Bose Woofer Cut Off Problem for 2001 Maxima
Old Dec 3, 2012 | 05:52 PM
  #201
Donkeypunch's Avatar
So I was going to try the pressing on the relay trick when I see this....
What the heck? Did bose forget something?
I have a 2000 if that matters.
Old Dec 3, 2012 | 06:03 PM
  #202
CaTalyst.X's Avatar
Wow that is from a 2000? That is strange. It is missing a few things... but I dont think they forgot, more like they didnt use them.
The number on that board is different from the ones I have worked on (I have repaired many a 01/02):
http://forums.maxima.org/5th-generat...-once-all.html
You are experiencing cutout with that PCB? Or does the sub just not work at all.
Old Dec 3, 2012 | 06:53 PM
  #203
Rods03Max619's Avatar
Not sure, but if you don't figure it out time for a upgrade....
Old Dec 3, 2012 | 08:23 PM
  #204
The sub never worked and you can see why. Really strange that stuff is missing.
I'm 30 years old. I'm not going to put in no jbl thump box ect.
Old Apr 24, 2013 | 05:11 PM
  #205
jayw's Avatar
Quick update:
I used the paper trick, worked for a few months. Problem came back.
Bought the relay online that is listed in this thread. I installed it and the subwoofer has been working perfectly for almost a year now.
Thank you to everyone involved in getting the information out there to fix this problem.
Old Aug 28, 2013 | 10:16 AM
  #206
Roymg's Avatar
Originally Posted by AUTOmobilePHILE
i have an 03 max, i got it in august. the bose sub hasnt worked ever since i had the car. i did a visual inspection of the sub and connections to the amp, and everything looks okay. the 4 door speakers and 2 tweeters work great, just the sub doesnt work. i really want to get the bose sound in my car, any ideas or suggestions? and you said you have subs for sale, is that the stock bose? if so, how much?
There is a relay built into the circuit board of the speaker that causes the sub to work sometimes and not sometimes. Somewhere in this forum there are a lot of comments and pictures about this. The relay is identified to a part number which I'm again looking for. I believe its a cheap fix. I think this relay turns the sub amp on and off.
Old Dec 4, 2013 | 01:01 AM
  #207
idea24's Avatar
Paper trick for the relay on the sub amp circuit board works!
Hey folks! I was on the infinitihelp forum looking at solutions regarding this same issue for I30/I35s and eventually wound up here. This thread was EXTREMELY helpful in solving my issue with the Bose sub cutting out in my infiniti. I did do the paper trick as suggested below and it's worked great since. Granted, it's only been a week, but all seems to be good now.
If for any reason this ends up being a temporary solution, thanks to all who listed info on where and how to get the new relays.
Much appreciated!
Originally Posted by levellkinchen
This is what i did. I took a piece of paper folded it several times and wrapped it in electrical tape. Placed it on top of this 'GREY' box. Closed the silver metal box. and Whola!!!!!! IT DOESN'T CUT OUT ANYMORE. it cost me about .03 cents.
Before you laugh try it. VELKIN '01 I30
Old Dec 4, 2013 | 09:26 AM
  #208
DennisMik's Avatar
The paper trick will probably "wear out" after some unknown amount of time. In your case, the relay itself is good, it is the solder connections that have failed. Resoldering should keep you going for another 10+ years.
Old Feb 23, 2014 | 04:33 PM
  #209
Suzie (v)Q's Avatar
Fast & Furry-ous
For the DIY'ers that are competent in soldering, but maybe not as competent in parts searching, I found this relay at Fry's, Philmore relay #86-112. It's just a simple SPDT relay, and there are cheaper options elsewhere. However, shipping always being a factor of total price, this was the cheapest venue I found for ordering alone (~$3.50 + $2 s/h). Working great for me. Uses the larger footprint holes on the board, but does not interfere with the outer shield.
__
JD
Old Feb 23, 2014 | 11:32 PM
  #210
Dumb question, but what does that little box do exactly?
Is it an amp? Can't I just go buy a cheap amp at the swap meet and replace it?
Old Feb 24, 2014 | 05:10 PM
  #211
Roymg's Avatar
It amps up the lower freq. and powers the base speaker. I know you can find replacement amps for home theater base boosters, but for this 12v system in a car, I don't know without spending time to ck it out.
Old Oct 18, 2014 | 04:59 PM
  #212
Wreslteman69's Avatar
Thanks!!
Originally Posted by CaTalyst.X
I am going to try the .03 fix, and if that doesnt work, I will do this. This is brilliantly simple.
Also, I am CONVINCED that biren had a source for those relays for less than a buck, and was selling them for $15, kept making new accounts to come on this thread and say how great they were.
