AM
  #197
LA02MAX's Avatar
Some duct tape worked wonders for me. Before I may have heard a note or two per month from the sub, and since then it's been perfect.
Old Oct 5, 2012 | 08:18 PM
  #198
5thGENJORDAN's Avatar
dude this problem has been driving me crazy for months!!!!!!!!!! finally a solution.
Old Oct 5, 2012 | 08:36 PM
  #199
CaTalyst.X's Avatar
This is a fix, but its not a definitive fix. The .03 trick works for many people, the resolder works for some others. Its better to replace the problem relay.
There is a detailed how-to in this thread:
Old Nov 21, 2012 | 03:57 PM
  #200
biren41888's Avatar
I don't think so! I am a tech/computer geek and I came up with this solution because Bose integrated a cheap quality relay. I drove an hour to a warehouse to purchase these relays. I did not buy a lot because I didn't think people would actually pay $15 for...but surprise surprise, people did and I will guarantee if they soldered it right, it is still working for them! I did not create accounts just to sit around my computer and make my relays look good. I HAVE A LIFE, I am in grad school and for 40 hours a week. So stfu!
I sold them for $15 because I took time out of my busy schedule to drive an hour to the warehouse and but the relay...also pay for the bubbled envelope and shipping, I also gave detailed instructions on how to install it! For the people who bought relays off of me...how is the sub working for you??