I dont know how long the site keeps track of MACs and IP's, but if all of those can be linked to the same MAC (provided this fellow is not too smart), then he needs a ban. I just read through 5 pages of this thread and at least a page of it was either his or his troll accounts spam.
.... Pretty much ... damn scammers do anything... love the forum ... gotta few things to try now to fix my POS Bose system! !!
Old Oct 18, 2014 | 08:04 PM
  #213
3 Cent Cheap'o Fix
Ok not sure if anyone is checking this thread anymore but will say I did the " wedge " technique..... and bass NEVER sounded as good as it does now !
Didn't have money to get it looked at much less get a new system..... So tried this cuz I don't have the resources for soldering.... If or when it goes out I'll update! Very informative! I will be checking out more topics in this forum next couple of days!
Old Oct 18, 2014 | 11:19 PM
  #214
Unclejunebug's Avatar
For what it's worth I tried the folded up electrical tape trick but it didn't work for me at all. As DennisMik mentions above, if the relay is bad no amount of folded up anything will fix the problem. I didn't bother replacing the relay since I added an Alpine 10" sub in the trunk but I will definitely replace it if/when I get rid of the car.
Old Feb 1, 2015 | 07:51 PM
  #215
AVaive's Avatar
Just made an account to say that I was having the intermittent Sub-outage on my '03 Max, and I was all ready to do the solder fix when I read about the electrical tape / paper method. Saved myself some trouble and gave that a shot and it works wonderfully! Fixed it right up. Bass is bumping again. But I just did this, so I'm not too sure about longevity. I'm sure soldering would be the more permanent fix, but I'm more of a "there, I fixed it" kind of guy. Thanks to all for the step-by-step guides + pictures!
Old Feb 2, 2015 | 12:09 PM
  #216
lukevp's Avatar
FYI, I did the paper trick and it worked for a month, max. I ended up just replacing the relay and I hadn't even thought about it until now but it's been working since then (a year or two later.) It was only $14. Would recommend just ordering the part from digikey and soldering a new one in.
Old Feb 2, 2015 | 05:50 PM
  #217
If you guys can list the part number of that big cap. on the bottom right
and the transistor on the bottom right that would be really helpful.
Mine didn't come with those or a relay mount at all. sub has never worked since day 1.
Old Feb 4, 2015 | 09:53 AM
  #218
DennisMik's Avatar
If Bose made that printed circuit board without those parts, I don't think putting them on is a good idea. You might be creating parallel circuits that could cause a short.
I would suggest getting the printed circuit board from a junkyard car instead.
my .02
Old Apr 1, 2015 | 04:29 PM
  #219
elarsik's Avatar
Originally Posted by paradiddle
I did this .03 repair and its working again !!!
Unbelievable, it works
Old Apr 1, 2015 | 06:47 PM
  #220
Since you bumped this if you have a 2000 with the missing components like mine.
They are on the harness before the speaker.
I just soldered the board and BAM got alittle bass back.
Old Jun 30, 2015 | 07:32 PM
  #221
DivinedragoonZu's Avatar
Thank you!!
Thank you DjCalvin! Performed the soldering to the grey relay per your instruction and it worked like a dream! I thought the relay was blown for sure but micro cracks in solder seem to be the cause of most electronics malfunctions these days. Sucks to be a newb here :/ but I'm super glad the veterans here are so knowledgeable. Thanks again guys. Baaaaasssssss!
Old Sep 25, 2015 | 10:56 PM
  #222
pleonard15@yahoo.com's Avatar
Thanks so much for this information! Really helped me out in a pinch! Been having this cut out for the last few years, and finally just completely died. Didn't bother with the paper trick since I read all the posts that it was temporary at best. Re-soldering with a new (better) relay did the trick! At least it worked for my initial tests. If I have problems with it again, I will reply to this thread, but no news is good news at this point.
Sure, it was a bit of work to replace, but gave me an excuse to learn how to solder and buy a set! Plus I enjoy the satisfaction of having fixed something myself, and not just sending an otherwise perfectly good sub into the trash heap. It was a little tricky for my first time (the relay had to be pried off from the top after removing all the soldering from the 5 relay pins), but after that it was all pretty straight-forward.
You just have to have the right tools, the right material, and the right mindset, and I find you can do a lot in life!
Thanks again all!
Old Sep 26, 2015 | 06:06 PM
  #223
Canadian_I35's Avatar
Anyone have one for sale and willing to ship to Canada? I can't order from frys, store pick up only. Will paypal you, thanks.
Old Sep 28, 2015 | 12:03 PM
  #224
Thanks they ship to Canada i just did the paper trick hopefully that will work until i receive the relay.
Old Sep 28, 2015 | 01:40 PM
  #225
Derrick2k2SE's Avatar
On the 2000 those parts are in the plastic wrapped piece in the harness outside the main box. Cut that open and there's a small board in there with the relay. I just fixed the wifes 00 by shorting the two contacts as shown here in post #3.https://maxima.org/forums/5th-genera...-once-all.html
Only I left the relay in place and did it from the back of the board. It works perfectly now. I may replace the relay some time.
I tried soldering the contacts but it didn't help.
Old Oct 2, 2015 | 09:17 AM
  #226
Prophecy99's Avatar
[IMG]https://cimg6.ibsrv.net/gimg/maxima.org-vbulletin/882x496/80-relay1_bd171aad33928139ee45996bc356e31c9baced0e.jp g[/IMG
[IMG]https://cimg7.ibsrv.net/gimg/maxima.org-vbulletin/882x496/80-relay2_4533a9ed904fc94a91566621d88957713eddcb3e.jp g[/IMG
so basically you figured out the bypass trick on the 2002 and 2003 just as others have done on the 2000 and 2001?
Old Oct 2, 2015 | 09:49 AM
  #227
The thread I linked already shows how to do it in an 02-03 car. That thread explains the weakness of the cheap relay Bose used.
I just took that info and applied it to the 00 car where the relay is in a different location. The only fixes in this thread for the 00 were to resolder the connections or bypass the entire small circuit board.
Old Apr 25, 2016 | 09:51 AM
  #228
Bigruu1's Avatar
This is the fix that I opted for. Put it in yesterday, now I have a unit that works good. Fry's had the right relay, bigger and better than the crap that was in there, and now the bass keeps on thumping. Good, solid advice, glad I followed it.
Old Apr 25, 2016 | 10:09 AM
  #229
Bigruu1's Avatar
Followed advice of Suzie(v)Q and got the Philmore relay from Fry's. Unsoldered the old (crappy) one and soldered in the new one. Best move I made so far, great, continuous bass sound.
Attached Thumbnails Bose Woofer Cut Off Problem for 2001 Maxima-dsc09859.jpg
Old Apr 25, 2016 | 11:28 AM
  #230
Bigruu1's Avatar
2001 Bose Subwoofer Fix
I am trying to show a better picture of the new relay.
Bought in from Fry's Electronics and replaced the old relay. Bass is now working properly.
A quick shout-out to Dennis Mik, the "Guru".
Old May 16, 2016 | 05:05 PM
  #231
Dbow's Avatar
New to this actually just signed up to post here.
I just spent the last hour carefully reading everyone's post about the sub cutout issues and how to fix. Djcalvin you did a great job with your right up. But I'll be damned if I didn't stick a piece of cardboard wrapped in electrical tape on top of the gray box and I'm thumpin again. Absolutely unreal. Thank you everyone that contributed to this post.
Old Oct 7, 2016 | 11:03 AM
  #232
Darkness's Avatar
Has this fix still been working for you? Do you notice a pop on startup and shutdown? If this works I rather do it this way than having to order and replace the relay.
Old Oct 25, 2016 | 09:03 AM
  #233
maxinout93's Avatar
Originally Posted by acgrunt19
So you used the original relay?
Basically the method behind the idea is just to force the realy downward so it always makes contact......correct?
Where is this part located? Under the speaker or is this the amplifier?
Old Oct 25, 2016 | 11:36 AM
  #234
Prophecy99's Avatar
under sub on rear deck, access from trunk,
i soldered a new relay, havent looked back
Old Oct 26, 2016 | 04:46 AM
  #235
maxinout93's Avatar
Thanks alot man, im having the same annoying issue! Gonna try to fix it this weekend.
Old Oct 26, 2016 | 06:29 AM
  #236
Prophecy99's Avatar
i never truly soldered before but got it done, and i am not sure my self but there is a subtle difference with 5 and 5.5 gen, prolly described in this thread somewhere
Old Oct 26, 2016 | 04:32 PM
  #237
Darkness's Avatar
I don't recall seeing this difference. Can you share?
Old Oct 26, 2016 | 06:47 PM
  #238
The difference is where the relay is located. My 00 has the relay on a small circuit card in the harness going to the sub. My 02 has the relay on the main circuit board under the sub.
I think 01 was the crossover year but It'll be obvious when you pull it apart. If you have a big lump in the harness going to the sub then you have the earlier design. I've posted pics of how to solder a jumper on both years that will fix the problem. I've had zero issues in either car for years now and both of them had completely lost the sub before the fix.
Old Oct 27, 2016 | 09:13 AM
  #239
Prophecy99's Avatar
perfect! so the jumper is as proper of a fix as the relay replacement, thanks derrick
Old Oct 27, 2016 | 06:48 PM
  #240
It has been for me. It's free and requires less soldering skills than the replacement.
